Bookmark this page:
Yahoo!
Windows Live
del.icio.us
digg
Netscape
Posted by Andy Doe on July 2, 2009, 12:26 pm
I have a ASA 5005 here which supports up to 10 Users. What does this exactly mean? Is this a count of internal IP addresses? If so, can I extend the possible internal clients through PAT? Lets say I put an internal router behind the FW which does PAT for the internal clients behind the router (the FW should only see one IP then, right?) Just a thought...what do you think? BR...Andy | ||||||||||
Posted by Chino on July 2, 2009, 12:40 pm
Please log in for more thread options If ASA works just like the old 501 PIX, then limit is applied to the nat translations. So you only can get 10 user nat translated at a time. If you setup a router behind, it should work fine. | ||||||||||
Posted by alexd on July 3, 2009, 3:26 pm
> translations. > So you only can get 10 user nat translated at a time. If you had, say, a network printer that had no need to access the internet, presumably removing its default gateway setting would ensure it didn't count toward the total? -- <http://ale.cx/> (AIM:troffasky) (UnSoEsNpEaTm@ale.cx)
20:25:03 up 58 days, 4:58, 1 user, load average: 0.28, 0.19, 0.17
A few flakes working together can unleash an avalanche of destruction | ||||||||||
Posted by Chino on July 4, 2009, 6:33 am
Please log in for more thread options > If you had, say, a network printer that had no need to access the
> internet, > presumably removing its default gateway setting would ensure it didn't > count > toward the total? Never tried but it should work. | ||||||||||
| Similar Threads | Posted |
| Questions about max. Users ASA | July 2, 2009, 12:26 pm |
| Monitoring VPN users on PIX 515 | September 23, 2005, 2:16 pm |
| ASA na local users | February 24, 2008, 5:21 pm |
| VPN Client - some users can't connect | February 2, 2006, 10:57 am |
| RME baseline templates, any users? | April 29, 2006, 6:52 pm |
| End-Users vpn client question | April 30, 2006, 10:04 pm |
| Configuring a VPN for users to connect thru | May 11, 2006, 12:24 am |
| Need a VPN solution for 25 users..already own PIX 515UR | September 26, 2006, 10:14 am |
| Internet only users - PIX settings | October 1, 2009, 11:38 am |
| Baltimore Cisco users' group | February 11, 2005, 1:11 pm |
| PIX or Router blocks wireless users? | November 7, 2005, 5:59 am |
| How to write on syslog which users access via RAS. | January 5, 2006, 11:12 am |
| How to write on syslog which users access via RAS. | January 5, 2006, 11:46 am |
| Michigan LWAP WLAN Users | January 20, 2006, 9:16 am |
| Active Directory users on Cisco PIX | February 23, 2006, 5:26 am |
Yahoo!
Windows Live
del.icio.us
digg
Netscape
> right?)
