Cisco Systems QOS VOIP - Hosted IP PBX Provider
Subject Author Date
QOS VOIP - Hosted IP PBX Provider pilotnine 07-04-08
Posted by on July 4, 2008, 11:04 am
Cisco 1720 router with 1 internet T1 to a IP PBX hosted provider.
I am having constant dropped calls, choppy, echoes, backup noises and
clipped calls when using the IP phone. I would like to implement QOS
on router, and am wondering if this will help. Hosted provider is
using MGCP and g.721 compression. The T1 line is mostly idle and used
very little for anything other than web surfing and phone calls.T1
line is error free and IP PBX provider checked and claim nothing is
wrong on their end.
Does anyone have a sample QOS configuration that may work? or point me
to the right direction where I may obtain
more information.
IP hosted PBX provider -----Internet Cloud -----Cisco 1720---
Firewall-------Switch---SIP IP phones..
Cisco IOS Software, C1700 Software (C1700-ENTBASE-M), Version
12.3(8)T11, RELEASE SOFTWARE (fc1)
Technical Support: http://www.cisco.com/techsupport
Copyright (c) 1986-2005 by Cisco Systems, Inc.
Compiled Wed 10-Aug-05 19:07 by dchih
ROM: System Bootstrap, Version 12.2(7r)XM1, RELEASE SOFTWARE (fc1)
Thanks!
Bill
Posted by headsetadapter.com on July 4, 2008, 12:48 pm
Bill,
If your T1 used not only for telephony, then you definitely need to
configure QoS on the router, as well as on your switches, as well as confirm
the configuration on the provider side. Here is a great document on all
aspects of QoS on Cisco devices (it's "best practices" for Quality of
Service).
In general, you must configure QoS on all your devices - the router, LAN
switches, phones. For example, if you configured QoS on the router, but your
LAN switch strips QoS marking, your QoS will not work. Or if your phone
sends other information, than router expects. Here is a list of what you
should do:
1. On the Router configure Priority Queuing (page 185)
2. On the Router configure Traffic Shaping for the voice (pages 206-215)
based on number of calls you expect.
3. On the switch(es) configure CoS trust (pick the section in the menu
depending on model of your switch)
4. Confirm with the provider, what DSCP values do they expect.
Also, since you have a firewall between your LAN and the router, things may
become more complicated, since firewalls (except the latest code of Cisco
ASA) do not understand and do not conform the QoS settings. So, you may need
to re-classify all voice traffic at the router.
Also, if you don't feel comfortable with doing all this stuff yourself, I
would advice you to get a consultant, who will do all this changes for you.
Believe me, it will be faster and cheaper.
Good luck,
Mike
CCNP, CCDP, CCSP, CCVP, MCSE W2K, MCSE+I, Security+, etc.
CCIE R&S (in progress), CCIE Voice (in progress)
Headset Adapters for Cisco IP Phones
www.ciscoheadsetadapter.com
www.headsetadapter.com
> Hi,
> wrong on their end.
> more information.
> Thanks!
> Bill
Posted by bill the kid on July 4, 2008, 1:09 pm
> Bill,
> Service).
> should do:
> Good luck,
> Mike
Phoneswww.ciscoheadsetadapter.comwww.headsetadapter.com
> > Hi,
> > wrong on their end.
> > more information.
> > Technical Support:http://www.cisco.com/techsupport
> > Thanks!
> > Bill
Mike,
Thank you for your suggestion. Do you have a URL or the author of the
mentioned doc - "Here is a great document on all
Service). "
Thanks!
Bill
Posted by headsetadapter.com on July 4, 2008, 2:35 pm
Sorry, forgot to insert the URL:
http://www.cisco.com/application/pdf/en/us/guest/netsol/ns432/c649/ccmigration_09186a008049b062.pdf
Good luck,
Mike
>> Bill,
>> confirm
>> Service).
>> your
>> should do:
>> may
>> need
>> you.
>> Good luck,
>> Mike
>> > Hi,
>> > wrong on their end.
>> > more information.
>> > Thanks!
>> > Bill
> Mike,
> Service). "
> Thanks!
> Bill
Posted by John Osmon on July 8, 2008, 2:19 am
pilotnine@gmail.com wrote:
: Hi,
: Cisco 1720 router with 1 internet T1 to a IP PBX hosted provider.
: I am having constant dropped calls, choppy, echoes, backup noises and
: clipped calls when using the IP phone. I would like to implement QOS
: on router, and am wondering if this will help.
Don't forget -- QOS on your 1720 only queues things on the egress of
your network. Your provider has to provide queuing for the ingress.
A better solution is to buy a bigger pipe, but that isn't always
an economical solution.
I sell a hosted PBX product. We try to make sure we also sell the
Internet access so that we can control packet flow to the customer
premise. It helps us eliminate a number of the quality issues that
other hosted companies run into.
We also keep all of our VOIP gear in a single /24, so that customers can
prioritize packets in our direction based on IP address. A lot of cheap
equipment allows you to priority-queue things based on IP addresses.
(Actiontec ADSL equipment comes to mind...)
An old-school Cisco template for priority queueing would look like:
interface Serial0
priority-group 1
access-list 112 permit ip any <voiop-ip-block> <mask>
priority-list 1 protocol ip high list 112
This template is likely to work on your 1720 -- but doesn't use the
newer modular QOS mechanisms, so is likely to draw ire from many
directions.
Similar ThreadsPosted
QOS VOIP - Hosted IP PBX Provider July 4, 2008, 11:04 am
Linksys VoIP boxes NOT tied to a particular provider? February 13, 2006, 11:28 am
Voip Updated Howto,Voip ATT Home (October Update) October 29, 2006, 9:00 am
Reliability of Provider July 23, 2005, 1:50 am
Obtain DNS Information from Provider April 26, 2006, 5:00 pm
Voip Updated Howto,Voip AT Home June 28, 2006, 9:02 pm
Cannot establish connection with ADSL provider December 4, 2005, 4:12 pm
Trying to connet to Telia(Skanova) ADSL provider in Sweden with 837 July 9, 2005, 10:35 am
Service Provider Bandwidth Test MPLS Network July 9, 2007, 9:47 am
Catalyst 3750-METRO as MPLS Provider Core July 8, 2008, 6:39 pm
Multiple network/Multiple provider Routing May 23, 2007, 10:56 am
VOIP June 21, 2006, 2:18 pm
Allow VOIP through PIX 501 July 10, 2006, 3:54 am
FAX + VoIP - T.30 / T.38 August 22, 2006, 4:20 pm
VoIP over VPN August 28, 2006, 4:16 am
