Posted by ronnieshih on January 27, 2007, 12:50 am
I have a site currently with a router directly to internet with
access-lists and no firewall, this router is configured with PPTP for
remote clients to vpn in. The serial interface has a public IP,
ethernet interface has a private IP. Remote clients VPN in via the
public IP tied to the serial interface on the router right now. I will
be swapping out the old router with a new 1800 and put in an ASA
firewall behind the 1800 router. My question is, how do I keep the VPN
capability for remote clients? They want VPN on the ASA instead of
being on the router. That means the outside interface of the ASA must
have a public IP within their range. Do I place the IP address that's
currently assigned to the serial interface on the router onto
fastethernet0 and leave serial interface unnumbered? Then ASA's
outside interface directly connected to the router's fastethernet0??
Does the router know how to pass packets from serial to its
fastethernet0 interface automatically?
thanks
| Similar Threads | Posted |
| Q on router/firewall config with pptp for clients enabled | January 27, 2007, 12:50 am |
| PPTP VPN with XP clients | March 24, 2007, 6:37 am |
| Issue with Ipsec and pptp clients | April 10, 2006, 5:29 am |
| PPTP clients connecting to PIX VPN host | January 9, 2007, 9:41 pm |
| PPTP clients connecting to PIX VPN host | January 9, 2007, 10:15 pm |
| VPN PPTP Clients and IPSEC tunneling between sites | July 11, 2005, 8:52 am |
| Configuring Access for L2TP and PPTP Clients on PIX 506 E | February 2, 2006, 6:44 am |
| PPTP Clients loose connection to cisco PIX 506E after a while.. | April 26, 2007, 6:59 am |
| Configure Cisco PIX515e PPTP VPN Clients to allow access to another network across a IPSEC Tunnel | August 17, 2007, 9:22 am |
| Help with internet router config to allow pptp | July 7, 2005, 11:43 am |
| Looking for H.323 and VPN enabled dialer? | September 1, 2006, 7:54 am |
| Looking for H.323 and VPN enabled dialer? | September 23, 2006, 6:59 am |
| Looking for H.323 and VPN enabled dialer? | October 9, 2006, 9:45 am |
| initial config of 3560, set config, cant ping~~nv_done: unable to open "flash:/C:\new\config.new | February 5, 2008, 11:39 pm |
| Problem Connecting from some computers after NAT-T Enabled | April 20, 2007, 9:48 am |
