Bookmark this page:
Yahoo!
Windows Live
del.icio.us
digg
Netscape
Posted by on October 26, 2005, 5:02 am
Please log in for more thread options i have a problem with my router 877w. i try to work over adsl. My provider is Tiscali. I want to connect my pc by interface WIFI DOT11Radio. I don't work. It's curious. All my interface of my router is UP. Since my pc connected via WIFI, I ping 10.10.10.1 ( gateway address WIFI of my router ) so the addresse IP of the PEER. The ping command(order) ATM interface atm 0 8 35 end is OK the ping command(order) ATM interface atm 0 8 35 seg is OK also Please help me . i don't understand my problems I have to forget some thing but which this my configuration of my router. Current configuration : 3238 bytes ! version 12.3 no service pad service timestamps debug datetime msec service timestamps log datetime msec no service password-encryption ! hostname yourname ! boot-start-marker boot-end-marker ! logging buffered 51200 warnings ! username xxxxx privilege 15 secret 5 $1$f6mU$TtSID75SNDbTYCDZITRvj. no aaa new-model ip subnet-zero ip cef ! ! no ip domain lookup ip domain name yourdomain.com no ftp-server write-enable ! ! ! ! ! bridge irb ! ! interface ATM0 no ip address no ip redirects no ip unreachables no ip proxy-arp ip virtual-reassembly no atm ilmi-keepalive pvc 8/35 encapsulation aal5mux ppp dialer dialer pool-member 1 ! dsl operating-mode auto dsl enable-training-log ! interface FastEthernet0 no ip address no cdp enable ! interface FastEthernet1 no ip address no cdp enable ! interface FastEthernet2 no ip address no cdp enable ! interface FastEthernet3 no ip address no cdp enable ! interface Dot11Radio0 no ip address ! ssid ESSAI vlan 1 authentication open guest-mode ! speed basic-1.0 basic-2.0 basic-5.5 6.0 9.0 basic-11.0 12.0 18.0 24.0 36.0 48.0 54.0 rts threshold 2312 power local cck 13 power local ofdm 13 channel 2462 no cdp enable ! interface Dot11Radio0.1 description Essai Open encapsulation dot1Q 1 native no cdp enable bridge-group 1 bridge-group 1 subscriber-loop-control bridge-group 1 spanning-disabled bridge-group 1 block-unknown-source no bridge-group 1 source-learning no bridge-group 1 unicast-flooding ! interface Vlan1 no ip address bridge-group 1 bridge-group 1 spanning-disabled ! interface Dialer0 ip address negotiated ip mtu 1492 encapsulation ppp dialer pool 1 dialer-group 1 no cdp enable ppp authentication chap pap callin ppp chap hostname xxxxxxx@tiscali.hautdebit ppp chap password 0 xxxxxxx ppp pap sent-username xxxxxx@tiscali.hautdebit password 0 xxxxxx ! interface BVI1 ip address 10.10.10.1 255.255.255.0 ! ip classless ! ip http server ip http authentication local ip http secure-server ip http timeout-policy idle 600 life 86400 requests 10000 ! no cdp run ! control-plane ! bridge 1 protocol ieee bridge 1 route ip banner login ^C ----------------------------------------------------------------------- Cisco Router and Security Device Manager (SDM) is installed on this device. This feature requires the one-time use of the username "cisco" with the password "cisco". Please change these publicly known initial credentials using SDM or the IOS CLI. Here are the Cisco IOS commands. username <myuser> privilege 15 secret 0 <mypassword>
no username cisco
Replace <myuser> and <mypassword> with the username and password you
want to use.
For more information about SDM please follow the instructions in the QUICK START GUIDE for your router or go to http://www.cisco.com/go/sdm ----------------------------------------------------------------------- ^C ! line con 0 login local no modem enable transport preferred all transport output all line aux 0 transport preferred all transport output all line vty 0 4 privilege level 15 login local transport preferred all transport input telnet ssh transport output all ! scheduler max-task-time 5000 end Why my router don't working over ADSL Please Help me | |||||||||||||||||||
Posted by Rob on October 26, 2005, 9:26 am
Please log in for more thread options you could use some NAT statements. Is the public IP being assigned to the dialer interface when you do a show command? | |||||||||||||||||||
Posted by on October 27, 2005, 10:24 am
Rob a =E9crit : > I'm not familiar with the 877w, but if its like any other IOS device,
> you could use some NAT statements. Is the public IP being assigned to > the dialer interface when you do a show command? thank rob but now i resolve my problem. I try to work a tunnel vpn ipsec into a router 877w and vpn concentrator. For example, this my configuration : version 12.3 no service pad service timestamps debug datetime msec service timestamps log datetime msec no service password-encryption ! hostname yourname ! boot-start-marker boot-end-marker ! logging buffered 512000 warnings ! username xxxxxxx privilege 15 secret 5 $1$RzzB$r0NZzV36DKNHexVsQELuU/ clock timezone PCTime 1 clock summer-time PCTime date Mar 30 2003 2:00 Oct 26 2003 3:00 no aaa new-model ip subnet-zero no ip source-route no ip cef ip dhcp excluded-address 10.10.10.1 ! ip dhcp pool sdm-pool1 import all network 10.10.10.0 255.255.255.0 default-router 10.10.10.1 ! ! no ip bootp server ip name-server 213.36.80.1 ip ssh time-out 60 ip ssh authentication-retries 2 no ftp-server write-enable ! ! ! ! ! bridge irb ! ! interface ATM0 no ip address no ip redirects no ip unreachables no ip proxy-arp no atm ilmi-keepalive pvc 8/35 encapsulation aal5mux ppp dialer dialer pool-member 1 ! dsl operating-mode ansi-dmt ! interface FastEthernet0 no ip address no cdp enable ! interface FastEthernet1 no ip address no cdp enable ! interface FastEthernet2 no ip address no cdp enable ! interface FastEthernet3 no ip address no cdp enable ! interface Dot11Radio0 no ip address ! ssid wifiESSAI authentication open guest-mode ! speed basic-1.0 basic-2.0 basic-5.5 6.0 9.0 basic-11.0 12.0 18.0 24.0 no cdp enable bridge-group 1 bridge-group 1 spanning-disabled no bridge-group 1 source-learning no bridge-group 1 unicast-flooding ! interface Vlan1 description $ETH-SW-LAUNCH$$INTF-INFO-HWIC 4ESW$$FW_INSIDE$ no ip address bridge-group 1 ! interface Dialer0 ip address negotiated no ip redirects no ip unreachables no ip proxy-arp ip nat outside ip virtual-reassembly encapsulation ppp dialer pool 1 dialer-group 1 no keepalive no cdp enable ppp authentication chap pap callin ppp chap hostname xxxxxxx@tiscali.hautdebit ppp chap password 0 xxxxxxxx ppp pap sent-username xxxxxxxxx@tiscali.hautdebit password 0 xxxxxx ! interface BVI1 description $ES_LAN$$FW_INSIDE$ ip address 10.10.10.1 255.255.255.0 ip nat inside ip virtual-reassembly ip tcp adjust-mss 1452 ! ip classless ip route 0.0.0.0 0.0.0.0 Dialer0 ! no ip http server ip http authentication local ip http secure-server ip http timeout-policy idle 600 life 86400 requests 10000 ip nat inside source list 1 interface Dialer0 overload ! no logging trap access-list 1 permit 10.10.10.0 0.0.0.255 dialer-list 1 protocol ip permit no cdp run ! control-plane ! bridge 1 protocol ieee bridge 1 route ip banner login ^C ----------------------------------------------------------------------- Cisco Router and Security Device Manager (SDM) is installed on this device. This feature requires the one-time use of the username "cisco" with the password "cisco". Please change these publicly known initial credentials using SDM or the IOS CLI. Here are the Cisco IOS commands. username <myuser> privilege 15 secret 0 <mypassword>
no username cisco
want to use.
For more information about SDM please follow the instructions in the QUICK START GUIDE for your router or go to http://www.cisco.com/go/sdm ----------------------------------------------------------------------- ^C ! line con 0 login local no modem enable transport preferred all transport output all line aux 0 transport preferred all transport output all line vty 0 4 privilege level 15 login local transport preferred all transport input telnet ssh transport output all ! scheduler max-task-time 5000 end | |||||||||||||||||||
Posted by on October 27, 2005, 10:25 am
Please log in for more thread options now i try to configure my router 877 for create a vpn ipsec with a vpn
concentrator 3000 of my bussiness unit i don't work | |||||||||||||||||||
| Similar Threads | Posted |
| Problem config Cisco 877w | October 26, 2005, 5:02 am |
| cisco pix 515 config problem (ver 7.3) | July 19, 2007, 8:51 am |
| cisco 2610 config problem | February 18, 2006, 7:50 pm |
| Cisco PIX Client VPN Config Problem | August 8, 2007, 3:49 pm |
| CISCO 2950 vlan config problem | August 18, 2005, 9:01 am |
| NAT type of Cisco 877W | November 26, 2005, 8:14 pm |
| Using IPv6 on a Cisco 877W | October 21, 2006, 10:52 am |
| Bridging with a Cisco 877W | December 21, 2006, 1:11 pm |
| Cisco 877W of 857W ? | May 23, 2008, 10:28 am |
| Cisco 877W and Demon | November 22, 2008, 9:39 am |
| Cisco 877W Router ( Newbie ) | November 3, 2005, 7:28 pm |
| Upgrading flash in a Cisco 877W | October 27, 2006, 5:31 am |
| Cisco 877W as Wireless client | July 1, 2007, 12:49 pm |
| Cisco 877W, fixed IP, ISP connection drops | June 30, 2006, 2:37 am |
| Cisco 877W shows incorrect DSL attenuation | July 3, 2006, 7:26 pm |
Yahoo!
Windows Live
del.icio.us
digg
Netscape
