Bookmark this page:
Yahoo!
Windows Live
del.icio.us
digg
Netscape
Posted by tman on May 9, 2008, 2:35 pm
Please log in for more thread options 3500XL switch so they will not trunk. I used the following command: conf t int fa0/1 switchport mode access It takes the command o.k. but when I do a sh run it does not show that the interface is in access mode. Moreover, when I connect another switch to fa0/1 with at cross-over cable, it trunks. When I use the same command on a Catalyst 2950 switch, this is what I see when I do a sh run: interface FastEthernet0/1 switchport mode access Am I missing something? Thanks in advance. | |||||||||||||
Posted by Doug McIntyre on May 9, 2008, 3:40 pm
Please log in for more thread options >conf t
>int fa0/1 >switchport mode access You need to turn off Dynamic Trunking Protocol int fa0/1 switchport mode access switchport nonegotiate | |||||||||||||
Posted by tman on May 9, 2008, 4:56 pm
Please log in for more thread options > >I want to configure several FastEthernet interfaces on a Catalyst
> >3500XL switch so they will not trunk. =A0I used the following command: > >conf t > >int fa0/1 > >switchport mode access >
> You need to turn off Dynamic Trunking Protocol > > int fa0/1 > =A0switchport mode access > =A0switchport nonegotiate I tried it but there is no such command as switchport nonegotiate. The only commands under switchport are: access mode multi priority trunk voice I tried the following command in interface config mode: no negotiation auto It returns the message: This command is not supported for FastEthernet0/1 | |||||||||||||
Posted by Merv on May 9, 2008, 5:08 pm
Please log in for more thread options to disable trunking on a 3500XL, try the command
no switchport mode | |||||||||||||
Posted by tman on May 9, 2008, 6:51 pm
Please log in for more thread options > to disable trunking on a 3500XL, try the command
> > no switchport mode I already tried that one. It doesn't seem to do anything. I can still plug another switch into the port and it lights up. | |||||||||||||
Problem Configuring Access Mode on an Interface on a Catalyst 3500XL
Yahoo!
Windows Live
del.icio.us
digg
Netscape
