Cisco Systems Posting etiquette question
Subject Author Date
Posting etiquette question K.J. 44 10-23-06
Posted by K.J. 44 on October 23, 2006, 9:44 am
I have a question, is it considered bad etiquette to repost a question
if an answer was never received? For instance, I never had a single
response on:
http://groups.google.com/group/comp.dcom.sys.cisco/browse_thread/thread/9f2b68096fbd885f
Is it okay to repost the question or will that be bad board etiquette?
Because i am in a bind with these VPNs and need some help.
Thanks.
Posted by www.BradReese.Com on October 23, 2006, 12:09 pm
Hi Kevin,
The remote peer is not responding to the client's request to establish
the connection.
Make sure you can ping the remote peer, or check remote peer logs for
why it is not responding to the client.
Sincerely,
Brad Reese
BradReese.Com - Cisco Repair
http://www.bradreese.com/cisco-big-iron-repair.htm
1293 Hendersonville Road, Suite 17
Asheville, North Carolina USA 28803
USA & Canada: 877-549-2680
International: 828-277-7272
Fax: 775-254-3558
AIM: R2MGrant
BradReese.Com - Cisco Power Supply Headquarters
http://www.bradreese.com/cisco-power-supply-inventory.htm
Posted by K.J. 44 on October 23, 2006, 1:00 pm
The outside IP address of the ASA is being Natt'ed won't affect the
fact that this is the IP I am trying to connect my VPN to?
Thanks.
www.BradReese.Com wrote:
> Hi Kevin,
> the connection.
> Sincerely,
> Brad Reese
> Fax: 775-254-3558
> AIM: R2MGrant
Posted by Barry Margolin on October 23, 2006, 9:17 pm
> Hi,
> response on:
> 096fbd885f
Usually the reason there was no answer is because no one could answer it
well. And reposting a few days later is not likely to change that.
Barry Margolin, barmar@alum.mit.edu
Arlington, MA
*** PLEASE post questions in newsgroups, not directly to me ***
*** PLEASE don't copy me on replies, I'll read them in the group ***
Posted by Walter Roberson on October 24, 2006, 12:14 am
Yes.
>response on:
It was bad etiquette the first time, to post a config trimmed down too
far for us to be able to debug the problem. We need to see
access-list 110, and we need to know whether you have sysopt
connection permit-ipsec, and if you do not then we need to see
inside_access_in and outside_access_in
You should also be considering that the documention indicates that
you should not use group 2 with AES-256: you need group 5.
You also haven't shown us anything from debug crypto ipsec
or debug crypto isakmp
Similar ThreadsPosted
Posting etiquette question October 23, 2006, 9:44 am
About posting August 24, 2005, 12:36 pm
switch not posting August 27, 2008, 5:05 pm
The Troll Who Keeps Posting About Michael Voight May 5, 2008, 9:32 am
Job Posting: Cisco Support Consultant July 3, 2008, 10:55 am
remote access vpn question (second try - sorry about that, question included this time.) April 2, 2007, 5:05 pm
pix question July 26, 2005, 7:53 pm
DNS question with VPN August 29, 2005, 12:18 am
CDP over 802.1q question August 31, 2005, 7:50 pm
pix nat question November 23, 2005, 3:46 pm
PIX 501 - question October 4, 2005, 4:53 pm
BGP question - need help !!! October 24, 2005, 7:44 am
NAT Question please help December 20, 2005, 4:25 am
BGP question December 30, 2005, 12:21 am
