Cisco Systems Port forwarding from cisco 2600 to ASA-5510
Subject Author Date
Port forwarding from cisco 2600 to ASA-5510 recvfrom 07-20-06
Posted by recvfrom on July 20, 2006, 10:23 am
Hi!
I have remote clients at sites with very restrictive firewalls which
allow only tcp/80 and tcp/443 outbound. I need to enable their
remote access IPsec VPN clients, and the only way I can think
of to do this is to 'deploy' and IP address, have their VPN clients
point to it on tcp/443, instead of the normal port. Then I'd like the
router, which has a *very* basic configuration, re-direct traffic
destined for that address on tcp/443 to the ASA on tcp/10000,
for example. Is that possible, and if so, how?? A nice, clear
example would be **greatly** appreciated! TIA!!!
-r
Posted by www.BradReese.Com on July 20, 2006, 12:41 pm
You may wish to investigate Cisco's IPSec Documentation:
http://www.cisco.com/en/US/tech/tk583/tk372/tsd_technology_support_protocol_home.html
Found on Cisco's VPN Documentation:
http://www.cisco.com/en/US/tech/tk583/tsd_technology_support_category_home.html
Sincerely,
Brad Reese
BradReese.Com - Refurbished Cisco PIX Firewall Guide
http://www.bradreese.com/refurbished-cisco-pix-firewalls.htm
1293 Hendersonville Road, Suite 17
Asheville, North Carolina USA 28803
USA & Canada: 877-549-2680
International: 828-277-7272
Fax: 775-254-3558
AIM: R2MGrant
BradReese.Com - Cisco Technical Forums
http://www.bradreese.com/cisco-technical-newsgroups.htm
Posted by recvfrom on July 20, 2006, 3:33 pm
www.BradReese.Com wrote:
Brad,
Thanks, but I'm not having any trouble with a VPN client. I
would like to find a way to re-direct traffic for one socket to
another as it passes through a router. Even reconfiguring
the VPN service to listen on a different port does not help,
since management functions are supplied on at least one
of them. The VPN situation is just a concrete example
of why I want to do this. Does that help to clarify?
-r
Posted by Darren Green on July 21, 2006, 2:56 am
> Hi!
> -r
I have an old config for TFTP that I dug out. Whilst this was on an 837 I am
sure that you could modify for your own purpose. The important lines were:
ip nat inside source list 110 interface Dialer0 overload
ip nat inside source static tcp 192.168.1.2 69 interface Dialer0 69
access-list 110 remark Nat list
access-list 110 permit ip 192.168.1.0 0.0.0.255 any
So...I allowed anything from inside to outside to be natted. The 2nd
statement mapped 192.168.1.2 on my LAN range to the Dialer 0 public IP for
TFTP.
The syntax for this command with details on how to specify the port no's is
here:
http://www.cisco.com/univercd/cc/td/doc/product/software/ios122/122newft/122t/122t13/ftnatis.htm
HTH.
Regards
Darren
Similar ThreadsPosted
Port forwarding from cisco 2600 to ASA-5510 July 20, 2006, 10:23 am
ASA5510 IMAP Port Forwarding February 21, 2007, 3:57 pm
Cisco 2600 + DSL + Cable -> Failover and port forwarding July 2, 2008, 12:47 am
Port Forwarding with Cisco 871?? September 25, 2005, 12:58 pm
cisco pix 515 port forwarding - NOT possible? hard to believe.. July 27, 2005, 12:23 am
Cisco 871 router port forwarding July 12, 2006, 8:41 pm
Cisco PIX 501 port forwarding trouble September 24, 2006, 10:32 am
port mapping or forwarding on Cisco Pix 506E August 5, 2005, 1:30 pm
Port Forwarding / VPN Pass-Thru on a Cisco 2800 August 30, 2006, 3:20 pm
ASA5510: inside DNS server getting denied - new 3 port installation June 23, 2006, 8:50 pm
Port forwarding February 2, 2006, 3:05 pm
Port forwarding help? June 4, 2006, 10:23 pm
Need help Port forwarding on PIX 501 September 14, 2006, 9:18 am
Port 21 forwarding on PIX 501 September 15, 2006, 11:56 pm
PIX Port Forwarding November 15, 2006, 2:42 pm
