Bookmark this page:
Yahoo!
Windows Live
del.icio.us
digg
Netscape
Posted by Patrick M. Hausen on July 9, 2008, 6:17 am
Please log in for more thread options for a particular installation I have set up two internet connections - one via leased line with fixed static IP addresses, the other one with PPPoE and dynamic IP addresses. The latter is a typical consumer product, i.e. "dirt cheap", high bandwidth downstream and billed flat. The leased line is a "business product" and offers less bandwidth, but symmetrical and with lower RTTs and better SLAs. The customer intends to use the cheap line for HTTP downloads as long as it is available. This was not that difficult to set up via policy routing: 1. the leased line: ------------------- interface FastEthernet1 description leased line uplink ip address x.y.z.42 255.255.255.252 ip route 0.0.0.0 0.0.0.0 x.y.z.41 250 interface Vlan3 description static network assigned by provider ip address x.y.z.57 255.255.255.248 ip nat inside ip route-cache policy ip policy route-map no-http See below for the NAT and policy config. 2. The cheap line: ------------------ interface FastEthernet0 description TDSL-Flat no ip address pppoe-client dial-pool-number 1 interface Dialer1 description TDSL-Flat 1 ip address negotiated ip mtu 1448 ip nat outside ip virtual-reassembly encapsulation ppp dialer pool 1 dialer idle-timeout 0 dialer enable-timeout 2 dialer persistent dialer-group 1 ... (deleted PPP auth parameters) ip route 0.0.0.0 0.0.0.0 Dialer1 dialer-list 1 protocol ip permit ip nat inside source list nat interface Dialer1 overload ip access-list extended nat permit ip x.y.z.56 0.0.0.7 any deny ip any any So we are NATing the official IP addresses assigned by the provider for the leased line for all traffic that is sent out the cheap one. 3. The policy route-map ----------------------- ip access-list extended no-http deny tcp any any eq www permit ip any any route-map no-http permit 10 match ip address no-http set ip next-hop x.y.z.41 This sends anything but traffic destined to port 80 out the leased line and leaves traffic to port 80 alone, so it's send out the cheap line. The entire setup works as intended but for one minor point. In case the cheap PPPoE line fails, we want to use the leased line for HTTP traffic. I intended to do this via a floating static route, hence the two default route entries you see above. Unfortunately it seems not to work that way. If I administratively shutdown Dialer1, the result is as expected. The route to Dialer1 is deleted from the routing table and the route to x.y.z.41 is used. But this is not the common mode of failure of that PPPoE line. If I simulate a failure on the cheap provider's side by administratively shutting down Fa0, the Dialer1 obviously times out and shuts down, eventually. Yet, the default route to Dialer1 is not deleted. The Dialer1 interface stays "up, line protocol is up (spoofing)", so the route stays in the routing table. Any hints on how to solve this greatly appreciated. Thanks, Patrick -- punkt.de GmbH * Kaiserallee 13a * 76133 Karlsruhe Tel. 0721 9109 0 * Fax 0721 9109 100 info@punkt.de http://www.punkt.de Gf: Jürgen Egeling AG Mannheim 108285 | |||||||||||||||||||
Posted by Patrick M. Hausen on July 9, 2008, 7:11 am
Please log in for more thread options never mind, I found a solution: int di1 description this is the cheap leased line that fortunately has got a fixed static IP address dialer persistent ... ! ! track the static IP track 1 ip route w.x.y.z 255.255.255.255 reachability ! ip route 0.0.0.0 0.0.0.0 Dialer1 track 1 Kind regards, Patrick -- punkt.de GmbH * Kaiserallee 13a * 76133 Karlsruhe Tel. 0721 9109 0 * Fax 0721 9109 100 info@punkt.de http://www.punkt.de Gf: Jürgen Egeling AG Mannheim 108285 | |||||||||||||||||||
Posted by Trendkill on July 9, 2008, 1:50 pm
Please log in for more thread options > Hello,
> > for a particular installation I have set up two internet > connections - one via leased line with fixed static IP addresses, > the other one with PPPoE and dynamic IP addresses. > > The latter is a typical consumer product, i.e. "dirt cheap", > high bandwidth downstream and billed flat. The leased line > is a "business product" and offers less bandwidth, but > symmetrical and with lower RTTs and better SLAs. > > The customer intends to use the cheap line for HTTP downloads > as long as it is available. This was not that difficult to set > up via policy routing: > > 1. the leased line: > ------------------- > interface FastEthernet1 > =A0description leased line uplink > =A0ip address x.y.z.42 255.255.255.252 > > ip route 0.0.0.0 0.0.0.0 x.y.z.41 250 > > interface Vlan3 > =A0description static network assigned by provider > =A0ip address x.y.z.57 255.255.255.248 > =A0ip nat inside > =A0ip route-cache policy > =A0ip policy route-map no-http > > See below for the NAT and policy config. > > 2. The cheap line: > ------------------ > interface FastEthernet0 > =A0description TDSL-Flat > =A0no ip address > =A0pppoe-client dial-pool-number 1 > > interface Dialer1 > =A0description TDSL-Flat 1 > =A0ip address negotiated > =A0ip mtu 1448 > =A0ip nat outside > =A0ip virtual-reassembly > =A0encapsulation ppp > =A0dialer pool 1 > =A0dialer idle-timeout 0 > =A0dialer enable-timeout 2 > =A0dialer persistent > =A0dialer-group 1 > =A0... (deleted PPP auth parameters) > > ip route 0.0.0.0 0.0.0.0 Dialer1 > dialer-list 1 protocol ip permit > > ip nat inside source list nat interface Dialer1 overload > > ip access-list extended nat > =A0permit ip x.y.z.56 0.0.0.7 any > =A0deny =A0 ip any any > > So we are NATing the official IP addresses assigned by the provider > for the leased line for all traffic that is sent out the cheap one. > > 3. The policy route-map > ----------------------- > ip access-list extended no-http > =A0deny =A0 tcp any any eq www > =A0permit ip any any > > route-map no-http permit 10 > =A0match ip address no-http > =A0set ip next-hop x.y.z.41 > > This sends anything but traffic destined to port 80 out the > leased line and leaves traffic to port 80 alone, so it's > send out the cheap line. > > The entire setup works as intended but for one minor point. > In case the cheap PPPoE line fails, we want to use the > leased line for HTTP traffic. I intended to do this > via a floating static route, hence the two default route > entries you see above. > > Unfortunately it seems not to work that way. If I administratively > shutdown Dialer1, the result is as expected. The route to Dialer1 > is deleted from the routing table and the route to x.y.z.41 is > used. > > But this is not the common mode of failure of that PPPoE line. > If I simulate a failure on the cheap provider's side by > administratively shutting down Fa0, the Dialer1 obviously > times out and shuts down, eventually. Yet, the default > route to Dialer1 is not deleted. The Dialer1 interface > stays "up, line protocol is up (spoofing)", so the route > stays in the routing table. > > Any hints on how to solve this greatly appreciated. > > Thanks, > Patrick > -- > punkt.de GmbH * Kaiserallee 13a * 76133 Karlsruhe > Tel. 0721 9109 0 * Fax 0721 9109 100 > i...@punkt.de =A0 =A0 =A0http://www.punkt.de > Gf: J=FCrgen Egeling =A0 =A0 =A0AG Mannheim 108285 PBR w/ tracking options. If your next hop on the PPoE is a public hop, you may need to block ping to that address out of the other router, but this should work if your feature set supports it: http://www.cisco.com/en/US/tech/tk364/technologies_configuration_example091= 86a0080211f5c.shtml | |||||||||||||||||||
Posted by Patrick M. Hausen on July 9, 2008, 2:30 pm
Please log in for more thread options Hello,
http://www.cisco.com/en/US/tech/tk364/technologies_configuration_example09186a0080211f5c.shtml
> hop, you may need to block ping to that address out of the other > router, but this should work if your feature set supports it: > > Though this is not needed in my particular situation (see my other post), it looks really interesting. Thanks for the link. Kind regards, Patrick -- punkt.de GmbH * Kaiserallee 13a * 76133 Karlsruhe Tel. 0721 9109 0 * Fax 0721 9109 100 info@punkt.de http://www.punkt.de Gf: Jürgen Egeling AG Mannheim 108285 | |||||||||||||||||||
| Similar Threads | Posted |
| Poor man's bandwidth management - floating static question | July 9, 2008, 6:17 am |
| Cisco 3000 and bandwidth management question | June 8, 2006, 11:55 am |
| VLAN1 for Management Question | February 14, 2008, 6:45 pm |
| Floating Virtual IP | July 14, 2007, 9:52 am |
| Bandwidth to a Website Question | October 5, 2006, 9:06 am |
| Policy Routing: Guaranteeing Bandwidth Question | March 27, 2007, 11:23 pm |
| Poor FTP performance with 837 | October 1, 2006, 3:01 am |
| Poor Mans Backup | February 8, 2006, 8:23 am |
| Poor performance with a 3640 | November 30, 2006, 10:55 pm |
| Static NAT Question | January 19, 2007, 9:33 am |
| NAT with static and outside interface - question | July 8, 2005, 12:09 am |
| static routing question | July 9, 2007, 5:32 pm |
| static route, next hop vs interface question. | January 15, 2006, 6:17 pm |
| IP Management | February 6, 2006, 9:18 am |
| lo0 for management | November 24, 2007, 12:46 pm |
Yahoo!
Windows Live
del.icio.us
digg
Netscape
