Cisco Systems Password Recovery for CISCO 836
Subject Author Date
Password Recovery for CISCO 836 freshbojan28 09-05-06
Posted by freshbojan28 on September 5, 2006, 9:16 am
can someone explain me how to get this thing going?
I 've tryed standard procedure
bits per second 1200
data bits 8
parity none
stop bits 1
flow control none
nothing I can't get into ROMMON
Also I've tryed same thing with bits per second 9600 and Ctrl + Break
Still NOTHING?
what next?
Pls help
REGARDS
Bojan
Posted by Agustin on September 5, 2006, 9:38 am
What to you mean nothing?
You cannot even connect to the serial port or you cannot managed to
change the Configuration register to be able to make enable mode
password free and the change the one that you need.
Regards.
Posted by on September 5, 2006, 10:49 am
> Regards.
Try
http://www.cisco.com/en/US/products/hw/routers/ps380/products_password_recovery09186a00800942bc.shtml
It lists other possible ways to get into ROMMON
Cheers
Dilan
Posted by www.BradReese.Com on September 5, 2006, 12:24 pm
Hi Bojan,
You may wish to investigate Cisco ROMmon Recovery Procedures.
http://www.bradreese.com/cisco-rommon-recovery-procedures.htm
Routers may go into ROM monitor ( ROMmon ) mode for any of these
reasons:
1. Boot failure.
2. The setting of the virtual configuration register forces the router
to stop in ROMmon mode during the boot.
3. A break sequence is sent to the console. The console will normally
ignore the break, except during the boot. However, the virtual
configuration register of the router may be configured to allow a break
sequence at all times.
For more information about the virtual configuration register, refer
to:
Configuration Register
http://www.cisco.com/en/US/products/hw/routers/ps133/products_tech_note09186a008022493f.shtml
To resolve your issue, please refer to the ROMmon recovery procedure
that applies to your platform:
Cisco AS5200 Series
http://www.cisco.com/en/US/products/hw/iad/ps497/products_tech_note09186a00800942de.shtml
Cisco AS5300, AS5350 and AS5400 Series
http://www.cisco.com/en/US/products/hw/univgate/ps501/products_tech_note09186a0080094697.shtml
Cisco 800 Series Router
http://www.cisco.com/en/US/products/hw/routers/ps380/products_tech_note09186a008009429e.shtml
Cisco 1000 Series Router
http://www.cisco.com/en/US/products/hw/routers/ps130/products_tech_note09186a00800942dd.shtml
Cisco 1600 Series Router
http://www.cisco.com/en/US/products/hw/routers/ps214/products_tech_note09186a0080094013.shtml
Cisco 1700 Series Router
http://www.cisco.com/en/US/products/hw/routers/ps221/products_tech_note09186a00800942dc.shtml
Cisco 2500, 3000, AS5100 and uBR900 Series Routers
http://www.cisco.com/en/US/products/hw/routers/ps233/products_tech_note09186a008009464c.shtml
Cisco 2600 Series Router and the VG200
http://www.cisco.com/en/US/products/hw/routers/ps259/products_tech_note09186a0080094a0b.shtml
Cisco 3600 Series Router
http://www.cisco.com/en/US/products/hw/routers/ps274/products_tech_note09186a008009429f.shtml
Cisco 4000 Series Router
http://www.cisco.com/en/US/products/hw/routers/ps5199/products_tech_note09186a0080094a2e.shtml
Cisco 7000 ( RP ) Series
http://www.cisco.com/en/US/products/hw/routers/ps332/products_tech_note09186a0080094afc.shtml
Cisco 7200, 7300, 7400, 7500, RSP7000, Catalyst 5500 RSM, uBR7100,
uBR7200, uBR10000, and 12000 Series Routers
http://www.cisco.com/en/US/products/hw/routers/ps359/products_tech_note09186a00800a750e.shtml
Cisco ROMmon Recovery Procedures:
Hope this helps.
Brad Reese
Cisco IOS Software - Compatible Partner Matrix by Technology
http://www.BradReese.Com
1293 Hendersonville Road, Suite 17
Asheville, North Carolina USA 28803
USA & Canada: 877-549-2680
International: 828-277-7272
Fax: 775-254-3558
AIM: R2MGrant
BradReese.Com - Global Cisco Systems Pre-Sales Support
http://www.bradreese.com/contact-us.htm#CISCO
Similar ThreadsPosted
Password Recovery for CISCO 836 September 5, 2006, 9:16 am
cisco 857 password recovery June 30, 2009, 1:45 pm
Cisco 1900 Password Recovery October 6, 2006, 12:01 pm
Avoid Password Recovery on Cisco 5300 October 6, 2005, 5:15 pm
strange cisco 7604 password recovery problem April 3, 2009, 5:05 pm
Password recovery disabled on Cisco 1711 Router - cannot login or reset May 17, 2006, 8:50 am
Password Recovery November 20, 2005, 12:00 pm
Password recovery problem July 20, 2005, 1:48 pm
Password recovery - 2900XL July 28, 2006, 11:09 pm
NO SERVICE PASSWORD RECOVERY March 6, 2008, 1:35 pm
HELP ON 2525 ROUTER PASSWORD RECOVERY February 12, 2005, 12:56 pm
Need password recovery util for LocalDirector 430 March 22, 2006, 1:53 am
PIX 520 with 5.1(4) OS enable password recovery problem October 7, 2006, 5:27 pm
Password recovery without serial port January 5, 2009, 7:45 am
aironet ap350 PASSWORD RECOVERY OR RESET ENTIRE CONFIG September 13, 2006, 7:24 pm
Residential Cabling Guide
Home Cabling Guide
Finally, an instantly downloadable book that saves you thousands in home improvement dollars! Enjoy living in 21st century technology-advanced home while increasing its selling value and competitive advantage on the real estate market. Whether your cabling is for home office or high-tech leisure, you can wire your home yourself or learn "wirish" to speak with your cabling contractors in their language!
Learn More
