Bookmark this page:
Yahoo!
Windows Live
del.icio.us
digg
Netscape
Posted by Bob Simon on November 15, 2006, 7:39 am
Please log in for more thread options selective packet capture and/or forwarding to a specified port? | |||||||||||||||||||
Posted by Walter Roberson on November 15, 2006, 1:39 pm
Please log in for more thread options Possibly. Release 12.2(20)EW and later http://www.cisco.com/univercd/cc/td/doc/product/lan/cat4000/12_2_20a/conf/span.htm#wp1066853 "monitor session" "filter ip access-group" That document is for the Cat 4000, so probably the 4500 would be the same. You can search to see if the same thing is supported for the 3700 series. | |||||||||||||||||||
Posted by Bob Simon on November 15, 2006, 3:05 pm
Please log in for more thread options On Wed, 15 Nov 2006 18:39:21 GMT, roberson@hushmail.com (Walter
Roberson) wrote: >>Does either the 3745 router or 4503 switch have the capability to do
>>selective packet capture and/or forwarding to a specified port? >
>Possibly. Release 12.2(20)EW and later > >http://www.cisco.com/univercd/cc/td/doc/product/lan/cat4000/12_2_20a/conf/span.htm#wp1066853 > >"monitor session" "filter ip access-group" > >That document is for the Cat 4000, so probably the 4500 would be the same. >You can search to see if the same thing is supported for the 3700 series. Walter, Thank you very much for the pointer to the SPAN and RSPAN documention for the 4500. This is exactly what I was looking for. It seems that I am in luck because sho ver shows that my customer is running Version 12.2(20)EWA. Bob | |||||||||||||||||||
| Similar Threads | Posted |
| Packet Capture | November 15, 2006, 7:39 am |
| Packet retransmits and bad check sum on ethereal capture | March 9, 2006, 9:02 am |
| %PIX-4-402106: Rec'd packet not an IPSEC packet. | August 25, 2006, 4:06 pm |
| PIX 6.3 - capture command | August 14, 2005, 3:53 pm |
| capture question pix 6.3 | March 19, 2007, 6:56 am |
| Frame Relay Capture? | August 4, 2005, 2:03 pm |
| PIX capture pppoe traffic | August 30, 2006, 5:10 am |
| Capture Text Plain in Cisco AS5300 | November 16, 2005, 2:30 pm |
| capture content of ipsec traffic on the engress interface | August 4, 2008, 3:00 pm |
| packet of disconnect | August 7, 2005, 10:52 pm |
| Packet fragmentation | April 25, 2006, 3:07 pm |
| pix 7.21 packet-tracer | July 7, 2006, 6:53 am |
| Packet fragmentation | July 27, 2006, 3:28 pm |
| debug ip packet | September 1, 2006, 7:56 pm |
| Packet grabs | April 9, 2007, 9:46 am |
Packet Capture
Yahoo!
Windows Live
del.icio.us
digg
Netscape
