Bookmark this page:
Yahoo!
Windows Live
del.icio.us
digg
Netscape
Posted by Jeff Pratt on July 13, 2005, 9:24 pm
Far end is a 3Com ISDN U lanmodem. It is configured for dialin and multilink. Near end is a C2610 with a 2ct1 network module. config: Current configuration : 1725 bytes ! version 12.1 service timestamps debug uptime service timestamps log uptime no service password-encryption ! hostname filet-rtr ! enable secret 5 ************************ enable password ************* ! ! ! ! ! ip subnet-zero no ip finger ! isdn switch-type primary-ni ! ! controller T1 1/0 framing esf linecode b8zs pri-group timeslots 1-10,24 ! controller T1 1/1 ! ! interface Ethernet0/0 ip address 192.9.200.249 255.255.255.0 no ip mroute-cache no cdp enable ! interface Serial1/0:23 no ip address encapsulation ppp no ip route-cache dialer pool-member 1 isdn switch-type primary-ni isdn calling-number 7807023021 no cdp enable ppp multilink multilink max-links 2 ! interface Dialer1 ip unnumbered Ethernet0/0 encapsulation ppp shutdown dialer pool 1 dialer remote-name agent1289 dialer rotor best dialer idle-timeout 20 dialer string 7804089168 dialer string 7804089169 dialer hold-queue 10 dialer load-threshold 3 outbound dialer-group 1 no fair-queue no cdp enable ppp authentication pap callin ppp chap refuse ppp pap sent-username iq-rtr password 7 ******************** ppp multilink bap ppp bap call accept ppp bap callback accept ppp bap timeout pending 20 ppp bap max dialers 2 multilink max-links 2 ! ip classless ip route 10.10.5.0 255.255.255.0 10.10.5.1 ip route 10.10.5.1 255.255.255.255 Dialer1 no ip http server ! access-list 101 permit ip 192.9.200.0 0.0.0.255 10.10.5.0 0.0.0.255 dialer-list 1 protocol ip list 101 no cdp run ! line con 0 transport input none line aux 0 line vty 0 4 password ********** login ! end Debugs are: filet-rtr#sh deb Dial on demand: Dial on demand events debugging is on PPP: Multilink events debugging is on BAP: BAP general debugging is on BAP negotiation debugging is on BAP error debugging is on ISDN: ISDN Q931 packets debugging is on ISDN Q931 packets debug DSLs. (On/Off/No DSL:1/0/-) DSL 0 --> 31
1 - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - -
Call come up fine, on one B channel: 2d00h: Di1 DDR: Call connected, 1 packets unqueued, 1 transmitted, 0 discarded 2d00h: %LINEPROTO-5-UPDOWN: Line protocol on Interface Serial1/0:9, changed state to up 2d00h: Di1 BAP: Group "0030.1e3f.0ad7" (10) (multilink) with precedence created 2d00h: 0030.1e3f.0ad7 MLP: Established BAP group 10 on Di1, physical Se1/0:9 When I try to add a channel to the bundle, however: 2d00h: Di1 BAP: Received CallbackReq, id 24, len 13 2d00h: 0030.1e3f.0ad7 BAP: I CallbackReq [Idle] id 24 len 17 2d00h: 0030.1e3f.0ad7 BAP: LinkType 64 kbps type isdn (0x0105004001) 2d00h: 0030.1e3f.0ad7 BAP: PhoneDelta 2d00h: 0030.1e3f.0ad7 BAP: UniqueDigits 1 (0x010301) 2d00h: 0030.1e3f.0ad7 BAP: SubscriberNumber 9 (0x020339) 2d00h: 0030.1e3f.0ad7 BAP: I CallbackReq, id 24 2d00h: Se1/0:23 DDR: has 10 ongoing call(s), maximum allowed call(s) 10 on pool 1, exceeded max 2d00h: DDR: rotor dialout [best] least recent failure is also most recent failure 2d00h: DDR: rotor dialout [best] also has most recent failure 2d00h: BAP: bap_link_is_free passed NULL idb 2d00h: DDR: rotor dialout [best] 2d00h: 0030.1e3f.0ad7 BAP: O NAK for CallbackReq, id 24 2d00h: 0030.1e3f.0ad7 BAP: Sending CallbackRsp, id 24, len 55 on Di1 to remote 2d00h: 0030.1e3f.0ad7 BAP: O CallbackRsp [Idle] id 24 len 51 NAK 2d00h: 0030.1e3f.0ad7 BAP: LinkType 64 kbps type isdn (0x0105004001) 2d00h: 0030.1e3f.0ad7 BAP: Reason No links of specified type(s) available 2d00h: 0030.1e3f.0ad7 BAP: (0x04294E6F206C696E6B73206F66207370) 2d00h: 0030.1e3f.0ad7 BAP: (0x65636966696564207479706528732920) 2d00h: 0030.1e3f.0ad7 BAP: (0x617661696C61626C65) Which would seem to indicate I am out of B channels on my PRI. But... show isdn service gives me: filet-rtr#sh is se PRI Channel Statistics: ISDN Se1/0:23, Channel [1-24] Configured Isdn Interface (dsl) 0 Channel State (0=Idle 1=Proposed 2=Busy 3=Reserved 4=Restart 5=Maint_Pend) Channel : 1 2 3 4 5 6 7 8 9 0 1 2 3 4 5 6 7 8 9 0 1 2 3 4 State : 0 0 0 0 0 0 0 0 0 2 3 3 3 3 3 3 3 3 3 3 3 3 3 3 Service State (0=Inservice 1=Maint 2=Outofservice) Channel : 1 2 3 4 5 6 7 8 9 0 1 2 3 4 5 6 7 8 9 0 1 2 3 4 State : 0 0 0 0 0 0 0 0 0 0 2 2 2 2 2 2 2 2 2 2 2 2 2 2 I'm stumped. Can anyone out there help? Jeff | |||||||||||||
Posted by Tosh on July 14, 2005, 6:39 am
Please log in for more thread options > Which would seem to indicate I am out of B channels on my PRI. But...
> show > isdn service gives me: > > filet-rtr#sh is se > PRI Channel Statistics: > ISDN Se1/0:23, Channel [1-24] > Configured Isdn Interface (dsl) 0 > Channel State (0=Idle 1=Proposed 2=Busy 3=Reserved 4=Restart > 5=Maint_Pend) > Channel : 1 2 3 4 5 6 7 8 9 0 1 2 3 4 5 6 7 8 9 0 1 2 3 4 > State : 0 0 0 0 0 0 0 0 0 2 3 3 3 3 3 3 3 3 3 3 3 3 3 3 > Service State (0=Inservice 1=Maint 2=Outofservice) > Channel : 1 2 3 4 5 6 7 8 9 0 1 2 3 4 5 6 7 8 9 0 1 2 3 4 > State : 0 0 0 0 0 0 0 0 0 0 2 2 2 2 2 2 2 2 2 2 2 2 2 2 > > I'm stumped. Can anyone out there help? > Maybe the last channels are configured by the carrier for receiving calls only, try to revert the order the router picks a b channel issueing the following command at the serial interface: isdn bchan-number-order ascending Bye, Tosh. | |||||||||||||
Posted by Jeff Pratt on July 14, 2005, 6:02 am
Tosh wrote: >> Which would seem to indicate I am out of B channels on my PRI. But...
>> show >> isdn service gives me: >> >> filet-rtr#sh is se >> PRI Channel Statistics: >> ISDN Se1/0:23, Channel [1-24] >> Configured Isdn Interface (dsl) 0 >> Channel State (0=Idle 1=Proposed 2=Busy 3=Reserved 4=Restart >> 5=Maint_Pend) >> Channel : 1 2 3 4 5 6 7 8 9 0 1 2 3 4 5 6 7 8 9 0 1 2 3 4 >> State : 0 0 0 0 0 0 0 0 0 2 3 3 3 3 3 3 3 3 3 3 3 3 3 3 >> Service State (0=Inservice 1=Maint 2=Outofservice) >> Channel : 1 2 3 4 5 6 7 8 9 0 1 2 3 4 5 6 7 8 9 0 1 2 3 4 >> State : 0 0 0 0 0 0 0 0 0 0 2 2 2 2 2 2 2 2 2 2 2 2 2 2 >> >> I'm stumped. Can anyone out there help? >> >
> Maybe the last channels are configured by the carrier for receiving calls > only, try to revert the order the router picks a b channel issueing the > following command at the serial interface: > isdn bchan-number-order ascending > Bye, > Tosh. Thanks.. I tried it though, and no joy. All channels are configured for inbound and outbound. Thanks, Jeff | |||||||||||||
| Similar Threads | Posted |
| PRI to BRI multilink failure. | July 13, 2005, 9:24 pm |
| Re: Dynamic NAT Failure | September 1, 2006, 9:53 am |
| Dynamic NAT Failure | August 28, 2006, 11:54 am |
| ASA failover failure | February 13, 2007, 6:37 am |
| MIB Discovery Failure | October 2, 2007, 2:08 pm |
| 1811 failure | October 29, 2009, 9:40 am |
| Multilink ppp | November 22, 2005, 3:44 pm |
| 2621XM - np ip inspect causes failure | December 13, 2005, 10:36 am |
| Pix 515 does not recover from, Power Failure | July 24, 2006, 12:28 pm |
| Temporary failure on T.38 fax calls | February 7, 2007, 5:48 am |
| VPN 3005 to IAS authentication failure... | March 5, 2007, 2:15 pm |
| VPN 3005 to IAS authentication failure... | March 5, 2007, 2:16 pm |
| Failure after switch warms up | July 19, 2007, 7:56 pm |
| RDP thru Cisco VPN client and thru 501 Failure | August 5, 2008, 3:52 pm |
| Wired dot1x failure | April 30, 2009, 4:22 am |
Yahoo!
Windows Live
del.icio.us
digg
Netscape
