Cisco Systems PPP LFI over L2TPv3
Subject Author Date
PPP LFI over L2TPv3 Mudropolk 11-02-06
Posted by Mudropolk on November 2, 2006, 8:09 am
Hi all,
PPP LFI (link fragmentaion and interleaving) over L2TPv3 - is it
possible? Could anybody implement this with Cisco routers?
The problem is the following. We have a central office with Cisco3660
and some remote offices with, say, Cisco 871s. The remote offices are
connected to the central one through the provider's network, which has
a mixed nature - somewhere FR, somewhere Wi-Fi, somewhere plain
ethernet. Traditionally I used GRE-tunnels (encrypted with IPSEC) to
pass the traffic between the offices. This worked and keeps working
now.
But then, the following idea to improve VoIP quaulity in this VPN has
appeared. What if I replace GRE-tunnels with L2TPv3 ones, pass PPP over
L2TPv3, and the cut the traffic to the small pieces using multilink PPP
interleaving and fragmentation.
I have made the working model on my LAN and everything seemed to work.
But it only seemed, unfortunately. Pings walked through the tunnel, but
the other traffic (HTTP etc) could not. After more detailed
investigation it became clear that IP-packets bigger than the PPP
fragment could not pass the tunnel. Probably the fragments could not be
reassembled on the tunnel's far end. When I tried to turn interleaving
off, all began to work. But I don't need the tunnel without
interleaving - I would better use plain old GRE in this case.
So the question is: what is wrong? Have not Cisco routers learned to
pass fragmented PPP over L2TPv3 pseudwires yet or is there something
wrong with my hands? If anybody managed to implement this schema, I
could show my configs for more detailed investigation.
Thanks in advance.
Similar ThreadsPosted
PPP LFI over L2TPv3 November 2, 2006, 8:09 am
L2TPv3 tunnel and SSS June 20, 2008, 9:25 am
L2TPv3 and vlans June 20, 2008, 12:02 pm
Need help with setting up L2TPv3 June 25, 2008, 11:30 am
L2TPv3 - one-way tunnel? July 1, 2008, 4:42 pm
L2TPv3 support on 3640 May 21, 2008, 6:08 pm
Question on L2TPv3 authentication June 18, 2008, 12:00 pm
Re: 3845 and l2tpv3 pseudowire problem May 12, 2008, 9:19 am
