Cisco Systems PIX 515E 7.01 static route in the same interface
Subject Author Date
PIX 515E 7.01 static route in the same interface opsvlc 05-16-06
Posted by on May 16, 2006, 11:20 am
Hope anyone can help me with this little problem:
I've got a pix 515e with 7.01 release. I made a static route pointing
to the inside interface; so im pinging a host and then ive got a static
route returning to the same interface. For example; my ip addresss is
10.10.80.113/16 trying to ping x.x.x.x. in my PIX (10.10.50.1/16 in the
inside interface) ive got a static route like this:
route inside x.x.x.x. 255.255.255.255 10.10.60.200/16
I think this wasnt possible with a release prior to 7.
what im doing wrong?
thank you
Posted by Lutz Donnerhacke on May 16, 2006, 11:25 am
It is still not possible with 7.x. With 7.x you can route between different
interfaces of the same security level and between VPN clients on the same
interface. You still can't use the pix as an router on the stick. You have
to use vlans at least.
Posted by on May 16, 2006, 11:58 am
thanks! gonna play with vlans :)
Similar ThreadsPosted
PIX 515E 7.01 static route in the same interface May 16, 2006, 11:20 am
Need to route SMTP traffic through static interface (not default route) March 27, 2007, 5:19 pm
static route, next hop vs interface question. January 15, 2006, 6:17 pm
Virtual Tunnel Interface Flapping - Route Redistribution: static->RIP->OSPF July 12, 2007, 2:44 pm
What is the default precedence: local-route, static-route, OSPF-route? August 4, 2008, 3:00 am
Can netwrok run static route and dynamic route the same time? December 1, 2005, 1:18 pm
question for static route -- default route April 1, 2009, 12:03 am
question for static route -- default route April 1, 2009, 12:04 am
PIX 515E and static NAT June 9, 2006, 9:51 am
Static PAT overrides Dynamic Pat - Pix 515e January 11, 2006, 1:38 pm
Re: PIX 515E, VPN client has no route to outside network via vpn June 12, 2005, 8:43 pm
PIX 515e - Static NAT with multiple public subnets October 26, 2005, 10:37 am
Static Route that won't go away September 8, 2006, 11:18 am
Which is better - static route or NAT? September 26, 2006, 3:30 am
PIX 506 static route October 11, 2006, 6:19 pm
Residential Cabling Guide
Home Cabling Guide
Finally, an instantly downloadable book that saves you thousands in home improvement dollars! Enjoy living in 21st century technology-advanced home while increasing its selling value and competitive advantage on the real estate market. Whether your cabling is for home office or high-tech leisure, you can wire your home yourself or learn "wirish" to speak with your cabling contractors in their language!
Learn More
