Cisco Systems PA-MC-T3 vs. External MUX on 7206VXR
Subject Author Date
PA-MC-T3 vs. External MUX on 7206VXR trbodsl 07-27-06
Posted by on July 27, 2006, 9:37 am
Hi All,
I'm at a point where we are looking at getting a DS3 to aggregate most
of our 31 T1 circuits on to. The telco is giving us a whole slew of
reasons why this is a good move, and I tend to agree with them.
Here's my predicament:
When we first built this network back in 2K3/4, facilities were not
available for a DS3 near our building. The build out of this would have
cost about $60-80K and pushed back the implementation about 12 weeks.
At that time, getting a DS3 was not practical. Now, our new account rep
wants to put the DS3 in to our building at no cost, except for the
loop. Seems as thogh facilities are now available and they are anxious
to get away from maintaining all the copper in the building.
As of right now, I have a 7206 with 4 of the octal T1 cards
(PA-MC-8TE1) in the chassis. The telco originally wanted to sell us an
Adtran mux to channelize the DS3 and give us 28 T1 ports that I would
have to put back into our router as T1. I spoke with their Cisco
engineer and asked him to investigate the options of plugging the DS3
directly into the 7206VXR. They came back with the PA-MC-T3 card, at a
cost of around $10K.
I'd much rather perfer putting the DS3 card into the 7206 and bypassing
the mux altogether, but I think it's going to be a hard sell to my boss
to say that I'm going to see $6K worth of benefit from the DS3 card.
This will be my first experience with DS3. I know there is additional
diagnostic information you can get by having the DS3 card directly in
the router, as well as you eliminate the additional point of failure of
the mux.
If I can convince him, would it be better to obtain a PA-MC-T3 card off
of eBay? I can get two for at or less than the price of one new one. I
know the lower end Cisco stuff is counterfeited quite a bit, but I
don't know much about the modules, etc.. for the higher end chassis.
Thanks,
Don
Posted by Hans on July 27, 2006, 10:24 am
When I worked at a very big ISP we used the PA-MC-E3 which could handle 16 * E1.
This was really interesting since our Telco delivered an E3 directly to our
premises and they configured the customers E1's on
these channels.
They muxed the E1's into the E3's. Either via a Nortel TN1X or via the Alcatel
Daccs.
I assume for the PA-MC-T3 it will work the same. You maybe also want to consider
the channelized STM1/OC3 PA which is probably
way too expensive.
We used these cards as well without problems. Only think you might want to
consider: what happens if the E3/DS3 circuit goes
down or if the Card breaks. You will loose all T1's at once which can be
painfull.
On the other hand: they will bring in fiber to your building (I assume) which is
much better and probably (dual-feed) more
redundant than just copper.
Hans
Posted by Doug McIntyre on July 27, 2006, 3:24 pm
trbodsl@gmail.com writes:
Only 12 weeks? Thats overly optimistic for telco buildouts.
They probably don't care about the copper for 31 T1s. More likely is
that they spent some money to get a SONET mux into the building, and
now they want to have something on it to justify it :)
The Adtran M13 MUX's are pretty reliable, but having all the T1s terminate
right on the chassis is even much more so. The PA-MC-T3 card is pretty nice.
>the mux.
Well, the MUX probably won't fail so much, especially if you get
redundant controllers and redudant power supplies. But You can have
cabling failures. Yes, you can do alot of testing off the PA-MC-T3
card, you can do latchup remote loops, and do bert tests right from
the router chassis. One less device to monitor for circuit failures.
(Not related to if you go for an external M13 MUX or the MUX right on
the cisco interface card), when the telco sees you have your T1s ride
the higher facilities in, its saves on them having to troubleshoot two
sides of a failed circuit, cuts down repair time quite a bit if they
only have to investigate one end for problems.
I wouldn't think that you could counterfeit a PC-MC-T3, there's custom
ASICs on it. The low-end stuff can be, because its just FPGAs with an
external EEPROM.
Similar ThreadsPosted
PA-MC-T3 vs. External MUX on 7206VXR July 27, 2006, 9:37 am
Setting IPs for PA-2FE-TX and IO/2FE in a 7206VXR October 7, 2005, 1:59 pm
Cisco 7206VXR January 9, 2007, 3:20 am
Hardware compression on 7206VXR March 4, 2007, 1:19 pm
Problems with 7206vxr-npe400 August 10, 2007, 10:40 am
PIX VPN using external addresses September 6, 2005, 8:33 pm
Howto hit an external ip with VPN September 27, 2005, 4:11 pm
PIX 515 Switch 8 External IPs October 24, 2005, 3:37 pm
Map external IP as internal IP? November 3, 2005, 11:08 am
PIX with two external Netowrks January 20, 2006, 9:22 am
On internal IP to many external IPs August 22, 2006, 6:03 am
external vlan March 19, 2007, 6:02 pm
two external ip addresses March 8, 2008, 12:42 pm
Multiple external IPs on SOHO97 November 10, 2005, 6:29 am
Allow all traffic from one external IP inside February 14, 2006, 2:42 pm
Residential Cabling Guide
Home Cabling Guide
Finally, an instantly downloadable book that saves you thousands in home improvement dollars! Enjoy living in 21st century technology-advanced home while increasing its selling value and competitive advantage on the real estate market. Whether your cabling is for home office or high-tech leisure, you can wire your home yourself or learn "wirish" to speak with your cabling contractors in their language!
Learn More
