Bookmark this page:
Yahoo!
Windows Live
del.icio.us
digg
Netscape
Posted by aservin on July 14, 2005, 2:06 am
We have an issue between a Catalyst Switch and a 3Com Switch. Everithing seem fine, the users and network speed are ok, but we start seeing "oversize packets" in the 3Com. The oversize counter in the 3Com switch that connects to the Catalyst is growing. We change the 3Com and the Cisco (originally was a 4503 and then we change it to a 2950) with the same results. The 3Com is 3300XM. The port is a 802.1q trunk with 3 vlans (default and 2 more). Any ideas, -as | ||||||||||||||||
Posted by roahboah on July 14, 2005, 10:02 am
Please log in for more thread options It's possible that there's a compromised machine on that segment sending the oversize packets to cause a SYN-ACK response from the target. Since you've changed out both pieces of equipment, it might be time to look at what's attached to said pieces of equipment. best of luck! russ | ||||||||||||||||
Posted by aservin on July 15, 2005, 4:04 am
I did the experiment in our Lab, just a couple of PCs. After generating some traffic between PCs, the errors appeared. It was between a 3Com 3300XM and a Catalyst 2950. We checked other connections of other 3Coms 3300XM to other gear (Enterasys) are the errors was there too. It seems that 3Com have issues with these boxes. I hate them any way. -as | ||||||||||||||||
| Similar Threads | Posted |
| Oversize packets | July 14, 2005, 2:06 am |
| PIX 515 doesn't route packets | July 19, 2005, 5:58 pm |
| PIX: How are packets travelling through it? | July 29, 2005, 10:46 pm |
| debug packets on PIX with 7.0 | October 11, 2005, 12:19 am |
| Can't receive VPN packets | December 7, 2005, 11:33 am |
| UDP Packets dropping | December 22, 2005, 4:50 pm |
| Dropped packets via ISR | August 23, 2006, 9:46 am |
| Millions of packets | November 18, 2005, 7:00 am |
| Sending RST packets | December 8, 2006, 4:13 pm |
| dropped packets | February 15, 2007, 5:11 am |
| PIX packets get NATed which shouldn't | August 27, 2008, 6:39 am |
| Dropping packets | November 18, 2008, 11:08 pm |
| Flagging packets as low priority | November 3, 2005, 11:00 am |
| Pix 525 running 7.1(1) dropping packets | April 26, 2006, 5:09 pm |
Oversize packets
Yahoo!
Windows Live
del.icio.us
digg
Netscape
