Bookmark this page:
Yahoo!
Windows Live
del.icio.us
digg
Netscape
Posted by Marko Uusitalo on May 7, 2008, 7:18 am
Please log in for more thread options Do You know if there is a client for 64-bit Vista that could make a IPSEC VPN to a old PIX runnix sw 6.35 Best regards Marko Uusitalo | |||||||||||||||||||||||||
Posted by DC on May 7, 2008, 9:59 am
Please log in for more thread options You could use the built in L2TP client in Vista. With the appropriate configuration the PIX will support it. | |||||||||||||||||||||||||
Posted by Scott Townsend on May 7, 2008, 1:25 pm
Please log in for more thread options I think on our 64-bit machine we ran a Virtual Machine on it and used the v5
Client. > Hi!
> Do You know if there is a client for 64-bit Vista that could make a IPSEC > VPN to a old PIX runnix sw 6.35 > > Best regards > > Marko Uusitalo | |||||||||||||||||||||||||
Posted by Doug McIntyre on May 8, 2008, 12:43 am
Please log in for more thread options >Do You know if there is a client for 64-bit Vista that could make a
>IPSEC VPN to a old PIX runnix sw 6.35 Cisco isn't making a 64-bit IPsec VPN client for any platform. They only support AnyConnect VPN on 64-bit Vista. (ie. SSL VPN supported on the ASA boxes). You can tunnel a wide range of ports through SSL VPN, but still... | |||||||||||||||||||||||||
Posted by MattFS218 on May 12, 2008, 5:08 pm
Please log in for more thread options > >Do You know if there is a client for 64-bit Vista that could make a
> >IPSECVPNto a old PIX runnix sw 6.35 >
> Cisco isn't making a 64-bit IPsecVPNclient for any platform. They > only support AnyConnectVPNon 64-bit Vista. (ie.SSLVPNsupported on > the ASA boxes). You can tunnel a wide range of ports throughSSLVPN, > but still... I believe AnyConnect VPN will try to first connect via IPsec and then attempt the connection via SSL if IPsec fails. However, as Doug pointed out, it does not work on a PIX VPN. Cisco announced End of Life for the PIX appliance last year...meaning it's time to fish out more $$ to upgrade your Cisco equipment. If you're interested, we've been using and have had a fabulous experience with an SSL VPN from NeoAccel. They are a startup so not many people have heard of them. http://www.neoaccel.com is their website. --matt | |||||||||||||||||||||||||
| Similar Threads | Posted |
| Old PIX 6.35 and Vista -64 bit ? | May 7, 2008, 7:18 am |
| Vista PPTP | February 11, 2007, 4:46 pm |
| Windows Vista | February 13, 2007, 2:03 pm |
| VPN client on vista | February 20, 2007, 3:35 am |
| Cisco VPN and Vista ??? | September 19, 2007, 11:54 pm |
| Cisco LEAP on Windows Vista | November 3, 2006, 7:08 pm |
| Re: Has any one found a Vista replacment for Hyperterminal?? | April 12, 2007, 6:24 pm |
| Has any one found a Vista replacment for Hyperterminal?? | April 12, 2007, 6:07 pm |
| ASA5510 and Vista 64bit with IPSec | November 25, 2008, 1:21 am |
| Nortel Contivity VPN client & Windows Vista | September 18, 2006, 10:11 am |
| Cisco Agent Desktop (CAD) - Unable to use Voice Monitor on Windows Vista | April 7, 2008, 12:30 pm |
| WE ARE BUYING SOFTWARE - WINDOWS VISTA, XP PRO, WIN2K PRO, HOME, 98SE, 98, 95, NT 4.0, OFFICE, SERVER INCLUDES MICROSOFT, DELL, COMPAQ, IBM, HP OR ANY OTHER OEM PACKAGES as well as Retail Box or just media kits. | June 9, 2007, 6:08 pm |
Yahoo!
Windows Live
del.icio.us
digg
Netscape
