Bookmark this page:
Yahoo!
Windows Live
del.icio.us
digg
Netscape
Posted by Christer Bergstrom on February 22, 2006, 10:33 am
I have been planning to move upwards in IOS versions an have been using Cisco Feature Navigator to establish the appropriate vesion for my needs. When examine versions: c837-k9o3sy6-mz.12.3-11.T with c837-k9o3sy6-mz.12.3-11.T3 there are no difference according to Feature Navigator. Is there some node in the Cisco abyss that I have missed to find, that have information regarding T and T3? best regards Christer Bergström | |||||||||||||
Posted by Merv on February 22, 2006, 11:50 am
Please log in for more thread options ( read junked) The numbers at the end are a finer granularity than the maintenace release number and usually provide no new features just bugs fixes So for example there are images 12.3(14)T2, T3, T4,T5 and T6 One usually wants to picked up the last image of a series like this as it will have the most bug fixes ( and sometimes some new ones ..) | |||||||||||||
Posted by Aaron Leonard on February 22, 2006, 6:20 pm
Please log in for more thread options Christer,
Comparing 12.3(11)T with 12.3(11)T3 ... the only difference is that the latter version (which is technically called a "throttle rebuild") contains some set of "important" bugfixes vs. the former. In general, if you wish to use some release branch 12.x(y)T, you should almost always select the last rebuild from that throttle - i.e. 12.x(y)T<n> where "n" is the highest value available. Right
now, for the 12.3(11)T throttle branch, 12.3(11)T10 is the latest
and presumably best rebuild. Regards, Aaron --- ~ dear Group ~ I have been planning to move upwards in IOS versions ~ an have been using Cisco Feature Navigator to establish ~ the appropriate vesion for my needs. ~ When examine versions: ~ c837-k9o3sy6-mz.12.3-11.T with ~ c837-k9o3sy6-mz.12.3-11.T3 there are no ~ difference according to Feature Navigator. ~ ~ Is there some node in the Cisco abyss ~ that I have missed to find, that have ~ information regarding T and T3? ~ ~ best regards ~ Christer Bergström | |||||||||||||
| Similar Threads | Posted |
| No difference between ....T and .....T3? | February 22, 2006, 10:33 am |
| Difference between PIX and ASA | May 29, 2006, 5:07 am |
| Difference in setting up ATM 0 or ATM 0.1 | February 8, 2005, 8:32 pm |
| Difference between PIX 501 and 800 series | July 9, 2005, 7:26 pm |
| Difference between SDM and SDM Express | July 18, 2007, 9:07 am |
| Difference between WICs and VWICs | July 6, 2006, 3:51 pm |
| Difference between 4500 and 4900. | August 21, 2006, 1:08 pm |
| routed port and SVI difference | March 30, 2007, 4:51 am |
| Difference - SUP2 vs. SUP32 | April 20, 2007, 1:54 am |
| difference between 3750 and 3750E | July 11, 2007, 1:24 pm |
| ASA IOS versions? Difference in Trains? | August 7, 2007, 1:25 pm |
| What is the difference between these two Cisco WAN Cards | October 31, 2007, 11:33 pm |
| What is the difference between a T1and an ISDN PRI | May 8, 2008, 9:45 pm |
| Difference between 4.1.7 and 4.7.2 - Cisco VPN 3005 | April 15, 2009, 11:34 pm |
| Difference Between Collision and Broadcast Domain. | September 21, 2005, 12:52 am |
Yahoo!
Windows Live
del.icio.us
digg
Netscape
