Cisco Systems Need sample code for Multilink1 setup with two isp
Subject Author Date
Need sample code for Multilink1 setup with two isp Marskarthik 02-22-07
Posted by Marskarthik on February 22, 2007, 10:19 am
I need a multilink1 sample code for Cisco 2610 router with two isp. I
need any working code from someone so that i can change and implement
according to my setup.
Note: my current setup has ppp encapsulation.
Thanks in advance,
Karthik(www.marskarthik.com)
Posted by Aaron Leonard on February 23, 2007, 4:26 pm
You don't use Multilink1 with two ISPs. You use Multilink1 with one ISP
and Multilink2 with the other.
Aaron
~ Hi,
~ I need a multilink1 sample code for Cisco 2610 router with two isp. I
~ need any working code from someone so that i can change and implement
~ according to my setup.
~ Note: my current setup has ppp encapsulation.
~ Thanks in advance,
~ Karthik(www.marskarthik.com)
Posted by Marskarthik on February 24, 2007, 8:12 pm
Yes you are correct its from same isp 2mbps on serial0 and 2mbps on
serial1. I need a code for this with two serial interface.
> Aaron
> ~ Hi,
Similar ThreadsPosted
Need sample code for Multilink1 setup with two isp February 22, 2007, 10:19 am
Sample BGP Config July 8, 2008, 7:25 pm
CCNA sample Q clarification January 10, 2007, 10:44 am
Sample config of Bonded T1 August 2, 2007, 9:42 am
req: sample config wic-1am-v2 modem card June 27, 2009, 6:24 pm
sample ccie/ccnp labs for dynamips June 25, 2007, 11:55 pm
CSUTIL.LOG : What those code means? August 19, 2005, 7:54 pm
Picking a stable Pix v7 code June 18, 2006, 3:07 pm
provide me Source code of IGMPv2 May 26, 2006, 2:36 am
I need code for nating in ppp multilink environment February 15, 2007, 10:10 am
Need code for enabling ping replies February 22, 2007, 1:34 pm
AddRoute failed to add a route: code 87 March 21, 2007, 9:58 am
I need Cisco Pix 506E code for the following items July 6, 2007, 4:32 am
AddRoute failed to add a route: code 87? May 2, 2008, 12:52 pm
SUNROCKET PROMOTION CODE SPECIAL LINK September 20, 2005, 1:39 pm
Residential Cabling Guide
Home Cabling Guide
Finally, an instantly downloadable book that saves you thousands in home improvement dollars! Enjoy living in 21st century technology-advanced home while increasing its selling value and competitive advantage on the real estate market. Whether your cabling is for home office or high-tech leisure, you can wire your home yourself or learn "wirish" to speak with your cabling contractors in their language!
Learn More
