Bookmark this page:
Yahoo!
Windows Live
del.icio.us
digg
Netscape
Posted by ash on September 4, 2006, 2:27 am
Our setup is like this : Our test setup is as below : 1) For the MLFR side, Port 5 of Adtech(.153) was connected to Tigris 0/Evros 0. 2) For the FR side, Port 4 of Adtech(.153) was connected to Tigris 1/Evros 1. Our Packet configuration : 1) IP over Frame Relay Traffic with channelised - DS3 configuration in the MLFR side with the following options set : DLCI = 16 Flags : C/R, FECN, DE with various combinations Control UI = 0x03 NLPID = 0xCC along with IP Packet Format in different modes set: 1) User Mode 2) IP editable Test Blocks. 2) But we are not getting that packet out from FR side. We thought of adding "fragmentation header" with the packet , we have not seen any option for adding this. Where can we get this option or any relevant information for the same in Adtech AX400. Thanks in advance. | |||||||||||||
Posted by www.BradReese.Com on September 4, 2006, 7:08 pm
Please log in for more thread options Compression: http://www.cisco.com/en/US/products/sw/iosswrel/ps1835/products_configuration_guide_chapter09186a0080080fdc.html#wp1002761 as well as Cisco's Configuring Real-Time Header Compression with Frame Relay Encapsulation: http://www.cisco.com/en/US/products/sw/iosswrel/ps1835/products_configuration_guide_chapter09186a0080080fdc.html#wp1002865 Cisco's TCP/IP Header Compression Examples: http://www.cisco.com/en/US/products/sw/iosswrel/ps1835/products_configuration_guide_chapter09186a0080080fdc.html#wp1003934 Finally, Cisco's Frame Relay Header Compression Compatibility Enhancements: http://www.cisco.com/en/US/products/sw/iosswrel/ps1834/products_feature_guide09186a0080080081.html Hope this helps. Brad Reese Cisco IOS Software - Compatible Partner Matrix by Technology http://www.BradReese.Com 1293 Hendersonville Road, Suite 17 Asheville, North Carolina USA 28803 USA & Canada: 877-549-2680 International: 828-277-7272 Fax: 775-254-3558 AIM: R2MGrant BradReese.Com - Global Cisco Systems Pre-Sales Support http://www.bradreese.com/contact-us.htm#CISCO | |||||||||||||
Posted by ash on September 5, 2006, 7:18 am
Please log in for more thread options Hi,
Thanks for the info. I am looking from adtech point of view. We need to send Ip over frame relay...for this when we select IP over frame relay, It shows the following option like frame header, payload ..etc. But we need to add fragmentation header as per FRF .12 . So we are not sure of adding this header ..from Adtech. Thanks, Asha www.BradReese.Com wrote: >
> as well as Cisco's Configuring Real-Time Header Compression with Frame > Relay Encapsulation: > > >
> Cisco's TCP/IP Header Compression Examples: > > >
> Finally, Cisco's Frame Relay Header Compression Compatibility > Enhancements: > > >
> Hope this helps. > > Brad Reese > Cisco IOS Software - Compatible Partner Matrix by Technology > http://www.BradReese.Com > 1293 Hendersonville Road, Suite 17 > Asheville, North Carolina USA 28803 > USA & Canada: 877-549-2680 > International: 828-277-7272 > Fax: 775-254-3558 > AIM: R2MGrant > BradReese.Com - Global Cisco Systems Pre-Sales Support > http://www.bradreese.com/contact-us.htm#CISCO | |||||||||||||
Posted by www.BradReese.Com on September 5, 2006, 11:48 am
Please log in for more thread options Hi Asha,
FRF.12 End-to-End Fragmentation http://www.cisco.com/en/US/tech/tk1077/technologies_tech_note09186a00800942e1.shtml#e2e Cisco's FRF.12 Support on Additional Platforms http://www.cisco.com/en/US/products/sw/iosswrel/ps1834/products_feature_guide09186a008008003f.html Cisco's FRF.12 Support on Switched Frame Relay PVCs http://www.cisco.com/en/US/products/sw/iosswrel/ps1834/products_feature_guide09186a0080080039.html Sincerely, Brad Reese Cisco Authorized Distributors Worldwide http://www.bradreese.com/cisco-distributors.htm | |||||||||||||
| Similar Threads | Posted |
| Need Info abt Frame relay fragmentation header | September 4, 2006, 2:27 am |
| Frame Relay fragmentation and interleaving | May 11, 2006, 4:42 pm |
| Frame-Relay and PPP Help | April 13, 2006, 5:02 pm |
| Frame Relay>>>>>Do we need a CSU/DSU? | March 27, 2007, 5:03 pm |
| Frame Relay Router | February 7, 2005, 2:18 pm |
| Frame-relay map and inverse-arp | February 10, 2005, 5:33 pm |
| Frame Relay Capture? | August 4, 2005, 2:03 pm |
| debug frame-relay lmi | October 25, 2005, 1:42 am |
| The use of HDLC in Frame relay? | February 3, 2007, 1:51 am |
| Frame Relay and DLCI | August 25, 2006, 12:06 am |
| Frame Relay Question | September 5, 2006, 4:37 pm |
| Frame relay configuration | September 10, 2006, 8:54 am |
| Multilink Frame-Relay | September 18, 2006, 4:43 pm |
| Help on BGP on Frame-relay network | October 8, 2006, 5:39 am |
| Little help with frame relay upgrade | December 27, 2006, 3:34 pm |
Yahoo!
Windows Live
del.icio.us
digg
Netscape
> Compression:
