Cisco Systems Need Cisco VPN advice for connecting two offices
Subject Author Date
Need Cisco VPN advice for connecting two offices Corbin O'Reilly 09-09-08
Posted by Corbin O'Reilly on September 9, 2008, 3:45 pm
Hello. I have a client that currently uses a Cisco VPN 3005 concentrator.
Remote employees use the Cisco VPN client to connect to the concentrator and
access servers on the company's LAN. They have been using this setup for
many years and it works great. My client has recently purchased another
company 3,000 miles away. This second company accesses the Internet via DSL
and does have a range of available public IPs. They currently have no remote
employees but that will soon change. My client would like to setup a VPN
solution at the second company that is similar to the parent company. They
will be adding remote employees and want those remote employees to be able
to VPN in just like the parent company's employees do. Also, in the near
future, they would like to do a site-to-site VPN between the two companies.
They have not bought Cisco VPN hardware in many years so my primary question
is what should they purchase for the second company. Like I said earlier
they want to accomplish two things:
1. Remote employees of the second company should be able to VPN in and
access servers on the second company's network.
2. The new Cisco VPN appliance in the second office will need to be linked
to the current Cisco 3005 VPN concentrator at the parent company.
Could someone please give me some advice on what Cisco appliance to purchase
in order to accomplish this? The second company will consist of about 20
employees and a few remote employees.
Thanks for the help.
Posted by Artie Lange on September 9, 2008, 3:55 pm
Corbin O'Reilly wrote:
Look at the Cisco ASA 55XX
Remote users would use an SSL VPN configuration, no client to install
just publish the login to the internet. Note there is a charge for the
SSL licenses, it comes with 2 out of the box.
Not a problem, the ASA is a mixture of the VPN concentrator and the PIX
firewall.
Posted by Corbin O'Reilly on September 9, 2008, 5:13 pm
Hey Artie. Will the Cisco ASA 55XX also support the traditional Cisco
Windows VPN client? The parent company has been using the Cisco Windows VPN
client for IPSEC connectivity for many years and it is rock solid. Just
wanted to make sure. Do you think the 5510 model would be sufficient for the
second company? Thanks.
> Remote users would use an SSL VPN configuration, no client to install just
> publish the login to the internet. Note there is a charge for the SSL
>> linked to the current Cisco 3005 VPN concentrator at the parent company.
> firewall.
Posted by Artie Lange on September 9, 2008, 5:15 pm
yes, it supports the past VPN clients as well.... I run the 5510 in alot
of client offices with well over 100 remote users. They may not connect
at the same time, but the hardware is capable. I am not sure what
performance you are looking for, but I would assume if anything, your
DSL line in your remote office would be your bottleneck before the ASA :)
Posted by Corbin O'Reilly on September 9, 2008, 7:05 pm
Thanks for the info Artie. One more question. Does the 5510 serve as both a
PIX and a VPN appliance? I am asking this because the parent company is
running a PIX 515 firewall and a VPN 3005 concentrator. If the second
company gets a 5510 the parent may want to get one as well. I just want to
know if the 5510 can replace both the PIX and VPN concentrator and the
parent company. Thanks again for the help.
>> VPN client for IPSEC connectivity for many years and it is rock solid.
>> Just wanted to make sure. Do you think the 5510 model would be sufficient
>> for the second company? Thanks.
> of client offices with well over 100 remote users. They may not connect at
> the same time, but the hardware is capable. I am not sure what performance
> you are looking for, but I would assume if anything, your DSL line in your
Similar ThreadsPosted
Need Cisco VPN advice for connecting two offices September 9, 2008, 3:45 pm
setting up multiple (20 +) offices using 1720s and one 3030 April 14, 2006, 5:09 pm
cisco advice May 21, 2006, 3:40 pm
Need help with 1721 routers to joing 2 offices via leased line May 23, 2006, 5:33 am
Re: Frame Relay -HQ-remote offices slow connection March 5, 2007, 4:25 am
Re: Frame Relay -HQ-remote offices slow connection March 5, 2007, 4:30 am
Re: Frame Relay -HQ-remote offices slow connection March 6, 2007, 12:43 am
Frame Relay -HQ-remote offices slow connection June 25, 2007, 5:55 am
Cisco 1721 ADSL configuration Advice December 8, 2006, 10:49 am
Cisco - Career Advice & CV Writing Service ! January 31, 2008, 4:04 am
Cisco 6509 w/ SUP2 - Netflow Expert Advice Needed December 19, 2007, 5:27 pm
Connecting two Cisco PIX 515 as per following Picture February 28, 2006, 10:40 pm
Problem Connecting 2 Cisco Switches together March 16, 2006, 4:43 pm
Error connecting using CISCO VPN Client 4.0.4(D) July 8, 2005, 8:19 am
Problems connecting with Cisco VPN client September 28, 2006, 2:54 pm
