Cisco Systems Native Vlan Cisco 1200 Access Point
Subject Author Date
Native Vlan Cisco 1200 Access Point jsallmann 03-11-06
Posted by on March 11, 2006, 7:50 pm
Hello again,
In the configuration guide for Cisco 1200 series access points, ver
12.3.7 on page 14-5 it states that "When you configure Vlans on access
points, the Native Vlan must be VLAN1." Is this correct? What if the
switch trunk port is Vlan 4 or something to that effect.
Thanks,
Posted by Merv on March 12, 2006, 6:50 am
It is doubtful that they made a special note in the prodcut
documentation if it is not the case.
Generally it is best to not use VLAN 1 at all or use it for mgmt
purposes only - telnet SNMP, etc.
There should be no need to change the native VLAN (VLAN 1), just add
the additional VLANs that you require for your setup.
int Fa0.1
encap dot1Q 1 native
exit
int Fa0.4
encap dot1Q 4
bridge-group 4
exit
int dot11radio 0
ssid WIRELESS
vlan 4
exit
int Dot11Radio 0.4
encap dot1Q 4
bridge-group 4
exit
Configure upstream switch accordingly.
Posted by madmax on March 12, 2006, 6:41 pm
OK<
But if the native VLAN is 1 on the access point then the native VLAN on
the switch for the trunk port must be VLAN1. This is what I'm
concerned about. Everyone states to stay away from VLAN1. Thanks for
your reply.
Posted by Aaron Leonard on March 12, 2006, 8:00 pm
Technically: AP IOS requires that it have exactly one IP
address, which must be configured on BVI1, which must
be in the (untagged) native VLAN.
You can call the native VLAN anything you want, vlan 1 or
vlan 47 ... what you call the native VLAN on the AP is
really private to the AP. EXCEPT that the AP will always
(if configured with dot1q encapsulation) send out its CDP
and Ethernet keepalives on VLAN 1 (whether or not you've
configured a VLAN 1)
... so it's best just to use native VLAN 1 and be done
with it.
Aaron
~ It is doubtful that they made a special note in the prodcut
~ documentation if it is not the case.
~ Generally it is best to not use VLAN 1 at all or use it for mgmt
~ purposes only - telnet SNMP, etc.
~ There should be no need to change the native VLAN (VLAN 1), just add
~ the additional VLANs that you require for your setup.
~ int Fa0.1
~ encap dot1Q 1 native
~ exit
~ int Fa0.4
~ encap dot1Q 4
~ bridge-group 4
~ exit
~ int dot11radio 0
~ ssid WIRELESS
~ vlan 4
~ exit
~ int Dot11Radio 0.4
~ encap dot1Q 4
~ bridge-group 4
~ exit
~ Configure upstream switch accordingly.
Similar ThreadsPosted
Native Vlan Cisco 1200 Access Point March 11, 2006, 7:50 pm
Cisco 1200 Access Point and Vlan Issue March 11, 2006, 1:26 pm
cisco 1200 access point and 350 bridge February 9, 2005, 8:34 am
Cisco Aironet 1200 Access point August 24, 2006, 3:33 am
cisco access point 1200 support February 8, 2007, 9:02 am
Re: Cisco 1300 series wireless access point/bridge Vs Linksys WAP54GPE Access Point Anyone know the basic pros & cons? November 28, 2007, 6:29 pm
Re: Cisco 1300 series wireless access point/bridge Vs Linksys WAP54GPE Access Point Anyone know the basic pros & cons? November 30, 2007, 4:03 pm
Re: Cisco 1300 series wireless access point/bridge Vs Linksys WAP54GPE Access Point Anyone know the basic pros & cons? December 2, 2007, 5:38 am
Changing native vlan on access port August 12, 2009, 6:53 pm
Native VLAN mismatch on Cisco 2950 August 9, 2007, 6:30 pm
Cisco 1200 AP and vlan tags/trunks September 30, 2005, 1:47 pm
cisco access point March 2, 2007, 5:16 am
Cisco 350 Access Point July 23, 2009, 11:50 am
Native, and management vlan "Vlan 1" September 21, 2005, 2:50 pm
VLAN Project and Native VLAN July 13, 2007, 5:06 am
Residential Cabling Guide
Home Cabling Guide
Finally, an instantly downloadable book that saves you thousands in home improvement dollars! Enjoy living in 21st century technology-advanced home while increasing its selling value and competitive advantage on the real estate market. Whether your cabling is for home office or high-tech leisure, you can wire your home yourself or learn "wirish" to speak with your cabling contractors in their language!
Learn More
