Cisco Systems Native VLAN mismatch on Cisco 2950
Subject Author Date
Native VLAN mismatch on Cisco 2950 bavien 08-09-07
Posted by on August 9, 2007, 6:30 pm
Little back ground:
Currently we have a Cisco 3750 and a couple of Cisco 2950 switches.
Only one VLAN on the whole network and that is the default VLAN 1 out
of the box. I want to create an additional VLAN for management so that
in the end there will be two VLANs, one for management and one for
user. My questions are:
1. Any benefit/reason in using VLAN 1 for management and create
another VLAN for users compare to using VLAN 1 for users and create
another VLAN for management?
2. I did some test and set all the ports in one of the 2950 to VLAN
10. Configure fa0/24 on the 2950 for trunking to Cisco 3750. Got
Native VLAN mismatch warning when issuing "show interface trunk" on
the 2950. Does this message indicates something is wrong or we can
have mismatch native vlan?
Thanks...
BV
Posted by Leander de Graaf on August 9, 2007, 7:19 pm
bavien@gmail.com wrote:
> Little back ground:
> Thanks...
> BV
If you are using dot1q as a trunking protocol (most common) you also
need to configure the same native VLAN on both ends of the trunk, as the
packets of that VLAN are send untagged. use interface config command
"switchport trunk native vlan vlan-nr" to change the specific VLAN on
one or both sides. This probably is the cause of the native VLAN
mismatch you are experiencing.
And yes, it can be a good practice to seperate management and users
VLANs, though its not a requirement.
Posted by Arthur Brain on August 10, 2007, 4:16 am
You can have it.
It just means that, on the trunk between them, your 3750 is treating
un-tagged frames as though they were VLAN 1, and your 2950 is treating
un-tagged frames as VLAN 10.
Basically a sign of poor design, but not *necessarily* of any problem.
Posted by Arthur Brain on August 10, 2007, 9:12 pm
> You can have it.
Actually, I was just playing with an old 3548 switch, patched to a
trunk port on a 3750 and the 3548 was actually disabling ports where a
VLAN mismatch was detected.
Posted by on August 10, 2007, 9:52 pm
> > You can have it.
> VLAN mismatch was detected.- Hide quoted text -
> - Show quoted text -
On the 2950 with all ports on VLAN10, I changed port 1 to access mode
1 (default VLAN), connect a PC to port 1 and found out that the PC
cannot see any devices on the 3750 switch (which all ports default to
VLAN1)
BV
Similar ThreadsPosted
Native VLAN mismatch on Cisco 2950 August 9, 2007, 6:30 pm
Native Vlan Mismatch error January 20, 2008, 2:09 am
Native Vlan Cisco 1200 Access Point March 11, 2006, 7:50 pm
Native, and management vlan "Vlan 1" September 21, 2005, 2:50 pm
VLAN Project and Native VLAN July 13, 2007, 5:06 am
Native VLAN February 8, 2007, 9:40 pm
native vlan December 18, 2008, 6:45 am
Native VLAN Warning August 23, 2005, 8:24 am
understanding native VLAN September 23, 2005, 10:10 pm
Native VLAN question November 22, 2005, 5:58 am
native vlan question April 15, 2008, 3:51 am
native vlan for mgmt July 18, 2009, 9:20 pm
Change native VLAN on ASA 5520 July 5, 2007, 6:17 am
change native vlan globaly on 3560 January 5, 2007, 2:08 pm
Changing native vlan on access port August 12, 2009, 6:53 pm
Residential Cabling Guide
Home Cabling Guide
Finally, an instantly downloadable book that saves you thousands in home improvement dollars! Enjoy living in 21st century technology-advanced home while increasing its selling value and competitive advantage on the real estate market. Whether your cabling is for home office or high-tech leisure, you can wire your home yourself or learn "wirish" to speak with your cabling contractors in their language!
Learn More
