Cisco Systems Making Sense of Cisco Spare Parts
Subject Author Date
Making Sense of Cisco Spare Parts Will 04-11-07
Posted by Will on April 11, 2007, 1:13 am
I'm trying to make sense of Cisco's part number system that uses an equal
(=) at the end of some part numbers, and it doesn't make a whole lot of
sense to me so far. Some of the cases that are throwing me for a loop:
- I have a catalog that has parts with = and no corresponding part without
the equal. Case in point: 15216-AD1-2-30.3= I see as a spare but cannot
locate in the catalog a 15216-AD1-2-30.3. What is the meaning of such
cases?
- I see cases where the = part has a lower price than the part without the
equal. Example: 15808-CMP and 15808-CMP=. 15808-CMP is more expensive
by far.
I understand the cases where the = part has a higher price, primarily for
service contracts (which makes sense), and for other items that are
discounted at time of purchase with a system.
Will
Posted by headsetadapter.com on April 11, 2007, 7:07 am
Will,
I think part numbers without "=" available only when you "build" the system.
For example, you build Catalyst 6513 with Sup720, line cards,etc. Or, for
example, if you order NetFlow cards for Catalyst 4500/Sup5 as "part of the
deal", or afterwards. These parts are "part of the package". however if you
want to "add" some auxiliary functionality or redundancy, you have to use
"spare" parts. It's like having Lego "set" and "spare" pieces. But honestly,
in most cases there is no difference in pricing, quality or availability
between "spare" and "non-spare" parts.
Good luck,
Mike
CCNP, CCDP, CCSP, Cisco Voice, MCSE W2K, MCSE+I, Security+, etc.
CCIE R&S (in progress), CCIE Voice (in progress)
Headset Adapters for Cisco IP Phones
www.ciscoheadsetadapter.com
www.headsetadapter.com
> cases?
> expensive by far.
> Will
Posted by on April 11, 2007, 7:15 am
> Will,
> Good luck,
> Mike
Phoneswww.ciscoheadsetadapter.comwww.headsetadapter.com
> > cases?
> > expensive by far.
When I worked for a Cisco Partner components ordered without the "="
were as has been said assumed to comprise an assembly and we checked
carefully that the components did indeed fit together and interoperate
and that the correct software was specified.
Parts ordered with "=" were on the other hand assumed to be discrete
and no shuch checks were made. IIRC the Cisco ordering system
did some automatic checking too.
There was never any price difference at all. That was though a while
back.
As an example an order for a 6513 chassis, PSU, sup720,
fan tray, software and 11 Dual fabric line cards would hopefully
be flagged up as invalid unless ordered with "=" part numbers.
Posted by Will on April 11, 2007, 6:07 pm
> system. For example, you build Catalyst 6513 with Sup720, line cards,etc.
> Or, for example, if you order NetFlow cards for Catalyst 4500/Sup5 as
> "part of the deal", or afterwards. These parts are "part of the package".
> however if you want to "add" some auxiliary functionality or redundancy,
> you have to use "spare" parts. It's like having Lego "set" and "spare"
> pieces. But honestly, in most cases there is no difference in pricing,
> quality or availability between "spare" and "non-spare" parts.
All clear, but I'm still trying to make sense of the special cases I found
such as:
>> without the equal. Case in point: 15216-AD1-2-30.3= I see as a spare
>> but cannot locate in the catalog a 15216-AD1-2-30.3. What is the
>> meaning of such cases?
>> the equal. Example: 15808-CMP and 15808-CMP=. 15808-CMP is more
>> expensive by far.
Will
Similar ThreadsPosted
Making Sense of Cisco Spare Parts April 11, 2007, 1:13 am
Cisco 804. Making it dumber March 27, 2006, 7:33 pm
Pricing of Cisco Spare Service April 5, 2007, 10:47 pm
Refurb cisco routers and parts in the Phils.? June 5, 2006, 8:22 am
Does the configuration my ISP provided make sense? If so, how should I configure my Cisco switches to properly utilize the Bridge being implemented with a connection to the internet at each building? January 14, 2007, 1:28 pm
PIX 515 Auto Sense October 5, 2005, 4:48 pm
Is this traffic shaping valid or make sense? December 29, 2005, 1:29 pm
Spare Fan April 11, 2006, 7:17 pm
What are the two parts of memory mean, please? May 16, 2007, 8:24 pm
Spare 1720 IOS file October 31, 2005, 10:30 pm
Making two ports perform like a hub June 29, 2008, 7:59 pm
www.yescell.com sell refurbish Sharp cellphone and parts January 9, 2009, 3:11 am
Need help making a VPN client connection within Windows 2000 Scheduled Task June 29, 2005, 12:18 pm
www.yescell.com sell refurbish Sony Ericsson cellphone and parts January 9, 2009, 3:09 am
ASA 5505 VPN making crazy. How to build single VPN on ATT dyn IP/static IP pool system November 21, 2007, 7:43 am
Residential Cabling Guide
Home Cabling Guide
Finally, an instantly downloadable book that saves you thousands in home improvement dollars! Enjoy living in 21st century technology-advanced home while increasing its selling value and competitive advantage on the real estate market. Whether your cabling is for home office or high-tech leisure, you can wire your home yourself or learn "wirish" to speak with your cabling contractors in their language!
Learn More
