Bookmark this page:
Yahoo!
Windows Live
del.icio.us
digg
Netscape
Posted by flamer die.spam@hotmail.com on August 5, 2008, 7:30 pm
Please log in for more thread options tree instance for it? I thought perhaps it was because it had no ethernet connections up but even when bringing an interface up I still get no stp instance. heres what I have done: vlan 123 name test interface GigabitEthernet0/13 description trunk port port-type nni switchport trunk allowed vlan 2-4094 switchport mode trunk udld port interface GigabitEthernet0/1 switchport access vlan 123 media-type rj45 speed 100 duplex full spanning-tree mode rapid-pvst spanning-tree extend system-id spanning-tree vlan 123 priority 0 switch#sh span vlan 50 Spanning tree instance(s) for vlan 50 does not exist. switch#sh vlan br VLAN Name Status Ports ---- -------------------------------- --------- ------------------------------- 1 default active Gi0/4, Gi0/5, Gi0/6, Gi0/7 Gi0/8, Gi0/9, Gi0/10, Gi0/11 Gi0/12, Gi0/13, Gi0/14, Gi0/15 Gi0/16 123 test active Gi0/1 1002 fddi-default act/unsup 1003 token-ring-default act/unsup 1004 fddinet-default act/unsup 1005 trnet-default act/unsup any ideas? I have tried shutting and no shutting the vlan etc but cant get spanning tree to work? Flamer. | ||||||||||||||||||||||
Posted by Brian V on August 5, 2008, 9:16 pm
Please log in for more thread options Uhm, because you created a VLAN 123 and are trying to look at VLAN 50 ? | ||||||||||||||||||||||
Posted by flamer die.spam@hotmail.com on August 5, 2008, 10:02 pm
Please log in for more thread options >
> > > > > When Im configuring this 12G switch and I add a vlan I get no spanning
> > tree instance for it? I thought perhaps it was because it had no > > ethernet connections up but even when bringing an interface up I still > > get no stp instance. >
> > vlan 123
> > name test >
> > description trunk port > > port-type nni > > switchport trunk allowed vlan 2-4094 > > switchport mode trunk > > udld port >
> > switchport access vlan 123 > > media-type rj45 > > speed 100 > > duplex full >
> > spanning-tree extend system-id > > spanning-tree vlan 123 priority 0 >
> > switch#sh vlan br
> > VLAN Name =A0 =A0 =A0 =A0 =A0 =A0 =A0 =A0 =A0 =A0 =A0 =A0 =A0 =A0 Statu=
s =A0 =A0Ports
ive =A0 =A0Gi0/4, Gi0/5, Gi0/6,
> > ------------------------------- > > 1 =A0 =A0default =A0 =A0 =A0 =A0 =A0 =A0 =A0 =A0 =A0 =A0 =A0 =A0 =A0act= > > Gi0/7
=A0 =A0 =A0 =A0 =A0 =A0Gi0/8, Gi0/9, Gi0/10,
> > =A0 =A0 =A0 =A0 =A0 =A0 =A0 =A0 =A0 =A0 =A0 =A0 =A0 =A0 =A0 =A0 =A0 =A0= > > Gi0/11
=A0 =A0 =A0 =A0 =A0 =A0Gi0/12, Gi0/13,
> > =A0 =A0 =A0 =A0 =A0 =A0 =A0 =A0 =A0 =A0 =A0 =A0 =A0 =A0 =A0 =A0 =A0 =A0= > > Gi0/14, Gi0/15
=A0 =A0 =A0 =A0 =A0 =A0Gi0/16
> > =A0 =A0 =A0 =A0 =A0 =A0 =A0 =A0 =A0 =A0 =A0 =A0 =A0 =A0 =A0 =A0 =A0 =A0= > > 123 test =A0 =A0 =A0 =A0 =A0 =A0 =A0 =A0 =A0 =A0 =A0 =A0 =A0 =A0 =A0 ac=
tive =A0 =A0Gi0/1
> > 1002 fddi-default =A0 =A0 =A0 =A0 =A0 =A0 =A0 =A0 =A0 =A0 act/unsup
> > 1003 token-ring-default =A0 =A0 =A0 =A0 =A0 =A0 =A0 act/unsup > > 1004 fddinet-default =A0 =A0 =A0 =A0 =A0 =A0 =A0 =A0 =A0act/unsup > > 1005 trnet-default =A0 =A0 =A0 =A0 =A0 =A0 =A0 =A0 =A0 =A0act/unsup >
> > get spanning tree to work? >
> > Flamer.
> Uhm, because you created a VLAN 123 and are trying to look at VLAN 50 ? ah sorry, i was looking at the right vlan, i had changed numbers around to not show anything sensitive (obviously didnt change all of them), but thank you for pointing that out it should read: switch#sh span vlan 123 >
Spanning tree instance(s) for vlan 123 does not exist.
My real question should really be, if i create a vlan while there are no active network connections on the switch is a stp instance created? | ||||||||||||||||||||||
Posted by flamer die.spam@hotmail.com on August 5, 2008, 11:10 pm
Please log in for more thread options On Aug 6, 11:30=A0am, "flamer die.s...@hotmail.com"
=A0 =A0Ports
> tree instance for it? I thought perhaps it was because it had no > ethernet connections up but even when bringing an interface up I still > get no stp instance. > > heres what I have done: > > vlan 123 > name test > > interface GigabitEthernet0/13 > =A0description trunk port > =A0port-type nni > =A0switchport trunk allowed vlan 2-4094 > =A0switchport mode trunk > =A0udld port > > interface GigabitEthernet0/1 > =A0switchport access vlan 123 > media-type rj45 > =A0speed 100 > =A0duplex full > > spanning-tree mode rapid-pvst > spanning-tree extend system-id > spanning-tree vlan 123 priority 0 > > switch#sh span vlan 50 > > Spanning tree instance(s) for vlan 50 does not exist. > > switch#sh vlan br > > VLAN Name =A0 =A0 =A0 =A0 =A0 =A0 =A0 =A0 =A0 =A0 =A0 =A0 =A0 =A0 Status = > ---- -------------------------------- ---------
> ------------------------------- > 1 =A0 =A0default =A0 =A0 =A0 =A0 =A0 =A0 =A0 =A0 =A0 =A0 =A0 =A0 =A0activ= > Gi0/7
=A0 =A0 =A0 =A0 =A0 =A0 Gi0/8, Gi0/9, Gi0/10,
> =A0 =A0 =A0 =A0 =A0 =A0 =A0 =A0 =A0 =A0 =A0 =A0 =A0 =A0 =A0 =A0 =A0 =A0 = > Gi0/11
=A0 =A0 =A0 =A0 =A0 =A0 Gi0/12, Gi0/13,
> =A0 =A0 =A0 =A0 =A0 =A0 =A0 =A0 =A0 =A0 =A0 =A0 =A0 =A0 =A0 =A0 =A0 =A0 = > Gi0/14, Gi0/15
=A0 =A0 =A0 =A0 =A0 =A0 Gi0/16
> =A0 =A0 =A0 =A0 =A0 =A0 =A0 =A0 =A0 =A0 =A0 =A0 =A0 =A0 =A0 =A0 =A0 =A0 = > 123 test =A0 =A0 =A0 =A0 =A0 =A0 =A0 =A0 =A0 =A0 =A0 =A0 =A0 =A0 =A0 acti=
ve =A0 =A0Gi0/1
> 1003 token-ring-default =A0 =A0 =A0 =A0 =A0 =A0 =A0 act/unsup > 1004 fddinet-default =A0 =A0 =A0 =A0 =A0 =A0 =A0 =A0 =A0act/unsup > 1005 trnet-default =A0 =A0 =A0 =A0 =A0 =A0 =A0 =A0 =A0 =A0act/unsup > > any ideas? I have tried shutting and no shutting the vlan etc but cant > get spanning tree to work? > > Flamer. Ok I have figured it out, it allows you to tag one port as "nni" this port must be up/up for spanning tree to start its thing.. (I had set nni on an optical interface and was testing it by plugging the trunk into a copper interface) | ||||||||||||||||||||||
| Similar Threads | Posted |
| ME 3400 | August 5, 2008, 7:30 pm |
ME 3400
Yahoo!
Windows Live
del.icio.us
digg
Netscape
> vlan 123
> name test
> port-type nni
> udld port
> media-type rj45
> speed 100
> duplex full
> switch#sh vlan br
> Gi0/7
> Gi0/11
> Gi0/12, Gi0/13,
> Gi0/14, Gi0/15
> Gi0/16
> Flamer.
