Cisco Systems MDS9222i ISLs & VSANs question?
Subject Author Date
MDS9222i ISLs & VSANs question? Andrew Instone-Cowie 09-07-08
Posted by Andrew Instone-Cowie on September 7, 2008, 6:58 am
Question on configuring ISLs between a pair of Cisco MDS 9222i switches
with VSANs:
I want to have an ISL (actually an FCIP link) between 2 VSANs, 1 each on
a pair of Cisco MDS 9222i switches. I do not want the ISL to link any
other VSANs on the switches
Switch1 Switch2
VSAN 10 VSAN 11
VSAN 20 VSAN 21
VSAN 30 ---ISL/FCIP--- VSAN 30
If I put the ISL ports (which in this case will be a fcip port) into
VSAN 30 on each switch, is that sufficient to ensure that only those
VSANs are linked? Or do I leave the ISL in the default VSAN and use a
permitted VSAN list?
I have looked at the MDS documentation, but I couldn't find exactly what
I was looking for.
Thanks
Andrew
Posted by Doug McIntyre on September 7, 2008, 1:37 pm
>with VSANs:
>Switch1 Switch2
>VSAN 10 VSAN 11
>VSAN 20 VSAN 21
You'll want to use the trunk allowed list for what VSANs are permitted.
int fcip ...
switchport trunk allowed vsan 30
They copied how the catalyst ethernet switches work for alot of the
MDS line..
Posted by Andrew Instone-Cowie on September 7, 2008, 2:22 pm
>> with VSANs:
>> Switch1 Switch2
>> VSAN 10 VSAN 11
>> VSAN 20 VSAN 21
> int fcip ...
> MDS line..
Thanks. Do I need to put the interface in the VSAN as well? Or just
leave it default?
vsan database
vsan 30 interface fcip...
Andrew
Posted by Ralf Eberhardt on September 8, 2008, 2:42 am
Actually you can do both.
Either use the allowed vsan list - in that case you still have a trunk
sending frames with the EISL header for vsans that are in the allowed list.
Or turn off trunking and put the ISL in vsan 30 - in that case you will
have normal FC frames on the link without the EISL header carrying the
VSAN information.
You may want to consider the option of having VSAN 1 spanning the whole
fabric for management purposes (e.g. you could run IPFC across it and
use it as secondary inband route to switches). In that case I would put
the link in native VSAN 1 and turn on trunking with the allowed VSAN list.
Otherwise if you do not suspend VSAN 1 and don't have a VSAN 1 link
between your switches, you will have it show up as segmented in FM...
Hope it helps,
Ralf
>>> switches with VSANs:
>>> on a pair of Cisco MDS 9222i switches. I do not want the ISL to link
>>> any other VSANs on the switches
>>> Switch1 Switch2
>>> VSAN 10 VSAN 11
>>> VSAN 20 VSAN 21
>> int fcip ...
>> MDS line..
> leave it default?
> vsan database
> Andrew
Similar ThreadsPosted
MDS9222i ISLs & VSANs question? September 7, 2008, 6:58 am
MDS9222i Gigabit Ethernet ports - support 100MBit/s? September 15, 2008, 7:09 am
remote access vpn question (second try - sorry about that, question included this time.) April 2, 2007, 5:05 pm
pix question July 26, 2005, 7:53 pm
DNS question with VPN August 29, 2005, 12:18 am
CDP over 802.1q question August 31, 2005, 7:50 pm
pix nat question November 23, 2005, 3:46 pm
PIX 501 - question October 4, 2005, 4:53 pm
BGP question - need help !!! October 24, 2005, 7:44 am
NAT Question please help December 20, 2005, 4:25 am
BGP question December 30, 2005, 12:21 am
VPN Question Pix 501 January 11, 2006, 3:07 am
Another ACL question January 31, 2006, 10:30 pm
VTP question February 1, 2006, 4:15 pm
