Cisco Systems MAC Address and Logical Router Interface
Subject Author Date
MAC Address and Logical Router Interface Graham Drabble 11-05-08
Posted by Graham Drabble on November 5, 2008, 5:59 pm
Do all the logical interfaces on a physical Ether interface have the
same MAC address? If not how is the MAC address for eahc logical
interface defined?
Thanks,
Graham Drabble
http://www.drabble.me.uk/
Posted by bod43 on November 5, 2008, 9:21 pm
Well, why don't you configure it and have a look?
I suppose you are asking a theoretical question?
Usually it will not matter of they are the same. The different
VLANs do not usually end up being connected so no
conflict occurs.
It is of course possible that some requirement
might result in the vlans being connected by a
cable somewhere in the network. This could
result in communication failures.
One related thing is that by default Sun workstations
use the same MAC address for all of the interfaces
in the device. This usually works OK since the
different interfaces are not usually in the same
broadcast domain.
Posted by Graham Drabble on November 6, 2008, 12:26 am
3517-4f71-b24c-a86290484222@a3g2000prm.googlegroups.com:
Because I don't have any CISCO kit available at the moment. I take it
from the rest of your answer the short answer is Yes.
Yes. I have a piece of equipment that has 2 physical ports with
addresses in different subnets. They share a MAC but any broadcast
traffic (STP, ARP etc) are always sent out of both ports. I'm trying
to find out how other equipment handles having 2 IP with 1 MAC handle
this, only thing I could think of was logical interfaces.
Thanks.
Graham Drabble
Posted by Stephen on November 7, 2008, 4:07 pm
On Wed, 05 Nov 2008 22:59:35 GMT, Graham Drabble
it depends :)
the hardware can support different MAC addresses on the same interface
(at least since the 25xx routers).
this used to be common - DECnet forced the MAC address to include the
L3 address, XNS forced all ports to the same MAC and so on.
Different MACs are used with HSRP / VRRP by the current "owner" of a
shared gateway address, for different groups and for the native
address.
i think if you have multiple IP addresses on a port, it will use the
same MAC - but it is so long since i tried i dont remember.
on cisco switches each vlan interfaces gets a separate MAC, so you
will different MACs per IP interface in each VLAN on a trunked
interface.
Regards
stephen_hope@xyzworld.com - replace xyz with ntl
Similar ThreadsPosted
MAC Address and Logical Router Interface November 5, 2008, 5:59 pm
PIX515 - VPN on logical interface June 21, 2006, 1:09 pm
What are logical lines on a Cisco router? May 10, 2006, 6:41 pm
Changing the MAc address to VLAN interface or how to SPLIT a router in 2. December 2, 2006, 10:19 am
Differnce between setting mac address port security under the interface vs. the mac address-table global command February 1, 2010, 2:16 pm
need to lookup master interface that inherit IP address to unnumbered interface via SNMP October 30, 2007, 8:30 am
Need help!! Interface answer to public address but not to private address July 13, 2006, 7:30 am
Setting up a router with 29 Global IPs, BUT can't ping router internal interface from server or server interface from router December 11, 2005, 10:37 am
pix 506 logical port support March 17, 2006, 7:11 pm
Confusion regarding logical vs. physical drawings July 18, 2005, 8:20 am
How to convert a fast ethernet interface in a Cisco Router to behave like a serial interface March 18, 2006, 8:48 am
Interface name vs interface IP address March 22, 2010, 7:12 pm
Secondary IP address on PIX ethernet interface April 25, 2006, 12:55 pm
GRE, importance of IP address for tunnel interface September 1, 2006, 11:48 am
ip address dhcp setroute February 8, 2007, 5:10 pm
Latest PostsForumRSS
NEWS: Samsung takes on the Apple iPad with the 7 inch Galaxy... Wireless Networking
c3560 port configuration Cisco Systems
Broadband 2010: A Big Slowdown [telecom] General Telecommunications Forum
Control Hot Water Circ Pump With X10? General Home Automation
Official Course CCNP TSHOOT 642-832 / Foundation Learning Gu... Cisco Certification
Speedflow Communications Honored for Innovation Voice-Over-IP
USB _to_ RJ45 (not from) connection Ethernet LAN
FAQ: Maximizing cable modem or DSL speed Cable Modems
CASH FOR CISCO - I BUY USED AND NEW EQUIPMENT & LOTS MOR... Telecom Technical
FAQ: Maximizing cable modem or DSL speed Digital Subscriber Line
How to set up Meridian 1 to "provide clock" to a C... Nortel Networks
New Discovery about WDM LAN and Telecom Cabling
Control Hot Water Circ Pump With X10? Home Automation
Text file to automate restoring a dropped VPN connection. Virtual Private Networks
Home Theater Installation Home Theater
Re: The Turkic Languages in a Nutshell Fiber Optics
sip Video Conferencing
Residential Cabling Guide Home Cabling Guide
Finally, an instantly downloadable book that saves you thousands in home improvement dollars! Enjoy living in 21st century technology-advanced home while increasing its selling value and competitive advantage on the real estate market. Whether your cabling is for home office or high-tech leisure, you can wire your home yourself or learn "wirish" to speak with your cabling contractors in their language!
Click Here to learn more
