Bookmark this page:
Yahoo!
Windows Live
del.icio.us
digg
Netscape
Posted by rick on July 7, 2005, 5:26 pm
Please log in for more thread options 100FX Ethernet. All of the buildings collapse to a central hub and is a flat layer 2 network. I'm would like to segment each building with a VLAN/subnet using some used Layer 3 Cisco switches. I'm not sure if any of the 2900xl or 3512xl switches can perform inter-VLAN routing. I will have each building collapse to a layer 2 core and performing the routing on the layer 3 switches for cost purposes (can't afford a 6513!!). If anyone can recommend an older model Cisco switch or router that can perform routing + 100FX and if affordable enough 1000Base SX I would appreciate it. Thank you, -Rick | ||||||||||||||||
Posted by BradReeseCom on July 7, 2005, 7:28 pm
Please log in for more thread options You may want to investigate the Cisco Refurbished Product Guide ( goes all the way back to 1999 ): http://www.bradreese.com/refurbished-cisco-product-guide.htm Hope this helps. Brad Reese BradReese.Com Cisco Repair Worldwide 1293 Hendersonville Road, Suite 17 Asheville, North Carolina USA 28803 Toll Free: 877-549-2680 International: 828-277-7272 Website: http://www.bradreese.com/cisco-big-iron-repair.htm | ||||||||||||||||
Posted by rick on July 8, 2005, 12:09 am
Please log in for more thread options Thanks Brad, I'll check that out. I have setup a 3COM network in the
past with Corebuilder 3500s performing the routing collapsed to a Corebuilder 9000 Layer 2 Core. From what I can see the Cisco product comparable to the 3COM Corebuilder 3500 series is a Catalyst 5505? | ||||||||||||||||
| Similar Threads | Posted |
| layer 3 switch STP | February 5, 2007, 2:17 am |
| Layer 3 switch | September 10, 2007, 7:45 am |
| Look for cheap/used Layer 3 Switch | July 7, 2005, 5:26 pm |
| Layer 3 switch model? | March 30, 2007, 1:24 pm |
| Layer 3 switch or Router | October 8, 2007, 5:08 am |
| Layer 3 switch-function | March 9, 2008, 8:58 am |
| LAYER 3 SWITCH BCMSN EXAM | December 11, 2006, 9:35 pm |
| VLAN interfaces on Layer 2 switch | July 15, 2007, 1:04 pm |
| qos on cisco 3560 layer 3 switch | September 11, 2007, 6:53 pm |
| MTU less than 1500 bytes on Cisco layer 3 switch | October 25, 2005, 7:18 am |
| cisco 3560 layer 3 switch question | October 29, 2007, 10:14 am |
| Expandin Subnet on Cisco 3550 Layer 3 Switch | March 23, 2006, 4:31 pm |
| FS/FA: $160 & works great - Extreme Networks Summit48 Switch w/basic layer 3 33923 | August 9, 2005, 10:33 am |
| 2960 (layer 2) vs 3560 (layer 3) ...considerations? | September 15, 2006, 9:22 am |
| Layer 1 / Layer 2 Difference | August 17, 2006, 10:00 pm |
Yahoo!
Windows Live
del.icio.us
digg
Netscape
