Cisco Systems Logging issue in CiscoSecure ACS 4.2
Subject Author Date
Logging issue in CiscoSecure ACS 4.2 Daniel Alex 05-05-08
Posted by Daniel Alex on May 5, 2008, 4:08 am
Hi All,
Good day everyone, I have a problem with ACS's logging and I hope anyone who
had similar experience could help me on this issues.
We have two ACS on our network (primary & secondary). All our dial-up
customer are authenticated on primary ACS and the secondary ACS is only
serves as a backup ONLY when the primary ACS is fail or out of service. User
databases and groups including certain security & network configurations are
replicated to secondary ACS on daily basis (every 24 hours). The logging for
configuration for each ACS reports (Failed Attempts, Passed Authentication,
RADIUS Accounting and etc) are also configured to daily basis. So far, the
operational status for both are fine but I found out the logging files on
secondary ACS has an extra ACS report which ends with "(HH-MM-SS).csv", for
example, RADIUS Accounting 2008-05-02(00-00-33).csv. This happens whenever
the secondary ACS are in replication mode and receives updates from primary
ACS after every 24 hours.
In a day, the secondary ACS generates two identical ACS reports, with and
without '(HH-MM-SS)'. Example ACS reports generated by secondary ACS;
RADIUS Accounting 2008-05-02.csv
It only happens on secondary ACS but not in primary ACS, although in my
understanding, whenever ACS in replication mode, all ACS services will be
temporarily suspended and return to operational once the replication mode is
completed. Our billing software is customized only to process those normal
ACS reports (logs) but not those ends with "(HH-MM-SS).csv" and we have to
manually extrack the content and merge it with the current reports. We did
not having this problem in our previous ACS version 3.2 until we had
upgraded our service recently.
Question: How do I overcome this issue? Any workaround?
Thank you very much!
Regards,
Daniel
Posted by Thrill5 on May 5, 2008, 11:41 pm
Disable log replication, and configure the primary to also log to the
secondary. When done this way, as each message is logged, it is
immediately sent to the secondary server, and both logs are always up to
date. Don't remember how to do this off the top of my head and if you don't
find where to set this up, post a reply.
> Hi All,
> who had similar experience could help me on this issues.
> User databases and groups including certain security & network
> configurations are replicated to secondary ACS on daily basis (every 24
> hours). The logging for configuration for each ACS reports (Failed
> Attempts, Passed Authentication, RADIUS Accounting and etc) are also
> configured to daily basis. So far, the operational status for both are
> fine but I found out the logging files on secondary ACS has an extra ACS
> report which ends with "(HH-MM-SS).csv", for example, RADIUS Accounting
> 2008-05-02(00-00-33).csv. This happens whenever the secondary ACS are in
> replication mode and receives updates from primary ACS after every 24
> hours.
> is completed. Our billing software is customized only to process those
> normal ACS reports (logs) but not those ends with "(HH-MM-SS).csv" and we
> have to manually extrack the content and merge it with the current
> reports. We did not having this problem in our previous ACS version 3.2
> until we had upgraded our service recently.
> Regards,
> Daniel
Posted by Daniel Alex on May 6, 2008, 6:18 am
I still need the log replication. However, I want to know how to prevent the
secondary ACS to produce similar log files (as shown below) after performing
replication.
It always happened whenever the primary ACS performed replication towards
secondary ACS. I wonder, after the replication complete on secondary ACS,
why it needs to create a new log instead of using the current log at that
day.
Thanks.
> don't find where to set this up, post a reply.
>> Hi All,
>> hours.
>> Regards,
>> Daniel
Posted by Thrill5 on May 6, 2008, 8:16 pm
You can't prevent this from happening when you replicate the log FILES, but
you can when you configure the primary also log to the secondary.
> Hi,
> the secondary ACS to produce similar log files (as shown below) after
> performing replication.
> day.
> Thanks.
>>> Hi All,
>>> hours.
>>> and without '(HH-MM-SS)'. Example ACS reports generated by secondary
>>> ACS;
>>> be temporarily suspended and return to operational once the replication
>>> mode is completed. Our billing software is customized only to process
>>> those normal ACS reports (logs) but not those ends with "(HH-MM-SS).csv"
>>> and we have to manually extrack the content and merge it with the
>>> current reports. We did not having this problem in our previous ACS
>>> version 3.2 until we had upgraded our service recently.
>>> Regards,
>>> Daniel
Posted by Daniel Alex on May 6, 2008, 10:07 pm
Okay. I will test it. Thanks.
> but you can when you configure the primary also log to the secondary.
>> Hi,
>> day.
>> Thanks.
>>>> Hi All,
>>>> anyone who had similar experience could help me on this issues.
>>>> ACS report which ends with "(HH-MM-SS).csv", for example, RADIUS
>>>> Accounting 2008-05-02(00-00-33).csv. This happens whenever the
>>>> ACS;
>>>> "(HH-MM-SS).csv" and we have to manually extrack the content and merge
>>>> it with the current reports. We did not having this problem in our
>>>> previous ACS version 3.2 until we had upgraded our service recently.
>>>> Regards,
>>>> Daniel
Similar ThreadsPosted
Logging issue in CiscoSecure ACS 4.2 May 5, 2008, 4:08 am
CiscoWorks and CiscoSecure ACS January 24, 2006, 2:33 am
MAC authentication on Linksys switches with CiscoSecure ACS 4.2 May 8, 2008, 6:32 am
CiscoSecure ACS v. 3.3 user TACACS+ password choice defaults not LDAP April 18, 2007, 2:22 pm
logging buffered vs. logging history February 5, 2006, 8:57 am
logging w/ PIX / ASA January 4, 2006, 11:43 am
VPN logging April 6, 2006, 7:58 am
logging PIX August 15, 2006, 10:20 am
PIX Logging October 19, 2006, 11:40 pm
logging October 25, 2006, 12:21 pm
IOS-VPN and logging October 11, 2007, 6:29 am
Remotely logging in September 16, 2005, 4:38 pm
remotely logging in September 16, 2005, 6:53 pm
logging to syslog ? October 12, 2005, 12:07 pm
PIX not logging IDS to syslog December 21, 2005, 12:52 am
