Cisco Systems Load balance between two parallel paths
Subject Author Date
Load balance between two parallel paths kazdan 06-21-06
Posted by on June 21, 2006, 6:26 am
hey guys, i have a topology which looks thusly:
Router
Router
both paths are tunnels, I would like to load balance between these two
cisco 3550 catalysts with ip routing enabled, so that not only will it
load balance but it will do so intelligently, it will distribute
packets according to load on bandwidth and so on. I am aware that i
could use variance to allow a worse connection to help in load balance
but i would prefer if the load were balanced so that the proportions
are calculated and possibly dynamic. Is this possible and if so what
are the commands necessary?
Posted by PepeRdguez on June 21, 2006, 1:52 pm
kazdan@gmail.com ha escrito:
> Router
> Router
Did you visit this site?
http://www.cisco.com/en/US/tech/tk365/technologies_tech_note09186a0080094820.shtml
Be aware about routers process load in case you chose the best traffic
balance, which is on packet basis.
Good luck
Similar ThreadsPosted
Load balance between two parallel paths June 21, 2006, 6:26 am
Load Balancing / Load Sharing over parallel paths November 21, 2005, 9:14 am
Load Balance and High Availability. July 19, 2005, 9:16 pm
port-channel load-balance May 29, 2006, 12:10 pm
Load Balance with Cisco ISR 1801 December 5, 2007, 5:45 pm
Load Balance 2 FRAME RELAY CIRCUITS July 5, 2005, 10:02 am
[Cisco ISR 1800] Load Balance over two xDSL November 20, 2007, 6:11 pm
1812w Load Balance two internet connections October 27, 2008, 9:53 am
Max Clients, Load Balance on Aironet 1231? I have 200 PDA's! August 23, 2007, 1:18 pm
Cisco CSS load balance weighted round-robin perl script February 13, 2007, 9:30 pm
Is it possible to load balance between MPLS router/network and DIA router? April 21, 2008, 3:30 am
VPN client disables my LPT1 parallel printer port April 20, 2007, 2:12 pm
WAN Connection using 2 Paths, one for up one for Down? April 2, 2007, 3:59 pm
Equal cost paths from separate OSPF Processes March 3, 2006, 4:47 am
