Cisco Systems Load Balancing of Two WAN private IPs
Subject Author Date
Load Balancing of Two WAN private IPs DumbHead 11-15-05
Posted by DumbHead on November 15, 2005, 12:53 am
I don't know if the subject is set right or no!
here is what I have and what I intend to do!
I have a simple office which has 20 comps and they all have to use
internet to and only plain simple internet no VPNs or any carp of that
sort.
Now here is what I am doing right now I have one ISP cable and that
comes on one computer which use ICS to distribute the internet to the
other pcs.
Everything is fine everything works great but the catch is that my isp
has a download limit..after which it charges on per mb basis. Well
thats normal but I am a poor man...Ok now ... the solution I am using
.. I got another ISP.. so when one ISP limit is done I use the other
one..
here is the example
isp A -- gives 150mb download free per day --so if the speed of 256kbps
is used the entire quota is downloaded within 2 1/2 hrs.
isp B-gives unlimited download free per day BUT the max speed is only
96kbps.
My requirement is to merge both isps into one isp A 150mb on 64kbps
will work for 10 hrs and isp B unlimited download will be there for the
entire day and I will get a speed of 96+64 kbps == that is roughly good
as 256kbps.
Now both of the isps use the private ips at my end 10.0.*.* and
192.168.*.* and I don't have a public ip.
I am looking for a cheap solution ... platform win XP
Please advice..
Posted by Rod Dorman on November 15, 2005, 1:08 pm
Sorry but my newsreader must have deleted the text where you described
what Cisco gear you're using.
                                        -- Rod --
rodd(at)polylogics(dot)com
Posted by DumbHead on November 15, 2005, 1:31 pm
Thank you for your reply.
I do not have any cisco router as of now.
I am open to all kind of solutions Cisco preferred.
Thanks and Regards
Similar ThreadsPosted
Load Balancing of Two WAN private IPs November 15, 2005, 12:53 am
Load Balancing / Load Sharing over parallel paths November 21, 2005, 9:14 am
Load Balancing February 15, 2005, 6:13 pm
load-balancing t1s August 30, 2005, 2:54 pm
Load Balancing February 20, 2006, 11:33 am
OER and load balancing March 2, 2006, 10:06 am
load balancing January 3, 2007, 8:35 pm
load-balancing t1s February 16, 2007, 1:43 pm
To QoS or load-balancing or both July 21, 2008, 5:35 pm
Load Balancing NxSTM1s August 23, 2005, 10:36 pm
RV042 and pix with load balancing October 12, 2005, 9:01 am
Load Balancing 2 Routes October 17, 2005, 8:08 am
Re: BGP and load balancing two routers October 17, 2005, 10:48 am
Re: BGP And Load Balancing With Two Routers October 17, 2005, 1:27 pm
Load balancing between T1 and ADSL December 4, 2005, 2:09 pm
