Cisco Systems Load Balancing / Load Sharing over parallel paths
Subject Author Date
Load Balancing / Load Sharing over parallel paths ciscortp 11-21-05
Posted by on November 21, 2005, 9:14 am
I have two parallel paths between a pair of routers.   They are running
Eigrp between them.  The bandwidths are very close to each other (704K
and 768K) so Eigrp Unequal cost load balancing doesn't really help me
because the traffic share count is usually 1 to 1.
I could get around this by altering the delay of one of the links and
then maybe have a trafic share count of 2 to 1.
I've tried per packet load balancing but because of the varying
latencies in each link, that doesn't work out too well for me.
What I would like to do is have a way of preferring the faster (less
latency) link until the bandwidth reaches a certain point, then
allowing the slower (greater latency) link to kick in.
The reason being is that sometimes 1 user will download a huge file
which will consume the entire bandwidth of 1 one link.   Other users
will try to connect and because of typical per session or per
destination load balancing, they will attempt to also use the congested
link.   I would like to avoid this.     I want a way to set a threshold
for a particular link by % utilization,  then put that link on hold
until the % util drops below a certain point.
If anyone sees what I mean here and has a solution, that would be
greatly appreciated.
Thank You
Posted by Vincent C Jones on November 21, 2005, 10:57 am
If the problem is a single FTP transfer, it sounds like weighted
fair queueing (WFQ) is not doing its thing. Could be because WFQ
has been disabled (or something about the configuration disables
it by default), or you may need to add traffic shaping on the links
to give WFQ a chance to kick in before the link is totally clogged.
Good luck and have fun!
Vincent C Jones, Consultant           Expert advice and a helping hand
Networking Unlimited, Inc.            for those who want to manage and
Tenafly, NJ  Phone: 201 568-7810      control their networking destiny
http://www.networkingunlimited.com
Similar ThreadsPosted
Load Balancing / Load Sharing over parallel paths November 21, 2005, 9:14 am
Load balance between two parallel paths June 21, 2006, 6:26 am
BGP Load Sharing November 30, 2005, 10:27 am
BGP load-sharing September 16, 2006, 11:37 pm
BGP Load Sharing August 19, 2010, 3:48 pm
solution for load sharing ? August 17, 2005, 12:03 pm
PBR for load sharing purposes October 30, 2005, 7:30 pm
NAT Overload and load sharing March 25, 2007, 3:03 pm
Traffic Load sharing March 25, 2007, 7:19 pm
Using Netflow and per packet load-sharing October 25, 2005, 7:04 am
BGP load sharing with 2 default gateways November 29, 2005, 10:04 pm
BGP load sharing with 2 default gateways November 29, 2005, 10:07 pm
Load sharing between full T1 and fractional T1 January 9, 2006, 2:58 pm
Circuit group for load-sharing February 20, 2006, 11:15 am
ospf load sharing ASA to Router March 28, 2007, 10:17 pm
Latest PostsForumRSS
NEWS: Samsung takes on the Apple iPad with the 7 inch Galaxy... Wireless Networking
c3560 port configuration Cisco Systems
Broadband 2010: A Big Slowdown [telecom] General Telecommunications Forum
Control Hot Water Circ Pump With X10? General Home Automation
Official Course CCNP TSHOOT 642-832 / Foundation Learning Gu... Cisco Certification
Speedflow Communications Honored for Innovation Voice-Over-IP
USB _to_ RJ45 (not from) connection Ethernet LAN
FAQ: Maximizing cable modem or DSL speed Cable Modems
CASH FOR CISCO - I BUY USED AND NEW EQUIPMENT & LOTS MOR... Telecom Technical
FAQ: Maximizing cable modem or DSL speed Digital Subscriber Line
How to set up Meridian 1 to "provide clock" to a C... Nortel Networks
New Discovery about WDM LAN and Telecom Cabling
Control Hot Water Circ Pump With X10? Home Automation
Text file to automate restoring a dropped VPN connection. Virtual Private Networks
Home Theater Installation Home Theater
Re: The Turkic Languages in a Nutshell Fiber Optics
sip Video Conferencing
Residential Cabling Guide Home Cabling Guide
Finally, an instantly downloadable book that saves you thousands in home improvement dollars! Enjoy living in 21st century technology-advanced home while increasing its selling value and competitive advantage on the real estate market. Whether your cabling is for home office or high-tech leisure, you can wire your home yourself or learn "wirish" to speak with your cabling contractors in their language!
Click Here to learn more
