Bookmark this page:
Yahoo!
Windows Live
del.icio.us
digg
Netscape
Posted by bvlmv on July 5, 2005, 10:02 am
Please log in for more thread options Can anybody shine light on load balancing 2 FR circuit going from cisco to cisco both with 2 serials wics. I was reading a couple of posts and MLPPP seems to be out of the question. Thanks, | |||||||||||||||||||
Posted by Tomasz Paszkowski on July 5, 2005, 11:27 am
Please log in for more thread options per-packet load balancing is also a good solution. TP | |||||||||||||||||||
Posted by Ivan Ostres on July 5, 2005, 3:39 pm
Please log in for more thread options apisa?(a):
>=20
> > Hi,
> > Can anybody shine light on load balancing 2 FR circuit going from cisco > > to cisco both with 2 serials wics. I was reading a couple of posts and > > MLPPP seems to be out of the question.=20 > > Thanks, >=20
> per-packet load balancing is also a good solution. >=20 If I may add, per-packet or per-destination load balancing could be much=20 better than MLPPP specially if you have limited bandwidth since MLPPP=20 adds significant overhead and some other problems which might or migh=20 not be related to your envirnoment. --=20 Ivan *** User rot13 to see my eMail address *** | |||||||||||||||||||
Posted by Jonathan on July 6, 2005, 12:00 am
> Hi,
> Can anybody shine light on load balancing 2 FR circuit going from cisco > to cisco both with 2 serials wics. I was reading a couple of posts and > MLPPP seems to be out of the question. > Thanks, > Call your provider and ask about MLFR. Think "IMA for the cheapo in all of us" Jonathan | |||||||||||||||||||
Posted by bvlmv on July 13, 2005, 6:45 pm
I work for the provider. My temp problem was that our atm switches only have frame to atm, but I tried circuit emulation to atm and I was able to get across the cisco's with ppp interfaces. Could you send me info/link on per-packet load balacing IMA was pretty much out of the question because IMA cards were not part of the project. Thanks for the reply. | |||||||||||||||||||
Load Balance 2 FRAME RELAY CIRCUITS
Yahoo!
Windows Live
del.icio.us
digg
Netscape
> Thanks,
