Cisco Systems Linksys WRT54G v2 and iBM T40 wireless access - need help
Subject Author Date
Linksys WRT54G v2 and iBM T40 wireless access - need help dar 12-03-05
Posted by dar on December 3, 2005, 1:03 pm
I have recently installed a linksys WRT54g v2 wireless router which
works fine with a hardwired PC to connect to the internet. I have
therefore updated the firmware to v4.20.7, Aug. 18, 2005.
i am trying to connect to the internet from my laptop (IBM T40 with
mini PCI wireless card 802.11b) i can see the router with a strong
connection in the netowrk connections window of XP. but when i hit the
connect button all i get a window showing a green ball pinging between
a pc and laptop. after awhile it returns me to the available networks
window with no error or comment message.
i have set the router to mixed to allow 802.11b and 802.11g
connections. Encryption on the router is set to WEP and on the laptop
i have tried both automatic key settings as well as the 10 hex digits
generated by the passkey in the router. in frustration i have also
tried to remove the encryption to see if that will allow me to connect.
the laptop is configured to work with an office wireless network hence
i am unable to re-install any software on the laptop.
i also enabled the incoming & outgoing logs - the incoming one is blank
(despite my numerous attempts to access the router from the laptop) the
outgoing has a number of entries.
Any help appreciated and TIA
dar dsa
Posted by dar on December 3, 2005, 8:03 pm
following a different posting that suggests use of WPA with AES. when
i hit connect on the laptop i get a prompt asking for the WPA key. i
enter the key and am back to the same situation where the laptop polls
the router but gets no connection.
this is really frustrating .....................
Posted by Steve Harris on December 4, 2005, 9:18 pm
just a start, have you disabled the existing Ethernet card? Or does it have
one?
Posted by Steve Harris on December 4, 2005, 9:19 pm
http://www.microsoft.com/technet/prodtechnol/winxppro/maintain/wifisoho.mspx
Posted by dar on December 5, 2005, 9:48 am
Steve
thanks for your suggestion. A colleague suggested i use a software
called Odyssey that is loaded on the laptop which is necessary for my
workplace wireless network. I need to add my home network to this
software in order to make connection.
Unfortunately Odyssey is an innocous icon that blends into the grey
background of the windows taskbar. i would never have noticed it
myself.
cheers and thanks again for yr help
dar
Similar ThreadsPosted
Linksys WRT54G v2 and iBM T40 wireless access - need help December 3, 2005, 1:03 pm
Internet to a 2611 through a Linksys WRT54G September 14, 2006, 6:55 pm
Re: Cisco 1300 series wireless access point/bridge Vs Linksys WAP54GPE Access Point Anyone know the basic pros & cons? November 28, 2007, 6:29 pm
Re: Cisco 1300 series wireless access point/bridge Vs Linksys WAP54GPE Access Point Anyone know the basic pros & cons? November 30, 2007, 4:03 pm
Re: Cisco 1300 series wireless access point/bridge Vs Linksys WAP54GPE Access Point Anyone know the basic pros & cons? December 2, 2007, 5:38 am
VPN between Cisco 837 and Linksys wireless router. February 14, 2005, 4:58 pm
Linksys Wireless-G Range Expander WRE54G September 14, 2006, 12:19 pm
Cisco 1121G AP and Linksys wireless clients October 10, 2006, 8:39 pm
Re: Linksys wireless-G notebook adapter pings Cisco web each second March 23, 2008, 11:17 pm
Re: Linksys wireless-G notebook adapter pings Cisco each second March 24, 2008, 1:57 am
Linksys WKUSB54GS cannot associate with access point problem September 10, 2005, 1:01 am
Linksys RV082 Problem: Can "login" but can't access web based utility June 28, 2006, 10:43 am
Wireless access opinions March 2, 2006, 1:30 pm
Belkin Wireless Network Access September 25, 2005, 1:50 am
Wireless Access Point Security January 16, 2007, 4:26 pm
