Cisco Systems Linksys GIG v's Cisco Gig
Subject Author Date
Linksys GIG v's Cisco Gig Gary 10-14-06
Posted by Gary on October 14, 2006, 2:01 pm
I can buy a linksys GIG Switch for about $400 while the same port density on
a Cisco costs $3000
If I do not need any of the bells and whistles like VLAN's/QoS etc. can I
assume the Linksys will perform at the same speeds and performance.
As Cisco have bought em I assume they were becoming a threat in some way.
G
Posted by Walter Roberson on October 14, 2006, 2:18 pm
>a Cisco costs $3000
No, that's not a good assumption at all; it would be false for most
inexpensive gigabit switches. And unfortunately it is often quite
difficult to find independant reviews that aren't just a rewriting
of the advertising brochure.
Someone did point out an inexpensive linksys to me recently, for which
I -was- able to find a positive independant review; it was the SD2008
(a design from a couple of years ago), and the review is at
http://soltesz.net/sd2008/part3.html
It's pretty good considering the price, but it does *not* get
gigabit at minimum packet size (which is what Cisco measures),
and the latency creeps up with packet size. The SD2008 is completely
unmanaged. I found a number of reviews that says that the fan on it
is quite noisy and that it runs hot; one review said it ran quiet and
cool, so it is possible they changed the fan design along the way.
Posted by Gary on October 14, 2006, 3:44 pm
>>on
>>a Cisco costs $3000
Trying to find reviews of the SR2024 and tech sheet but there is precious
little. Blurb says:
The 24-Port 10/100/1000 Gigabit Switch provides non-blocking, wire speed
switching
Price comarison is $400 v's $Loads for anything Gig from Cisco.
Gary
Posted by Walter Roberson on October 14, 2006, 9:04 pm
>little. Blurb says:
>switching
Consider the SRW2024 instead -- at least you'll get WebView so
you can do some remote configuration.
The SR2024 and SRW2024 both review as having a loud fan.
Real information... hard to find. There's some nuggets here,
http://www.newegg.com/Product/CustratingReview.asp?item=N82E16833124049
I found a mid-sized thread from someone using the SRW's who couldn't
get more than 300 Mbit/s throughput; no-one was able to come up
with anything that helped his particular situation (whatever the
actual cause was.) There was a useful resource in there,
http://www.enterprisenetworkingplanet.com/nethub/article.php/3485486
"Squeeze Your Gigabit NIC for Top Performance"
I skimmed over lots of other links, but the rest was just fluff or
ads or people asking whether anyone knew anything about them...
Similar ThreadsPosted
Linksys GIG v's Cisco Gig October 14, 2006, 2:01 pm
telnet through Linksys to Cisco April 11, 2006, 4:56 pm
cisco 7960 POE on linksys SRW 244 P August 2, 2006, 9:30 am
Cisco Pix 501 and Linksys router July 6, 2005, 4:34 pm
Linksys SFE2000P - not really a Cisco July 4, 2008, 5:44 pm
VPN between Cisco 837 and Linksys wireless router. February 14, 2005, 4:58 pm
Cisco 837 IPSEC Linksys WAG54g July 11, 2005, 5:37 pm
Linksys BEFVP41 to Cisco Pix 506E July 21, 2005, 7:50 am
Linksys Router < -- > Cisco PIX 506e September 22, 2005, 9:02 am
cisco CP-7920 with linksys AP on CCME September 22, 2006, 3:08 pm
Cisco PIX 515E and Linksys WRV 200 VPN Tunnel November 28, 2006, 4:09 am
Cisco VPN client and Linksys VPN compatibility? February 5, 2007, 11:41 pm
Which ports to forward on my linksys to cisco February 21, 2007, 12:32 pm
Cisco 2621 w/Firewall IOS and Linksys WRV54G March 16, 2006, 10:46 am
Cisco 1121G AP and Linksys wireless clients October 10, 2006, 8:39 pm
