Cisco Systems Layer 4 EtherChannel Load Balancing
Subject Author Date
Layer 4 EtherChannel Load Balancing Miguel Sanders 08-09-08
Posted by Nicolai on August 10, 2008, 6:37 am
> Well let me explain the background of this question:
> Server A (TSM client) needs to backup to Server B (TSM server) over
> Ethernet. Server A can have multiple TSM sessions to server B,
> resulting in multiple tape mounts. Furthermore each TSM session
> corresponds to one TCP session.
> Server A and Server B both have a layer 4 EtherChannel defined of 4
> interfaces in which the hashing is based on source and destination
> ports.
> So this means that, whenever Server A starts 2 TSM sessions to Server
> B (= 2 TCP sessions resulting in 2 tape mounts), the EtherChannel on
> server A will balance the load on two switchports (given the used
> hashing algorithm). Unfortunately, since my 3750E only allows layer 2
> and layer 3 EtherChannel load balancing, all load will be placed on
> the same physical port of server B's EtherChannel, only resulting in a
> maximum throughput of only 1 Gbit/s for server A. Ofcourse, whenever
> another server (f.e. server C) starts a TCP session with server B, it
> is likely (75% chance) that it will use another port of Server B's
> EtherChannel...
> Bottom line is that Server A will never get a bandwidth higher than 1
> Gbit/s no matter how many TCP sessions is starts with Server B.
> Do you understand the problem?
I do - and I currently have the same problem. I never get over 1Gbit. Will
keep an eye on this great post.
Similar ThreadsPosted
Layer 4 EtherChannel Load Balancing August 9, 2008, 8:21 am
EtherChannel Load Balancing - per packet? August 22, 2005, 5:41 am
Layer 3 Etherchannel Issue September 16, 2008, 10:27 am
Load Balancing / Load Sharing over parallel paths November 21, 2005, 9:14 am
Load Balancing February 15, 2005, 6:13 pm
load-balancing t1s August 30, 2005, 2:54 pm
Load Balancing February 20, 2006, 11:33 am
OER and load balancing March 2, 2006, 10:06 am
load balancing January 3, 2007, 8:35 pm
load-balancing t1s February 16, 2007, 1:43 pm
To QoS or load-balancing or both July 21, 2008, 5:35 pm
Load Balancing NxSTM1s August 23, 2005, 10:36 pm
RV042 and pix with load balancing October 12, 2005, 9:01 am
Load Balancing 2 Routes October 17, 2005, 8:08 am
Re: BGP and load balancing two routers October 17, 2005, 10:48 am
