Cisco Systems Layer 4 EtherChannel Load Balancing
Subject Author Date
Layer 4 EtherChannel Load Balancing Miguel Sanders 08-09-08
Posted by Miguel Sanders on August 9, 2008, 8:21 am
Hello all
I am currently using Cisco 3750E StackWise+ Switches. However, it
seems that this type of switch only supports layer 2 (MAC address -
src/dest/src and dest) and layer 3 (IP address- src/dest/src and dest)
hashing possibilities concerning EtherChannel load balancing. Is there
an (affordable compared to the 3750E) switch available which supports
layer 4 (TCP port - src/dest/src and dest) etherchannel load
balancing?
Thanks a lot!
Miguel
Posted by Brian V on August 9, 2008, 10:37 am
> Hello all
> balancing?
> Thanks a lot!
> Miguel
4500 series minimum. Thats certainly more expensive the the 3700 series.
http://www.cisco.com/en/US/tech/tk389/tk213/technologies_tech_note09186a0080094714.shtml
Is there a reason you specifically need layer 4? Only reason I really see is
for it is multiple services on a server that are max'ing out, i.e email and
web on a single server with email taking 100% of the bandwidth. If thats the
case, it's cheaper just to add more servers and break out the services on to
individual servers.
-Brian
Posted by Miguel Sanders on August 9, 2008, 11:24 am
> > Hello all
> > balancing?
> > Thanks a lot!
> > Miguel
series.http://www.cisco.com/en/US/tech/tk389/tk213/technologies_tech_note091...
> individual servers.
> -Brian
Well let me explain the background of this question:
Server A (TSM client) needs to backup to Server B (TSM server) over
Ethernet. Server A can have multiple TSM sessions to server B,
resulting in multiple tape mounts. Furthermore each TSM session
corresponds to one TCP session.
Server A and Server B both have a layer 4 EtherChannel defined of 4
interfaces in which the hashing is based on source and destination
ports.
So this means that, whenever Server A starts 2 TSM sessions to Server
B (= 2 TCP sessions resulting in 2 tape mounts), the EtherChannel on
server A will balance the load on two switchports (given the used
hashing algorithm). Unfortunately, since my 3750E only allows layer 2
and layer 3 EtherChannel load balancing, all load will be placed on
the same physical port of server B's EtherChannel, only resulting in a
maximum throughput of only 1 Gbit/s for server A. Ofcourse, whenever
another server (f.e. server C) starts a TCP session with server B, it
is likely (75% chance) that it will use another port of Server B's
EtherChannel...
Bottom line is that Server A will never get a bandwidth higher than 1
Gbit/s no matter how many TCP sessions is starts with Server B.
Do you understand the problem?
Thnx a lot!
Posted by Thrill5 on August 9, 2008, 7:22 pm
I don't know of any switch that supports the type of EtherChanneling you
need. How about installing 10Gb/s cards in the two servers and connecting
them back to back?
>> > Hello all
>> > balancing?
>> > Thanks a lot!
>> > Miguel
>> is
>> and
>> the
>> to
>> individual servers.
>> -Brian
> ports.
> EtherChannel...
> Thnx a lot!
Posted by Miguel Sanders on August 10, 2008, 6:30 am
> need. =A0How about installing 10Gb/s cards in the two servers and connect=
ing
> them back to back?
> >> > Hello all
> >> > src/dest/src and dest) and layer 3 (IP address- src/dest/src and des=
t)
> >> > hashing possibilities concerning EtherChannel load balancing. Is the=
re
> >> > an (affordable compared to the 3750E) switch available which support=
s
> >> > balancing?
> >> > Thanks a lot!
> >> > Miguel
> >> series.http://www.cisco.com/en/US/tech/tk389/tk213/technologies_tech_n=
ote091...
> >> Is there a reason you specifically need layer 4? Only reason I really =
see
> >> is
> >> for it is multiple services on a server that are max'ing out, i.e emai=
l
> >> and
> >> web on a single server with email taking 100% of the bandwidth. If tha=
ts
> >> the
> >> case, it's cheaper just to add more servers and break out the services=
on
> >> to
> >> individual servers.
> >> -Brian
> > ports.
> > B (=3D 2 TCP sessions resulting in 2 tape mounts), the EtherChannel on
> > EtherChannel...
> > Thnx a lot!- Tekst uit oorspronkelijk bericht niet weergeven -
> - Tekst uit oorspronkelijk bericht weergeven -
If I look at the 4500 series, it is capable of examining the TCP
traffic and do load balancing based on src/destination TCP ports.
However, as already stated, this is an expensive solution and I think
I will look after something else.
Unfortunatele, the 10 Gbps ports are already used for uplinks.
Similar ThreadsPosted
Layer 4 EtherChannel Load Balancing August 9, 2008, 8:21 am
EtherChannel Load Balancing - per packet? August 22, 2005, 5:41 am
Layer 3 Etherchannel Issue September 16, 2008, 10:27 am
Load Balancing / Load Sharing over parallel paths November 21, 2005, 9:14 am
Load Balancing February 15, 2005, 6:13 pm
load-balancing t1s August 30, 2005, 2:54 pm
Load Balancing February 20, 2006, 11:33 am
OER and load balancing March 2, 2006, 10:06 am
load balancing January 3, 2007, 8:35 pm
load-balancing t1s February 16, 2007, 1:43 pm
To QoS or load-balancing or both July 21, 2008, 5:35 pm
Load Balancing NxSTM1s August 23, 2005, 10:36 pm
RV042 and pix with load balancing October 12, 2005, 9:01 am
Load Balancing 2 Routes October 17, 2005, 8:08 am
Re: BGP and load balancing two routers October 17, 2005, 10:48 am
