Bookmark this page:
Yahoo!
Windows Live
del.icio.us
digg
Netscape
Posted by abhils44@gmail.com on September 15, 2006, 5:11 am
Please log in for more thread options all neccessary things to consider while doing this..... The idea of this project is to implement a filter at layer 2 (Ethernet). The user will be given a command line utility and he can add and remove rules into this filter. Depending on the rule decision needs to be made on the current Ethernet frame. Following is the specification: 1. The L2F gets started when the Linux Kernel boots up. 2. The user is given a command line utility with the following syntax: internal linked list. The L2F need to capture the Ethernet frame and extract source and destination mac addresses. If it matches any of the existing rules it should perform that action. The linked list should take care of all error conditions. | |||||||||||||
Posted by on September 15, 2006, 7:02 am
Please log in for more thread options abhils44@gmail.com wrote: > Is there anyone who knows how to implement this project, and what r the
> all neccessary things to consider while doing this..... > The idea of this project is to implement a filter at layer 2 > (Ethernet). The user will be given a command line utility and he can > add and remove rules into this filter. Depending on the rule decision > needs to be made on the current Ethernet frame. Following is the > specification: > > > > 1. The L2F gets started when the Linux Kernel boots up. > 2. The user is given a command line utility with the following > syntax: > 1. <utility_name> -add -s <source_mac_addr> -d > <destination_mac_addr> -a <action allow/deny> > 3. Once the user enters adds the rule the L2f will add a node to its > internal linked list. The L2F need to capture the Ethernet frame and > extract source and destination mac addresses. If it matches any of the > existing rules it should perform that action. The linked list should > take care of all error conditions. Very interesting, please post the code when you have finished your assignment:-) | |||||||||||||
| Similar Threads | Posted |
| Layer 2 Filtering Project...... | September 15, 2006, 5:11 am |
| looking for a valuable project in VOIP / IMS | August 2, 2006, 3:36 am |
| Re: Large VLAN Project - Advise | March 21, 2007, 7:34 am |
| Cisco WLAN Controller project | May 16, 2008, 7:14 am |
| 2960 (layer 2) vs 3560 (layer 3) ...considerations? | September 15, 2006, 9:22 am |
| project to configure Cisco Catalyst 6509 | April 23, 2006, 11:50 pm |
| Looking for Cisco (freelance) engineers for project work | August 10, 2006, 4:01 pm |
| Layer 1 / Layer 2 Difference | August 17, 2006, 10:00 pm |
| How to tell if my vlans are layer 2 or layer 3. | September 11, 2007, 4:43 am |
| BGP filtering PA and PI blocks | June 12, 2006, 9:45 am |
| URL Filtering WITHOUT Websense?? | January 3, 2007, 10:31 am |
| IOS MAC Address filtering? | January 3, 2007, 10:38 am |
| Content filtering | April 2, 2007, 2:12 am |
| Pix content filtering | May 29, 2007, 7:21 am |
| url filtering 2811 | December 1, 2007, 6:41 am |
Yahoo!
Windows Live
del.icio.us
digg
Netscape
