Cisco Systems [LONG] VPNClient - NAT - LAN to LAN tunnel
Subject Author Date
[LONG] VPNClient - NAT - LAN to LAN tunnel AM 09-19-05
Posted by AM on September 19, 2005, 3:48 pm
Sorry for weird subject but my post involves each issue.
I have an 837 configured for a LAN to LAN tunnel with my PIX.
I decided to connect to my 837 via VPNclient. So I setup all parameters needed.
The VPN client connected and connects fine.
When my target was to connect only to the LAN behind the router everythink
worked fine.
Afterwards I wanted to connect to resources behind the PIX also from the
VPNclient. I decided so on the basis that the
router can rotate packets on the same interface so there are no obstacles from
that point of view..
I created 3 groups for VPNclient
1) stupid users: they can not surf Internet and can access only 10.168.31.1
2) normal users: they can not surf Internet and can access all 10.168.31.0/24
3) power users: they can both access Internet and all 10.168.31.0/24
the first step was to assign those 3 groups ranges belonging to LAN numbering
behind of the router.
Everything worked fine but someone told me is not a good idea because devices
behind the router and accessed from the
VPNclient could search that VPNclient IP address directly on the LAN without
sending packets to the default gateway (the
router). Access to resources behind the PIX was fine. Packets coming from
VPNclient matched against 'LAN to LAN tunnel'
rules.
On the basis of the warning I moved to other pools for the VPNclient. But that
way, packets coming from client and going
towards resources behind the PIX are not encrypted as they didn't match L2L
tunnel.
Follow you can see the real configuration and under that changes I would add to
permit clients to reach resources behind
the PIX (I can tell you that those didn't work)
Finally my configuration is like below:
-0-0-0-0-0-0-0-0-0-0-0-0-0-0-0-0-0-0-0-0-0-0-0-0-0-0-0-0-0-0-0-0-0-0-0-0-0-0-0-0-0-0-0-0-0-0-0-0-0-0-0
version 12.3
no service pad
service timestamps debug datetime msec
service timestamps log datetime msec
service password-encryption
hostname MyRouter
boot-start-marker
boot-end-marker
enable secret 5 TTTTTTTTTTTTTTTTTTTT
username MyRouter password 7 TTTTTTTTTTTTTTTTTTT
clock timezone CET 0
clock summer-time CEST recurring last Sun Mar 2:00 last Sun Oct 3:00
aaa new-model
aaa authentication login userauthen local
aaa authorization network groupauthor local
aaa session-id common
ip subnet-zero
ip dhcp excluded-address 10.162.31.0 10.162.31.31
ip dhcp excluded-address 10.162.31.240 10.162.31.254
ip dhcp excluded-address 10.162.31.232 10.162.31.239
ip dhcp pool DHCPPoolLAN_0
network 10.162.31.0 255.255.255.0
default-router 10.162.31.254
dns-server 192.168.218.31 192.168.218.19 158.43.240.4 158.43.240.3
ip domain name DDDDDDDDDDDDDDD
ip name-server DDDDDDDDDDDDD
ip inspect name ethernetin esmtp timeout 3600
ip inspect name ethernetin tcp timeout 3600
ip inspect name ethernetin cuseeme timeout 3600
ip inspect name ethernetin ftp timeout 3600
ip inspect name ethernetin h323 timeout 3600
ip inspect name ethernetin rcmd timeout 3600
ip inspect name ethernetin realaudio timeout 3600
ip inspect name ethernetin sqlnet timeout 3600
ip inspect name ethernetin streamworks timeout 3600
ip inspect name ethernetin tftp timeout 30
ip inspect name ethernetin udp timeout 15
ip inspect name ethernetin vdolive timeout 3600
ip ips po max-events 100
ip ssh authentication-retries 5
ip ssh version 2
no ftp-server write-enable
crypto isakmp policy 10
encr 3des
hash md5
authentication pre-share
group 2
lifetime 1200
crypto isakmp policy 10000
encr 3des
group 2
crypto isakmp key YYYYYYYYYYYYYYYYYYYYYYYYYYYYYYYYYYYYYYYYYYYYYY address
RRRRRRRRR no-xauth
crypto isakmp invalid-spi-recovery
crypto isakmp client configuration group FFFFFFFFFFFF-USERS
key group1
dns 192.168.218.31 192.168.218.19
domain DDDDDDDDDDDDDDDd
pool VPNCLIENT-USERS
crypto isakmp client configuration group LOC_OP
key group2
pool VPNCLIENT-LOC_OP
crypto isakmp client configuration group HQ_OP
key group3
pool VPNCLIENT-HQ_OP
acl 103
netmask 255.255.255.254
crypto ipsec security-association lifetime seconds 1200
crypto ipsec transform-set headquarter esp-3des esp-md5-hmac
crypto ipsec transform-set 3DES-SHA esp-3des esp-sha-hmac
crypto dynamic-map mydynmap 10
set transform-set 3DES-SHA
reverse-route
crypto map vpnplusclient client authentication list userauthen
crypto map vpnplusclient isakmp authorization list groupauthor
crypto map vpnplusclient client configuration address respond
crypto map vpnplusclient 10 ipsec-isakmp
set peer DDDDDDDDDDDDDDD
set pfs group2
match address 130
crypto map vpnplusclient 65535 ipsec-isakmp dynamic mydynmap
interface Ethernet0
ip address 10.162.31.254 255.255.255.0
ip access-group 104 out
ip nat inside
ip inspect ethernetin in
ip virtual-reassembly
no cdp enable
hold-queue 100 out
interface ATM0
no ip address
no atm ilmi-keepalive
dsl operating-mode auto
pvc 0/38
encapsulation aal5mux ppp dialer
dialer pool-member 1
interface FastEthernet1
no ip address
duplex auto
speed auto
interface FastEthernet2
no ip address
duplex auto
speed auto
interface FastEthernet3
no ip address
duplex auto
speed auto
interface FastEthernet4
no ip address
duplex auto
speed auto
interface Dialer0
description OOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOo
ip address negotiated
ip mtu 1492
ip nat outside
encapsulation ppp
dialer pool 1
no cdp enable
ppp authentication chap pap callin
ppp chap hostname FFFFFFFFFFFFFF
ppp chap password 7 FFFFFFFFFFFFFFFFFFFF
ppp pap sent-username FFFFFFFFFFFFFFFFFFFF password 7 FFFFFFFFF
ip local pool VPNCLIENT-USERS 192.168.61.232 192.168.61.235
ip local pool VPNCLIENT-LOC_OP 192.168.61.236 192.168.61.237
ip local pool VPNCLIENT-HQ_OP 192.168.61.238 192.168.61.239
ip classless
ip route 0.0.0.0 0.0.0.0 Dialer0
no ip http server
no ip http secure-server
ip nat translation max-entries 2000
ip nat pool VPNclient2HQ 10.162.31.232 10.162.31.239 prefix-length 24
ip nat inside source route-map vpn_2hq interface Dialer0 overload
ip access-list extended vty-access
permit tcp 10.162.31.0 0.0.0.255 any eq 22
permit tcp 10.162.31.0 0.0.0.255 any eq telnet
permit tcp 192.168.218.0 0.0.0.255 any eq 22
permit tcp 192.168.218.0 0.0.0.255 any eq telnet
access-list 10 permit 192.168.218.0 0.0.0.255
access-list 10 permit 10.162.31.0 0.0.0.255
access-list 103 permit ip 10.162.31.0 0.0.0.255 192.168.61.238 0.0.0.1
access-list 104 permit ip 192.168.61.232 0.0.0.3 host 10.162.31.1
access-list 104 deny ip 192.168.61.232 0.0.0.3 10.162.31.0 0.0.0.255
access-list 104 permit ip any any
access-list 130 permit ip 10.162.31.0 0.0.0.255 192.168.218.0 0.0.0.255
access-list 130 permit ip 10.162.31.0 0.0.0.255 host 10.2.1.3
access-list 130 deny ip any any
access-list 131 deny ip 10.162.31.0 0.0.0.255 192.168.218.0 0.0.0.255
access-list 131 deny ip 10.162.31.0 0.0.0.255 192.168.61.232 0.0.0.7
access-list 131 deny ip 10.162.31.0 0.0.0.255 host 10.2.1.3
access-list 131 permit ip 10.162.31.0 0.0.0.255 any
no cdp run
route-map vpn_2hq permit 10
match ip address 131
control-plane
line con 0
exec-timeout 120 0
no modem enable
transport preferred all
transport output all
stopbits 1
line aux 0
line vty 0 4
access-class vty-access in
exec-timeout 120 0
length 0
transport input all
scheduler max-task-time 5000
end
access-list 105 permit ip 192.168.61.232 0.0.0.7 192.168.218.0 0.0.0.255
ip nat outside source list 105 pool client2HQ
ip nat pool client2HQ 10.162.31.232 10.162.31.239 netmask 255.255.255.248
ip route 10.162.31.232 255.255.255.248 dialer 0
I' m really sorry for the very long post but where I'm wrong?
BTW I don't want to change L2L rules as I would standardize all of this for all
837 routers connecting to the PIX. It
mean I should change all 40 rules written on PIX. Moreover I'd use different ip
pools for client on different routers.
Thank you very much to all arrived down to here.
Alex.
Similar ThreadsPosted
[LONG] VPNClient - NAT - LAN to LAN tunnel September 19, 2005, 3:48 pm
VPNclient and access to LAN. September 9, 2005, 1:59 pm
VPNclient and PIX515. January 11, 2007, 7:01 am
assigning vpnclient static ip July 11, 2007, 2:59 pm
cisco vpnclient for cmd script April 30, 2008, 11:25 am
Working even if missing some commands - VPNclient June 1, 2006, 11:31 am
udp traffic not passing over vpnclient connection to pix ASA 7.2 August 29, 2006, 4:24 pm
configure idle timout for Cisco vpnclient for linux 4.6.0 June 22, 2005, 12:42 pm
[VERY LONG] Cisco 3620 and very low throghuput. October 28, 2005, 4:21 pm
[LONG] Performance of an 877. How to increase the buffer? July 6, 2006, 11:33 am
Job Openings in the Long Island NY Area October 2, 2006, 2:56 pm
How long does the switch retain the MAC address? October 11, 2006, 3:45 pm
Problem with interface counters. (long) May 17, 2007, 9:16 am
weird Config... How long will this work? April 22, 2008, 2:19 pm
Cisco BGP confederation treatment changes in IOS 12.3 (LONG post) December 18, 2005, 6:18 am
