Cisco Systems LAN, Switching and Routing: No link between fiber converter and Catalyst 6500, works with Router 7301
Subject Author Date
LAN, Switching and Routing: No link between fiber converter and Catalyst 6500, works with Router 7301 Hoffa 01-12-07
Posted by Hoffa on January 12, 2007, 2:27 am
Greetings all
I have tried to find an answer to and issue like this before but
without success.
I've tried for some day now to get a fiber connection between an
IMCnetworks MM850 GigabitTP<->Fiber converter up and running. The fiber
is on my end connected to a SX SPF. When I connect the cable and enable
the interface I get a LinkUp light on the media converter but no link
on my Cat6500. I've tried different autodetect, negotiation and speed
settings but nothing works. I've also tried different SPFs and switched
cables.
As a final solution I plugged the fiber cable into our 7301 router,
bypassing our Cat6500. After I set the port to "no negotiate auto" the
link went up on the 7301.
How can the same cable and same SPF work on the 7301 but not on my
Cat6500? Is there some setting I'm missing here?
Regards
Fredrik Hofgren
Posted by Peter on January 12, 2007, 5:04 pm
Hi Frederick,
> without success.
> cables.
That certainly sounds like the problem, however one thing seems
obvious to me, the Device you are trying to connect appears to NOT be
doing any negotiation. This means you MUST set the Cisco device to not
even ATTEMPT to autonegotiate, the settings should match between ends
EXACTLY, so that the Cisco device does not even try to autonegotiate.
From you comments about the 7301 connection working I would also check
the Auto MDX (X-over), however I have seen this work both ways in no
negotiate scenarios so I guess it depends on the exact H/W involved.
Its not much but I hope it helps.................pk.
Peter from Auckland.
Similar ThreadsPosted
LAN, Switching and Routing: No link between fiber converter and Catalyst 6500, works with Router 7301 January 12, 2007, 2:27 am
WS-X6516A-GBIC + Catalyst 6500 + Sup2 = Fibre Channel-Switching ? March 8, 2007, 1:02 pm
Using a Gigabit copper to Gigabit fiber media converter for an IDF May 3, 2006, 7:56 pm
Link aggregation over fiber -- possible? May 25, 2006, 5:15 pm
Catalyst 5000 w/ Sup. III - Switching Fabric June 22, 2005, 11:08 am
Catalyst 3500 switching method July 5, 2005, 11:56 am
When bridging works faster than routing March 28, 2007, 2:55 pm
WAN, Routing and Switching: Route some IP traffic over tunnel January 15, 2007, 6:16 am
LAN, Switching and Routing: Cat 3524 switch better at streaming than 4503, why? December 12, 2007, 8:21 am
Internetworkexpert CCIE Routing & Switching Advanced Technologies Labs December 1, 2006, 3:15 am
LAN, Switching and Routing: Multicast advice needed on Cat 6513 IOS 12.2SXF5 February 7, 2008, 7:34 am
Catalyst 6500 help October 9, 2007, 2:42 pm
catalyst 6500 power February 20, 2006, 5:23 am
Catalyst 6500 [FWSM] [CSM] May 4, 2006, 3:51 am
