Cisco Systems KeepAlive on Ethernet Interfaces
Subject Author Date
KeepAlive on Ethernet Interfaces Yab 09-26-06
Posted by Yab on September 26, 2006, 3:55 am
I had a major issue on our LAN with 25 2950 switchs. After a Gbic
change on our 6513, all giga trunk ports connected on this 6513 were
err-disable at the same time due to keepalive issue. One hour after the
second giga port on all affected 2950 were err-disable too. It was very
strange because the second giga port was plugged on my secundary 6513.
I never exactly understand what's happened.
I take a glance at Bug Tool Web site and there are 2 bugs referenced
which could be the origin of my problem: CSCea46385 & CSCeg58877
I try to have a full explanation about keepalive on cisco website but
it's really confused. If you can explain me exactly how it's working.
It is mentioned to disable keepalive on Fiber interfaces and uplink
interfaces as 12.2SE releases, release not available for 2950.
I use also GigaStack between 2950 switches. what is recommanded for?
Is it possible to remove keepalive on all trunk interfaces (Copper,
Fiber, Gigastack) between switches?
Thanks in advance.
Similar ThreadsPosted
KeepAlive on Ethernet Interfaces September 26, 2006, 3:55 am
ethernet keepalive November 10, 2007, 7:44 am
Keepalive on Ethernet interface June 23, 2006, 11:06 pm
LLQ on Ethernet Interfaces July 1, 2007, 9:36 am
2960 Ethernet interfaces going down November 25, 2008, 1:25 pm
OSPF issues on Ethernet Interfaces August 10, 2005, 7:56 am
Routing between ethernet interfaces on 1605r September 18, 2006, 4:59 pm
Two ethernet Interfaces want to use one as a backup different ISP's September 25, 2006, 10:01 am
More than two Ethernet interfaces on a 28xx router? October 5, 2006, 12:52 pm
smallest IOS based router with 3 ethernet interfaces March 20, 2006, 11:09 am
problems pinging between FastEthernet and Ethernet interfaces November 15, 2006, 3:17 pm
Configure MPLS VPN on Ethernet VLAN interfaces June 15, 2008, 10:35 am
VPN Tunnel - Keepalive NOT SET February 21, 2007, 1:44 pm
CSM Script for Radius-Keepalive July 18, 2005, 4:26 am
Re: ipv6ip tunnel keepalive September 26, 2007, 5:06 pm
