Bookmark this page:
Yahoo!
Windows Live
del.icio.us
digg
Netscape
Posted by claire on February 8, 2006, 6:26 am
Please log in for more thread options I'm using a Windows version of CiscoWorks Resource Manager Essentials 3.5 and I'm having issues adding or deleting new devices using a CSV file to the RME Inventory. What I'm doing and the results I'm getting are: RME -> Administrator -> Inventory -> Delete Devices from file
Probable Cause: The device data in the import file was incorrectly formatted. A log of the messages describing the detected errors is in the file /tmp/FIXME. Recommended Action: Review the contents of the error log file before calling your technical support representative for assistance. The FIXME output is: PGM_NM=XIP.pm:14:TYPE=CRITICAL::[] Input does not contain the required header. Cannot proceed. Has anyone else had this problem or know the correct format and required header? Basically, I put all the device name details into notepad, saved it as a CSV file. I have also tried using the same format generated by the Inventory export to file utility but I get the same error. Any ideas? TIA, | ||||||||||||||||
Posted by on February 8, 2006, 1:30 pm
Please log in for more thread options around. VNC into the CW2K server and open the GUI from there and login as "admin" then run the RME -> Administrator -> Inventory
it should work that way. Let me know claire wrote: > Greetings All,
> > I'm using a Windows version of CiscoWorks Resource Manager Essentials 3.5 > and I'm having issues adding or deleting new devices using a CSV file to the > RME Inventory. > > What I'm doing and the results I'm getting are: > RME -> Administrator -> Inventory -> Delete Devices from file > > Probable Cause: The device data in the import file was incorrectly > formatted. A log of the messages describing the detected errors is in the > file /tmp/FIXME. > Recommended Action: Review the contents of the error log file before calling > your technical support representative for assistance. > > The FIXME output is: > PGM_NM=XIP.pm:14:TYPE=CRITICAL::[] Input does not contain the required > header. Cannot proceed. > > Has anyone else had this problem or know the correct format and required > header? > > Basically, I put all the device name details into notepad, saved it as a CSV > file. > > I have also tried using the same format generated by the Inventory export to > file utility but I get the same error. > > Any ideas? > > TIA, | ||||||||||||||||
| Similar Threads | Posted |
| Issues Updating CiscoWorks Inventory | February 8, 2006, 6:26 am |
| CiscoWorks Inventory Interface | June 16, 2008, 3:58 am |
| Updating IOS, how much Flash do I have? | April 2, 2007, 5:46 pm |
| updating pix IDS signitures | October 8, 2007, 12:23 pm |
| updating pix 506e? | June 9, 2008, 5:47 pm |
| Updating flash on 3620 - again | August 11, 2005, 8:25 am |
| Updating 2620 & 2924 FW | September 16, 2007, 9:33 pm |
| Updating 2900 switch | September 26, 2007, 9:32 pm |
| IOS Updating my hosts entries?? | October 9, 2007, 8:26 pm |
| Ciscoworks LMS 2.5 | December 1, 2005, 9:02 am |
| CiscoWorks 2000 | February 13, 2005, 9:19 pm |
| CiscoWorks and CiscoSecure ACS | January 24, 2006, 2:33 am |
| whatsupgold and ciscoworks is it possible on same pc?? | January 25, 2006, 5:48 am |
| Ciscoworks problem | January 27, 2006, 12:04 pm |
| CiscoWorks + IIS problems? | March 2, 2006, 4:51 pm |
Yahoo!
Windows Live
del.icio.us
digg
Netscape
