Bookmark this page:
Yahoo!
Windows Live
del.icio.us
digg
Netscape
Posted by Sako on March 6, 2006, 11:28 am
Please log in for more thread options it's quite a good utility to manage a network use. I want to know if there is any utility that permits making stadistics of wich ip addresses are using more the network and what protocols are them using in a device such as cisco PIX 501or 515. Thanks and regards | ||||||||||||||||
Posted by Walter Roberson on March 6, 2006, 12:21 pm
Please log in for more thread options > I want to know if there is any utility that permits making
>stadistics of wich ip addresses are using more the network and what >protocols are them using in a device such as cisco PIX 501or 515. The PIX 501 is currently restricted to run 6.x software. The PIX 515 can run 6.x or 7.0 or 7.1 software. The monitoring available with 7.0 and 7.1 is more advanced than for 6.x, but I have not examined the differences as yet. I do recall, though, that there is no equivilent to netflow for PIX 6.x or PIX 7.0. For PIX 6.x, if you are trying to track by anything finer-grained than total traffic on the [logical] interface, then your only option is to set up logging to a syslog server, and to use some program that analyses the syslog output. The two major limitations on that are: 1) that it has no way to provide you with information about current bandwidth usage through syslog (but snmp can give overall bandwidth usage); and 2) that throughput estimates cannot be made for connections until the connection closes and the final connection time and byte-count are written out. The byte counts are not broken down by direction, unfortunately. For sample source to do a traffic volume analysis of a PIX 6.x log, see http://groups.google.ca/group/comp.dcom.sys.cisco/browse_thread/thread/972a527ba458f06/37ddb0b6234c1e48#37ddb0b6234c1e48 | ||||||||||||||||
| Similar Threads | Posted |
| Is possible Pix + Netflow stadistics? | March 6, 2006, 11:28 am |
| 6500 modules & netflow - what is the difference between "X-BAR" and "Fabric enabled" , netflow questions | October 12, 2005, 8:12 pm |
| Netflow over VPN | February 8, 2006, 6:20 pm |
| Netflow on PIX | December 5, 2006, 7:41 pm |
| "NetFlow" for ASA | April 3, 2007, 7:53 am |
| NetFlow | September 11, 2007, 4:07 pm |
| Re: NTOP & Netflow | February 13, 2006, 7:58 am |
| Netflow easy, MLS not | June 21, 2006, 7:54 pm |
| NETFLOW ON CAT 3550 | July 8, 2005, 12:22 pm |
| Netflow QOS monitoring | September 15, 2006, 5:58 am |
| [gsr] netflow on subinterfaces | December 12, 2006, 5:32 pm |
| Configure Netflow | December 4, 2007, 5:32 pm |
| more netflow problems | March 23, 2008, 2:40 pm |
| NetFlow Collector performance | September 27, 2005, 9:42 am |
| Netflow and VRF-Lite problem | November 3, 2005, 8:24 am |
Yahoo!
Windows Live
del.icio.us
digg
Netscape
