Bookmark this page:
Yahoo!
Windows Live
del.icio.us
digg
Netscape
Posted by thefunnel@aol.com on July 12, 2007, 12:09 pm
Please log in for more thread options I am having difficulties connecting two switches (3750s) together via copper (using auto mdix). I was always under the impression ports should either be set to fixed speeds or set to auto at both ends. You should not have a combination of fixed / auto or mismatches can occur. I seem to be seeing the opposite: "speed 10" to "speed 10" = NOT WORKING "speed 100" to "speed 100" = NOT WORKING But if only one end is set to a fixed speed: "speed 10" to "speed auto" = WORKING "speed 100" to speed auto" = WORKING I have also tried setting both ends to full and half duplex - still nothing. Would someone mind explaining why this is happening? I can achieve the desired effect by only configuring the speed on one end but I thought Cisco avoid against this? Thanks, Paul | |||||||||||||
Posted by on July 12, 2007, 12:37 pm
Please log in for more thread options > should either be set to fixed speeds or set to auto at both ends. You
> should not have a combination of fixed / auto or mismatches can occur. > I seem to be seeing the opposite: > > > "speed 10" to "speed 10" = NOT WORKING > "speed 100" to "speed 100" = NOT WORKING Auto mdix requires autonegotiate. > But if only one end is set to a fixed speed:
> > "speed 10" to "speed auto" = WORKING > "speed 100" to speed auto" = WORKING If one end is auto, that end will do the auto-mdix. > I have also tried setting both ends to full and half duplex - still
> nothing. Would someone mind explaining why this is happening? I can > achieve the desired effect by only configuring the speed on one end > but I thought Cisco avoid against this? I don't see that you've tried "speed auto" to "speed auto". That's the setting that I would recommend. | |||||||||||||
Interlinking switches / port speeds
Yahoo!
Windows Live
del.icio.us
digg
Netscape
