Bookmark this page:
Yahoo!
Windows Live
del.icio.us
digg
Netscape
Posted by on April 18, 2007, 3:36 am
Please log in for more thread options "8059 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored" No no overruns, CRCs errors, etc, so what other causes are there for these errors. Both side are half-duplex. Thanks, Robbert Dam Complete log: FastEthernet0/5 is up, line protocol is up (connected) Hardware is Fast Ethernet, address is 0018.b925.5f87 (bia 0018.b925.5f87) MTU 1500 bytes, BW 10000 Kbit, DLY 1000 usec, reliability 255/255, txload 5/255, rxload 5/255 Encapsulation ARPA, loopback not set Keepalive set (10 sec) Half-duplex, 10Mb/s, media type is 10/100BaseTX input flow-control is off, output flow-control is unsupported ARP type: ARPA, ARP Timeout 04:00:00 Last input never, output 00:00:00, output hang never Last clearing of "show interface" counters never Input queue: 0/75/0/0 (size/max/drops/flushes); Total output drops: 0 Queueing strategy: fifo Output queue: 0/40 (size/max) 5 minute input rate 233000 bits/sec, 254 packets/sec 5 minute output rate 235000 bits/sec, 256 packets/sec 427769882 packets input, 1774996100 bytes, 0 no buffer Received 56242 broadcasts (0 multicast) 0 runts, 0 giants, 0 throttles 8059 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored 0 watchdog, 0 multicast, 0 pause input 0 input packets with dribble condition detected 430647135 packets output, 2197925637 bytes, 0 underruns 0 output errors, 17420 collisions, 1 interface resets 0 babbles, 0 late collision, 0 deferred 0 lost carrier, 0 no carrier, 0 PAUSE output 0 output buffer failures, 0 output buffers swapped out | ||||||||||||||||
Posted by Lutz Donnerhacke on April 18, 2007, 3:44 am
Please log in for more thread options If the sender of a frame detects a collision, it sends a abort sequence to the ethernet. This is an input error, but non of the specified error conditions, because it's a valid abort of transfer. | ||||||||||||||||
Posted by on April 18, 2007, 11:16 am
Please log in for more thread options > * robbert...@gmail.com wrote:
> > I see lots of input error on my switch,
> > these errors. Both side are half-duplex. >
Hmm, never heard of that one?
> If the sender of a frame detects a collision, it sends a abort sequence to > the ethernet. This is an input error, but non of the specified error > conditions, because it's a valid abort of transfer. Have a look at sh int FastEthernet0/5 counters sh int FastEthernet0/5 counters error sh int FastEthernet0/5 counters detailed Possibly non performance impacting bug? Always worth checking the snmp counters to see if there is anything there that is not in the sh int counters. The error rate is not that high 1/50,000 so not worth getting into a huge lather about. "Last clearing of "show interface" counters never " These errors may be historic. | ||||||||||||||||
| Similar Threads | Posted |
| Input errors, but what's causing them? | April 18, 2007, 3:36 am |
| CRC & INPUT Errors | April 23, 2007, 5:51 pm |
| Cisco 2621xm Input and CRC Errors | July 6, 2005, 9:24 am |
| IOS RMON - monitoring Input Errors ? | July 8, 2008, 4:54 pm |
| Easily Logging / Reviewing input errors from multiple routers | May 11, 2006, 9:51 am |
| Who is causing traffic on 506e | March 24, 2006, 3:05 pm |
| Cisco VPN client causing Win XP VPN issue | April 24, 2008, 11:13 pm |
| Cisco ASA 5505 causing network down | June 10, 2008, 11:04 pm |
| Aironet 1200 causing BSOD in XP clients! | November 23, 2005, 6:33 am |
| Catalyst 3560 causing switches to freeze? | May 8, 2006, 4:21 pm |
| Whos's causing my high traffic on 506e | December 4, 2006, 10:57 am |
| ip inspect causing problems joing domain | December 7, 2006, 9:43 pm |
| 6513 with HSRP and F5 causing Dropped packets | March 5, 2008, 6:36 pm |
| DC Input on Cisco 2900XL | September 17, 2005, 5:21 pm |
| if input / output drops | April 26, 2007, 7:47 pm |
Yahoo!
Windows Live
del.icio.us
digg
Netscape
