Cisco Systems Im paying ATT for a 6 meg down load speed but Im not even getting 1 meg can any one help me fix this
Subject Author Date
Im paying ATT for a 6 meg down load speed but Im not even getting 1 meg can any one help me fix this quain433 02-13-08
Posted by on February 13, 2008, 5:50 am
meg can any one help me fix this. Any time I down laod someting I
cannot get no more than 600 kbs. I shold be getting a lot more than
that. Ive got a 10/1000 realtek gigabit card. is ther any
configuraation I need to make. I was thinking about installing a
installing a direct ethernet line to my phone hub outside would that
help anything. Any and all advise is greatly appreaciated.
Posted by Trendkill on February 13, 2008, 7:29 am
Well, and first, 6 meg is not 6 MB, its 6 Mb (bit) and you will only
see a max of 700-750 KB per second. Presuming you know this since you
said 600 kilobits, have you tried calling the provider? I would
seriously doubt you have a LAN issue unless you are using wireless and
have a poor signal. Besides checking the obvious settings, ie speed/
duplex etc, which would cause errors and very very poor speed (much
less than 600kb), you probably need to call your provider. Before you
do, can you setup another machine and ftp between them, this will
eliminate your NICs, PCs/Servers, and the switch part of your
equipment. If it goes fast, you need to follow up with the ISP.
Similar ThreadsPosted
Im paying ATT for a 6 meg down load speed but Im not even getting 1 meg can any one help me fix this February 13, 2008, 5:50 am
TOP PAYING KEYWORDS for Google Adsense and Pay Per Click January 21, 2007, 12:34 pm
Load Balancing / Load Sharing over parallel paths November 21, 2005, 9:14 am
Speed Mismatch?!? May 7, 2006, 7:43 pm
Port Speed October 6, 2006, 9:20 am
Re: Speed Mismatch?!? January 5, 2007, 1:12 pm
Duplex/Speed Hardcoding May 17, 2006, 8:19 am
Setting DSL downstream Speed May 27, 2006, 5:56 pm
Speed for AUX (RJ45) port. November 25, 2006, 4:53 pm
determining speed issues April 27, 2007, 12:01 pm
restrict PC traffic speed on the lan August 10, 2008, 1:11 pm
Port down when i force in speed 100 October 28, 2008, 12:11 pm
Serial Line Speed Limit!! October 28, 2005, 2:45 pm
T1 Line Speed Test Question Please Help!!!! March 26, 2006, 9:12 pm
Speed Dials in Attendant Console July 7, 2006, 8:48 am
