Cisco Systems ISIS Adjacency Problem
Subject Author Date
ISIS Adjacency Problem dennis 06-08-07
Posted by dennis on June 8, 2007, 12:56 am
Hi all,
first let me tell I' not ver familar with ISIS...yesterday night I try
to troubleshoot a adjacency problembetween two cisco systems....
on is a AS5800 and on the other side a cisco 7609
On both systems are IOS version 12.2
The connectivity is done over fiber SX gigabit ports...because the
systems are in the same room and side by side.
The AS is redundant connected to 2 7606
So from AS gi 6/0 is going to router 1 gig 2/21 and gig6/1 is going
to router 2/21
When I debug on the AS that it sends and receives clns packets over
6/1...but it only send over 6/0 and doesn't receive...
both interfaces are UP....
so what are the possible reasons ? any ideas ?
thanks dennis
Posted by Trendkill on June 8, 2007, 7:12 am
> Hi all,
> to router 2/21
> thanks dennis
What does your show isis topology and show isis database show? Are
you actually losing adjacencies, or you are just noticing through show
commands that you are not sending these? I would assume that these
are two different vlans from the AS perspective, so it shouldn't be
layer 2, spanning-tree, etc. Have you checked your fiber? What
messages are you seeing on the switch portion of your routers
(presuming you have a switch underneath because your port was number
21). Any link-loss? Is UDLD turned on?
Similar ThreadsPosted
ISIS Adjacency Problem June 8, 2007, 12:56 am
OSPF adjacency problem while adding multiple routes. January 9, 2007, 10:13 pm
Csico 3640 => MTU/ISIS/MPLS February 8, 2009, 9:05 am
ISIS multicast addr on broadcast nets? February 15, 2005, 8:23 pm
IS-IS Routers not establishing adjacency March 27, 2006, 1:39 pm
Re: How does CEF determine PPP peer adjacency? January 23, 2009, 3:42 am
PIX Problem February 11, 2005, 2:45 am
PIX problem .. July 12, 2005, 10:27 am
NAT-PT and TCP problem July 20, 2005, 12:25 pm
problem with FTP July 21, 2005, 8:11 pm
PIX 501 Problem July 23, 2005, 9:18 pm
FXO Problem? July 23, 2005, 9:15 pm
pix problem July 27, 2005, 8:13 pm
PIX 501 - problem August 4, 2005, 5:58 pm
pix to pix problem :) August 23, 2005, 4:53 pm
Residential Cabling Guide
Home Cabling Guide
Finally, an instantly downloadable book that saves you thousands in home improvement dollars! Enjoy living in 21st century technology-advanced home while increasing its selling value and competitive advantage on the real estate market. Whether your cabling is for home office or high-tech leisure, you can wire your home yourself or learn "wirish" to speak with your cabling contractors in their language!
Learn More
