Cisco Systems ISDN and VoIP configuration
Subject Author Date
ISDN and VoIP configuration clmx_jleudo@yahoo.com 10-06-05
Posted by clmx_jleudo@yahoo.com on October 6, 2005, 4:11 pm
Hi Fellows
I need a little help to fix a problem that I have already trying to
receive calls in a Cisco GW 2610, basically I want to receive some
calls coming from the PSTN and sent these to and IP-PBX using SIP, when
a dial I got dial tone and few seconds later the call is discconected,
the call is received by the router but is not routed to the other end
thru SIP.
If you can take a look to this y will appreciate any help on this:
1d07h: ISDN Se1/0:23: Ux_BadMsg(): Invalid Message for call state 10,
call id 0x2B, call ref 0x805A, event 0x62
1d07h: ISDN Se1/0:23: TX -> STATUS pd = 8 callref = 0x805A
1d07h: Cause i = 0x80E562 - Message not compatible with call
state
1d07h: Call State i = 0x0A
1d07h: ISDN Se1/0:23: TX -> DISCONNECT pd = 8 callref = 0x805A
1d07h: Cause i = 0x809C - Invalid number format (incomplete
number)
a different log
1d06h: ISDN Se1/0:23: Incoming call id = 0x001D, dsl 0
1d06h: ISDN Se1/0:23: NegotiateBchan: bchan 1 intid 0 serv_st 0 chan_st
0 callid 0x0000 ev 0x90 n/w? 0
1d06h: Negotiated int_id 0 bchan 0 cr=0x804D callid=0x001D lo_chan 1
final int_id/bchan 0/1 cause 0x0
1d06h: ISDN Se1/0:23: LIF_EVENT: ces/callid 1/0x1D CALL_INCOMING
1d06h: ISDN Se1/0:23: CALL_INCOMING dsl 0 bchan 0
1d06h: ISDN Se1/0:23: CALL_INCOMING: call type is VOICE ULAW, bchan = 0
1d06h: ISDN Se1/0:23: Event: Received a VOICE call from 3059842692 on
B0 at 64 Kb/s
1d06h: ISDN Se1/0:23: process_pri_simple(): msg 74, call id 0x1D, bchan
0, call type VOICE
1d06h: ISDN Se1/0:23: process_disconnect(): call id 0x1D, call type is
VOICE, b_idb 0x82346678, ces 1, cause No route to destination(0x3)
1d06h: ISDN Se1/0:23: CCPRI_ReleaseCall(): bchan 1, call id 0x1D, call
type VOICE
1d06h: CCPRI_ReleaseChan released b_dsl 0 B_Chan 1
1d06h: ISDN Se1/0:23: LIF_EVENT: ces/callid 1/0x1D CALL_CLEARED
1d06h: ISDN Se1/0:23: received CALL_CLEARED call_id 0x1D
1d06h: no resend setup, no redial
Part of the configuration
What I'm missing here?
no ip dhcp-client network-discovery
isdn switch-type primary-ni
voice service voip
controller T1 1/0
framing esf
linecode b8zs
pri-group timeslots 1-24
interface Ethernet0/0
description To LAN
ip address 192.168.1.34 255.255.255.0
full-duplex
interface Serial0/0
no ip address
shutdown
interface Serial0/1
no ip address
shutdown
interface Serial1/0:23
no ip address
no logging event link-status
isdn incoming-voice voice
isdn calling-number 3056777888
isdn sent-alerting
no cdp enable
ip classless
no ip http server
call rsvp-sync
voice-port 1/0:23
mgcp profile default
dial-peer cor custom
dial-peer voice 2 pots
incoming called-number 30567778..
direct-inward-dial
dial-peer voice 200 voip
destination-pattern 30567778..
session target ipv4:192.168.1.25
codec g711ulaw
end
Posted by Jonathan on October 6, 2005, 4:51 pm
> Hi Fellows
> thru SIP.
Run a "debug isdn q931" and make a test call. Post the results.
I am pretty sure you are not sending these as unknown/unknown and that is
why it is failing, but I want to check (or, you could be sending them
unknown/unknown and it is looking for national/unknown, etc...)
Jonathan
Posted by clmx_jleudo@yahoo.com on October 11, 2005, 7:58 pm
HI Jonathan
The numbers are showing as National instead of Unknown I will made the
change, but here is how it is from the begining:
IPGateway(config-if)#
1d07h: ISDN Se1/0:23: RX <- SETUP pd = 8 callref = 0x0059
1d07h: Bearer Capability i = 0x8090A2
1d07h: Channel ID i = 0xA98381
1d07h: Facility i =
0x9F8B0100A10F02010106072A8648CE1500040A0100
1d07h: Calling Party Number i = 0x2183, '7862109319',
Plan:ISDN, Type:National
1d07h: Called Party Number i = 0xA1, '3056777888', Plan:ISDN,
Type:National
1d07h: ISDN Se1/0:23: TX -> CALL_PROC pd = 8 callref = 0x8059
1d07h: ISDN Se1/0:23: TX -> DISCONNECT pd = 8 callref = 0x8059
1d07h: Cause i = 0x8083 - No route to destination
1d07h: ISDN Se1/0:23: RX <- RELEASE pd = 8 callref = 0x0059
1d07h: ISDN Se1/0:23: TX -> RELEASE_COMP pd = 8 callref = 0x8059
1d07h: ISDN Se1/0:23: RX <- SETUP pd = 8 callref = 0x005A
1d07h: Facility i =
1d07h: Called Party Number i = 0xA1, '3056777810', Plan:ISDN,
Type:National
1d07h: ISDN Se1/0:23: TX -> CALL_PROC pd = 8 callref = 0x805A
1d07h: ISDN Se1/0:23: TX -> CONNECT pd = 8 callref = 0x805A
1d07h: ISDN Se1/0:23: RX <- CONNECT_ACK pd = 8 callref = 0x005A
1d07h: ISDN Se1/0:23: CALL_PROGRESS: CALL_CONNECTED call id 0x2B, bchan
0, dsl 0
1d07h: ISDN Se1/0:23: RX <- FACILITY pd = 8 callref = 0x005A
1d07h: Facility i =
0x9F8B0100A117020101020100800F4C4555444F2C4A4F484E2020202020
state
number)
1d07h: Facility i =
1d07h: ISDN Se1/0:23: RX <- RELEASE pd = 8 callref = 0x005A
1d07h: ISDN Se1/0:23: TX -> RELEASE_COMP pd = 8 callref = 0x805A
Posted by clmx_jleudo@yahoo.com on October 11, 2005, 9:12 pm
genius Jonathan
That was my issue I set numbering-type as unknown and it works fine
now. Thanx a lot
Similar ThreadsPosted
ISDN and VoIP configuration October 6, 2005, 4:11 pm
VOIP Configuration June 1, 2006, 5:02 am
VOIP CONFIGURATION July 12, 2007, 12:14 pm
ISDN Configuration Tutorials April 21, 2007, 4:51 am
Cisco 2600 ISDN Failover Configuration April 25, 2006, 3:59 pm
Simple ISDN configuration to dial in with Windows January 12, 2007, 12:25 pm
Configuration for setup: ISDN - Cisco 2821 - SIP Phone October 12, 2006, 10:48 am
Voip Updated Howto,Voip ATT Home (October Update) October 29, 2006, 9:00 am
Voip Updated Howto,Voip AT Home June 28, 2006, 9:02 pm
Configuration reverted to previous configuration after power loss March 3, 2006, 11:14 am
VOIP June 21, 2006, 2:18 pm
Allow VOIP through PIX 501 July 10, 2006, 3:54 am
FAX + VoIP - T.30 / T.38 August 22, 2006, 4:20 pm
VoIP over VPN August 28, 2006, 4:16 am
Voip and QoS August 28, 2007, 4:54 am
