Cisco Systems ISDN Switching between BRI and PRI interfaces
Subject Author Date
ISDN Switching between BRI and PRI interfaces chassignet 01-03-06
Posted by on January 3, 2006, 2:29 am
Hello,
I have a 2811 router which has one VWIC-1MFT-E1 connected to the PSTN,
and one VIC2-2BRI-NT/TE connected DIRECTLY to one router and one modem
(not Cisco ones). The 2811 is a H323 gateway that works properly for
voice with CallManager and Cisco IP Phones (whose reach external
numbers through the PRI interface).
The router and the modem (whose handle data) need to access to the PSTN
through the PRI interface (for remote maintenance purpose). I mean the
2811 needs to proceed the switching between its BRI interfaces and its
PRI interface properly!!!
We've managed to make ISDN switching to work in our lab with one 3640
router with two VIC2-2BRI-NT/TE (one connected to the PSTN and one
directly connected to a router). So, I don't know why it's not working
with a 2811 between a BRI and a PRI???
Our network topology network is as follow :
CCM---IP---2811-PRI--PSTN
BRI
Modem&Router
Does someone know how to make this configuration working ?
Thanking you in advance,
Regards,
Benjamin
PS: I have the following configuration :
Current configuration : 4591 bytes
version 12.3
service timestamps debug datetime msec
service timestamps log datetime msec
service password-encryption
hostname H323GTW
boot-start-marker
boot-end-marker
logging buffered 4096 debugging
enable secret 5 *****************************
network-clock-participate wic 0
network-clock-participate wic 1
network-clock-select 1 E1 0/0/0
no aaa new-model
ip subnet-zero
ip cef
no ip domain lookup
no ftp-server write-enable
isdn switch-type primary-net5
voice-card 0
no dspfarm
dsp services dspfarm
no local-bypass
voice call carrier capacity active
voice service pots
voice service voip
modem passthrough nse codec g711alaw
voice class codec 1
codec preference 1 g711ulaw
voice class h323 1
h225 timeout tcp establish 5
voice translation-rule 10
rule 1 /^1/ /001/
rule 2 /^2/ /002/
rule 3 /^3/ /003/
rule 4 /^4/ /004/
rule 5 /^5/ /005/
rule 6 /^6/ /006/
rule 7 /^0/ /00/
rule 8 /^8/ /008/
voice translation-rule 20
rule 1 /^00/ /0/
rule 2 /^01/ /1/
rule 3 /^03/ /3/
voice translation-profile modif_entrant_appelant
translate calling 10
voice translation-profile modif_sortant_appele
translate called 20
controller E1 0/0/0
framing NO-CRC4
pri-group timeslots 1-28
interface FastEthernet0/0
description vers CCM
ip address 192.168.10.6 255.255.255.0
duplex auto
speed auto
h323-gateway voip interface
h323-gateway voip bind srcaddr 192.168.10.6
interface FastEthernet0/1
no ip address
shutdown
duplex auto
speed auto
interface Serial0/0/0:15
no ip address
no logging event link-status
isdn incoming-voice voice
isdn negotiate-bchan resend-setup
isdn sending-complete
no cdp enable
interface BRI0/1/0
no ip address
isdn switch-type basic-net3
isdn overlap-receiving
isdn protocol-emulate network
isdn layer1-emulate network
isdn skipsend-idverify
line-power
interface BRI0/1/1
no ip address
line-power
ip classless
ip route 0.0.0.0 0.0.0.0 192.168.10.254
ip http server
ip http authentication local
ip http secure-server
control-plane
voice-port 0/0/0:15
translation-profile incoming modif_entrant_appelant
cptone FR
voice-port 0/1/0
compand-type a-law
cptone FR
voice-port 0/1/1
compand-type a-law
cptone FR
dial-peer cor custom
dial-peer voice 10 pots
translation-profile outgoing modif_sortant_appele
destination-pattern .T
progress_ind setup enable 3
progress_ind alert enable 8
progress_ind progress enable 8
progress_ind connect enable 8
incoming called-number .
no digit-strip
direct-inward-dial
port 0/0/0:15
forward-digits all
dial-peer voice 11 pots
destination-pattern 7158
incoming called-number 7158
direct-inward-dial
port 0/1/0
forward-digits all
dial-peer voice 12 pots
destination-pattern 7157
incoming called-number 7157
no digit-strip
direct-inward-dial
port 0/1/1
forward-digits all
prefix 7157
dial-peer voice 100 voip
description Vers Publisher
preference 1
destination-pattern 71..
voice-class codec 1
voice-class h323 1
session target ipv4:192.168.10.2
incoming called-number 71..
dtmf-relay h245-signal h245-alphanumeric
no vad
dial-peer voice 110 voip
description Vers Subscriber
preference 2
voice-class codec 1
voice-class h323 1
session target ipv4:192.168.10.3
no vad
dial-peer voice 200 voip
preference 1
destination-pattern 30..
voice-class codec 1
voice-class h323 1
no vad
dial-peer voice 210 voip
preference 2
voice-class codec 1
voice-class h323 1
no vad
gateway
timer receive-rtp 1200
line con 0
password 7 *****************************
login
line aux 0
login
line vty 0 4
login
scheduler allocate 20000 1000
end
Posted by on January 3, 2006, 3:09 am
PS: When I try to make a call from the router connected to the BRI of
the 2811, Here is what I get :
H323GTW#DEB ISDN Q931
debug isdn q931 is ON.
H323GTW#TERM MON
H323GTW#
*Dec 16 17:45:32.492: ISDN BR0/1/0 Q931: RX <- SETUP pd = 8 callref =
0x0B
Bearer Capability i = 0x8890
Standard = CCITT
Transer Capability = Unrestricted Digital
Transfer Mode = Circuit
Transfer Rate = 64 kbit/s
Channel ID i = 0x83
Called Party Number i = 0x80, '0323990725'
Plan:Unknown, Type:Unknown
*Dec 16 17:45:36.492: ISDN BR0/1/0 Q931: RX <- SETUP pd = 8 callref =
0x0B
Standard = CCITT
Channel ID i = 0x83
*Dec 16 17:45:40.484: ISDN BR0/1/0 Q931: RX <- RELEASE_COMP pd = 8
callref = 0x
0B
Cause i = 0x80E6 - Recovery on timer expiry
Posted by Erik Tamminga on January 3, 2006, 3:43 pm
Have a look at
http://www.cisco.com/en/US/tech/tk652/tk653/technologies_tech_note09186a00804794c6.shtml.
From your debug output I cannot see the router continue call setup to the
PSTN. Have another look at your dial-plan.
Erik
> H323GTW#TERM MON
> H323GTW#
> 0x0B
> Standard = CCITT
> Channel ID i = 0x83
> 0x0B
> Standard = CCITT
> Channel ID i = 0x83
> callref = 0x
> 0B
Posted by on January 5, 2006, 2:21 am
Hello,
Thanks for your reply!
I've changed some little things on my access router...
Now, here is what I get on my 2811 router :
H323#deb isdn q931
*Jan 5 07:08:01.735: ISDN BR0/1/0 Q931: RX <- SETUP pd = 8 callref =
0x79
Standard = CCITT
Channel ID i = 0x83
Called Party Number i = 0x80, '0032390725'
*Jan 5 07:08:01.739: ISDN BR0/1/0 Q931: TX -> SETUP_ACK pd = 8
callref = 0xF9
Channel ID i = 0x89
*Jan 5 07:08:16.747: ISDN Se0/0/0:15 Q931: Applying typeplan for
sw-type 0x12 i
s 0x0 0x0, Calling num 7158
sw-type 0x12 i
s 0x0 0x0, Called num 0323990725
*Jan 5 07:08:16.747: ISDN Se0/0/0:15 Q931: TX -> SETUP pd = 8 callref
= 0x0165
Sending Complete
Standard = CCITT
Channel ID i = 0xA1839B
Preferred, Channel 27
Progress Ind i = 0x8183 - Origination address is non-ISDN
Calling Party Number i = 0x80, '7158'
Called Party Number i = 0x80, '032390725'
*Jan 5 07:08:16.747: ISDN BR0/1/0 Q931: TX -> CALL_PROC pd = 8
callref = 0xF9
*Jan 5 07:08:16.823: ISDN Se0/0/0:15 Q931: RX <- CALL_PROC pd = 8
callref = 0x
8165
Channel ID i = 0xA9839B
Exclusive, Channel 27
*Jan 5 07:08:16.823: ISDN Se0/0/0:15 Q931: RX <- CONNECT pd = 8
callref = 0x81
65
*Jan 5 07:08:16.827: ISDN Se0/0/0:15 Q931: TX -> CONNECT_ACK pd = 8
callref =
0x0165
*Jan 5 07:08:16.839: ISDN BR0/1/0 Q931: TX -> CONNECT pd = 8 callref
= 0xF9
*Jan 5 07:08:16.863: ISDN BR0/1/0 Q931: RX <- CONNECT_ACK pd = 8
callref = 0x7
9
*Jan 5 07:08:22.835: %ISDN-6-CONNECT: Interface BRI0/1/0:1 is now
connected to
unknown unknown
sh isdn active
*Jan 5 07:08:26.247: %ISDN-6-CONNECT: Interface BRI0/1/0:1 is now
connected to
unknown unknownSH ISDN ACTIVE
ISDN ACTIVE CALLS
Call Calling Called Remote Seconds Seconds Seconds
Charges
Type Number Number Name Used Left Idle
Units/Currency
Out 7158 0323990725 9 Unavail -
0
In ---N/A--- ---N/A--- 9 Unavail -
*Jan 5 07:08:39.139: ISDN BR0/1/0 Q931: RX <- DISCONNECT pd = 8
callref = 0x79
Cause i = 0x8090 - Normal call clearing
*Jan 5 07:08:39.139: %ISDN-6-DISCONNECT: Interface BRI0/1/0:1
disconnected fro
m N/A N/A, call lasted 22 seconds
disconnected fro
m unknown , call lasted 22 seconds
*Jan 5 07:08:39.143: ISDN BR0/1/0 Q931: TX -> RELEASE pd = 8 callref
= 0xF9
Cause i = 0x8290 - Normal call clearing
*Jan 5 07:08:39.155: ISDN Se0/0/0:15 Q931: TX -> DISCONNECT pd = 8
callref = 0
x0165
*Jan 5 07:08:39.179: ISDN BR0/1/0 Q931: RX <- RELEASE_COMP pd = 8
callref = 0x
79
*Jan 5 07:08:39.291: ISDN Se0/0/0:15 Q931: RX <- RELEASE pd = 8
callref = 0x81
65
*Jan 5 07:08:39.295: ISDN Se0/0/0:15 Q931: TX -> RELEASE_COMP pd = 8
callref =
0x0165
It seems the configuration is almost OK but the communication between
my access router (connected to the BRI interface of the 2811 router)
and my remote router can't be established.
Is it a problem of PRI configuration? Is it a question of configuring a
dedicated chanel on the PRI ?
Could you please give me your feedback about that ?
Regards
Benjamin
Posted by John Agosta on January 5, 2006, 9:05 am
It looks like a seperate call is being placed in each direction. The
connection should come up with a single
call. I've seen this before on more than one occasion - bug perhaps -
it had to do with the CHAP configuration and IOS version.
Specifically, if one-way authentication was configured, the routers placed
two calls, and the challenge
happened on one channel, but never got the response on that same channel.
If two way authentication was configured, a single call was placed, and the
challenge/response took place on
the same channel.
I'd suggest posting the configs for both routers, maybe even the output of
"debug ppp authentication" as well.......
Perhaps the easiest way to rule this out would be to eliminate
ppp/authentication from the conigurations and try again......
-ja
> Hello,
> H323#deb isdn q931
> 0x79
> Standard = CCITT
> Channel ID i = 0x83
> callref = 0xF9
> Channel ID i = 0x89
> sw-type 0x12 i
> sw-type 0x12 i
> = 0x0165
> Sending Complete
> Standard = CCITT
> callref = 0xF9
> callref = 0x
> 8165
> callref = 0x81
> 65
> callref =
> 0x0165
> = 0xF9
> callref = 0x7
> 9
> connected to
> unknown unknown
> sh isdn active
> connected to
> ISDN ACTIVE CALLS
> Charges
> Units/Currency
> 0
> callref = 0x79
> disconnected fro
> disconnected fro
> = 0xF9
> callref = 0
> x0165
> callref = 0x
> 79
> callref = 0x81
> 65
> callref =
> 0x0165
> Regards
> Benjamin
Similar ThreadsPosted
ISDN Switching between BRI and PRI interfaces January 3, 2006, 2:29 am
HSRP monitor several interfaces switching to standby on failure of any active interface May 10, 2008, 7:07 pm
ISDN interfaces in North America July 16, 2007, 8:49 am
Channelised ISDN E1/PRI and serial interfaces number September 10, 2007, 3:08 am
Process Switching vs. Fast/CEF Switching? May 27, 2007, 3:53 pm
Switching over DSL? July 6, 2005, 3:55 am
Switching problem ? September 11, 2005, 3:16 pm
Switching redirection September 28, 2005, 7:26 am
Switching ISPs February 27, 2006, 11:14 am
Switching ISPs February 27, 2006, 11:15 am
switching a PIX to "no nat control" August 10, 2006, 10:02 pm
Switching fabric November 7, 2006, 1:04 pm
PBR fast switching November 23, 2006, 6:25 am
Intelligent switching technology. July 12, 2005, 2:25 pm
RE : Switching redirection [urgent ...] September 29, 2005, 9:32 am
