Cisco Systems IP/VC 3540 vs. Sony PCS-1P /monitor disabled/
Subject Author Date
IP/VC 3540 vs. Sony PCS-1P /monitor disabled/ zedworks 02-24-06
Posted by on February 24, 2006, 3:06 am
Hi!
I would like to add a Sony PCS-1P (H.323) terminal to an existing Cisco
(IP/VC 3540, software version 3.2)+ Polycom (Viewstation EX - several
terminals) installation. The hole infrastructure runs on H.323, and
there's no CCM, so SCCP isn't an option.
The gatekeeper is IOS based.
The Sony can register just fine to the gatekeeper, and can use all of
it's facilities. Calling through the gatekeeper, but in point to point
mode, it works fine, there are basically no interoperability issues
with the Polycom terminals - even remote camera control works between
them.
But when I want to use the MCU for a conference call, the Sony PCS-1P
gets no image. It gets the sound and it can send both sound and video
(other participants can see the image transmitted from the Sony
camera). On the conference control web application, when the conference
is accessed, each participant has usually 4 icons next to it:
Microphone, Speaker, Monitor and Camera.
Well, the Monitor icon is completely missing from the Sony device, not
just crossed over, like when the camera or microphone gets disabled.
All codecs, fps-s, etc. have been double checked (and tried several
methods) to ensure they are the same both on the Sony and on the MCU.
There should be no access right problems (I couldn't find any. Is there
a place I should look specifically?)
As far as I can tell, there's no way to reenable the monitor, and I can
find no indications in the logs either (they only record
registering/unregistering devices).
ANY idea would be really appreciated, as I'm completely blocked by this
issue.
thanks,
Zoltan
Similar ThreadsPosted
IP/VC 3540 vs. Sony PCS-1P /monitor disabled/ February 24, 2006, 3:06 am
www.yescell.com sell refurbish Sony Ericsson cellphone and parts January 9, 2009, 3:09 am
PIX troubles H.323 even with fixup disabled August 15, 2007, 9:12 am
Logging to DMZ 5.6.7.8 tcp/1468 is disabled February 22, 2008, 6:51 am
3750 Error disabled ports from loopback?? November 11, 2005, 6:46 am
Etherchannel disabled = spanning tree loops... February 21, 2006, 12:34 pm
Error-disabled Uplink Port on 2950 - 12.1(22)EA9 May 29, 2007, 5:18 am
Standby Module disabled after IOS Image upgrade May 9, 2008, 1:58 pm
Cisco 6500 switch, Dell unmanaged switches err-disabled April 25, 2007, 9:26 am
Password recovery disabled on Cisco 1711 Router - cannot login or reset May 17, 2006, 8:50 am
rom monitor help September 9, 2005, 6:03 am
Monitor sessions December 12, 2005, 1:33 pm
Monitor Server/PC March 5, 2006, 11:26 pm
Monitor Servers/PC March 5, 2006, 11:27 pm
port monitor October 7, 2007, 8:17 pm
Residential Cabling Guide
Home Cabling Guide
Finally, an instantly downloadable book that saves you thousands in home improvement dollars! Enjoy living in 21st century technology-advanced home while increasing its selling value and competitive advantage on the real estate market. Whether your cabling is for home office or high-tech leisure, you can wire your home yourself or learn "wirish" to speak with your cabling contractors in their language!
Learn More
