Cisco Systems IP Stack no activated.
Subject Author Date
IP Stack no activated. andym@jse.co.za 08-23-05
Posted by andym@jse.co.za on August 23, 2005, 8:37 am
I'm trying to connect two routers (7206 and 1700) via a serial
interface over IP. Currently the serial communicates perfectly via IPX.
I've just confgured ip addresses on both sides with a /30 mask and
encapsulation is PPP but they cannot ping each other. I even tried HDLC
but the IP stack on the interface cannot even open. I have attached the
"show interface" command output of both routers:
1700 Router
Serial1/0 is up, line protocol is up
Hardware is CD2430 in sync mode
Description: LINK TO SAFEX
Internet address is 192.168.15.70/30
MTU 1500 bytes, BW 128 Kbit, DLY 20000 usec,
reliability 255/255, txload 1/255, rxload 5/255
Encapsulation PPP, loopback not set
Keepalive set (10 sec)
DTR is pulsed for 4294967 seconds on reset, Restart-Delay is 541942
secs
LCP Open
Closed: CDPCP
Open: IPXCP
Last input 00:00:01, output 00:00:01, output hang never
Last clearing of "show interface" counters 1w5d
Queueing strategy: fifo
Output queue 0/40, 0 drops; input queue 0/75, 0 drops
5 minute input rate 4000 bits/sec, 2 packets/sec
5 minute output rate 1000 bits/sec, 3 packets/sec
489253 packets input, 111702134 bytes, 0 no buffer
Received 0 broadcasts, 0 runts, 0 giants, 0 throttles
1110 input errors, 681 CRC, 0 frame, 0 overrun, 0 ignored, 429
abort
599055 packets output, 25929293 bytes, 0 underruns
0 output errors, 0 collisions, 39 interface resets
0 output buffer failures, 0 output buffers swapped out
0 carrier transitions
DCD=up DSR=up DTR=up RTS=up CTS=up
7206 Router
SAFEX-7200-2#sh int s3/0:10
Serial3/0:10 is up, line protocol is up
Hardware is Multichannel E1
Description: "Market Traders, Tim Gibson #57-03048-00"
Internet address is 192.168.15.69/30
MTU 1500 bytes, BW 64 Kbit, DLY 20000 usec,
reliability 255/255, txload 1/255, rxload 1/255
Encapsulation PPP, crc 16, CRC 16, Data non-inverted
LCP Open
Open: IPXCP
Last input 00:00:14, output 00:00:00, output hang never
Last clearing of "show interface" counters 10:49:38
Input queue: 0/75/0 (size/max/drops); Total output drops: 0
Queueing strategy: weighted fair
Output queue: 0/1000/64/0 (size/max total/threshold/drops)
Conversations 0/4/16 (active/max active/max total)
Reserved Conversations 0/0 (allocated/max allocated)
5 minute input rate 0 bits/sec, 0 packets/sec
5 minute output rate 0 bits/sec, 0 packets/sec
60631 packets input, 3053947 bytes, 0 no buffer
Received 0 broadcasts, 0 runts, 0 giants, 0* throttles
0 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored, 0 abort
42071 packets output, 13260031 bytes, 0 underruns
0 output errors, 0 collisions, 0 interface resets
no alarm present
Timeslot(s) Used:10, subrate: 64Kb/s, transmit delay is 0 flags
Posted by Anthrax on August 23, 2005, 10:48 am
> 1700 Router
> secs
> LCP Open
> Closed: CDPCP
> Open: IPXCP
> abort
> 7206 Router
> LCP Open
> Open: IPXCP
> no alarm present
is it "ip routing" enabled in both routers? any acls in the interfaces?
btw your interfaces in the 7200 has some errors, most likely from a
dirty line although in this case that's not the reason of you not being
able to ping.
2nd Law of Thermodynamics: Chaos will Reign.
--Anthrax--
Posted Via Usenet.com Premium Usenet Newsgroup Services
** SPEED ** RETENTION ** COMPLETION ** ANONYMITY **
http://www.usenet.com
Posted by andym@jse.co.za on August 24, 2005, 12:35 am
ip routing is activated on both routers. No ACL on both routers and our
local TELCO tested the line and it passed 100%. Could it be the IOS
maybe?
Posted by Mike' Newsgroups on August 24, 2005, 6:11 am
Check the timeslots configured on both sides of the link and make sure that
they are configured the same. Then run a show controllers s1/0 to make sure
that the clocking is set properly.
> 1700 Router
> secs
> LCP Open
> Closed: CDPCP
> Open: IPXCP
> abort
> 7206 Router
> LCP Open
> Open: IPXCP
> no alarm present
Similar ThreadsPosted
IP Stack no activated. August 23, 2005, 8:37 am
ASA 5505 as hardware vpn client to PIX 501 or ASA 5505 with network extension mode activated June 16, 2007, 8:21 am
Router Stack?? May 2, 2008, 3:04 am
SDM Java stack overflow February 17, 2006, 1:25 pm
Protocol stack with MPLS June 25, 2007, 6:51 am
3750 IOS Upgrade in a Stack March 16, 2008, 3:49 am
how to deliver IOS/Config to a stack of Ciscos? February 14, 2005, 5:45 pm
Newbie: 3750 Stack Question May 3, 2006, 4:36 pm
switch stack spanning tree June 15, 2005, 9:46 am
Two unit 3750 stack: one cable or two? June 29, 2005, 11:04 am
mrtg and catalyst 3750 stack February 2, 2007, 10:58 am
Soho 97 Crashing/Restarting - ideas? sh stack inc. July 10, 2005, 8:32 pm
remove stack configuration of Catalyst 3750? August 9, 2005, 11:21 am
3750 stack unit replacement procedure September 6, 2006, 11:06 am
Question about 3750 Stack and IP address Assignment January 17, 2007, 2:11 pm
